Husqvarna 701 Super Moto and Enduro!
Discussion in 'Thumpers' started by Dozer720, Aug 13, 2015.
  1. DIYPSCM
    DIYPSCM Been here awhile Supporter
    Jan 3, 2020
    320
    NorCal
    The 701 version has a base that screws right into the stock socket, clears everything and has the right connector. There is no connection for the small lower bulb tho.
  2. Snowq
    Snowq Been here awhile
    Aug 2, 2012
    479
    SWE
    Has anyone tried the "Ergo" seat yet?
    It doesn't look much better than stock.
  3. smackyface
    smackyface Boldly going wherever Supporter
    Nov 3, 2020
    300
    Albuquerque, NM
    For what it’s worth, I’m the same weight as you and the stock suspension was actually dangerous in rough terrain, even with the right springs. The problem is that the fork valving provides very little range of actual adjustment. Not nearly enough rebound, and in my case, the suspension ended up poorly balanced. It showed up as the back end kicking around all over the place, especially in whoops or larger bumps.
    I spent the money for a full revalve from a reputable shop and it was so worth it. Now, I’m terrain that felt unridable before, I can feel the bike moving evenly under me and the bike stays right on track.
    Yukon Ho! likes this.
  4. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    5,138
    What year was your bike? Valving changed in 2020.
  5. greasyfatman
    Oct 18, 2014
    5,138
    Got a golden tire fatty to try up front. hope I can get it on before perry mountain this weekend.
  6. Kiwirich
    Kiwirich Super Moderator Super Moderator Supporter
    Dec 26, 2007
    1,004
    Toowoomba Australia
    Hey @Doc Sarvis
    When you get the parts , can you share the details ?
    TIA
    Kiwirich
    Doc Sarvis and willh like this.
  7. willh
    willh Been here awhile
    Feb 23, 2005
    488
    Shefford, Quebec
    Must say I’m pleased with the 15 tooth for the morning city commute on my SM. Able to crawl without the clutch and it’s more lively. Gearing works better/happier engine at the speeds used. Weather permitting I’ll see how it pans out for the twisties.
    the 5second blink from the abs light is a little annoying though. Electrical tape or…
    Rodknee likes this.
  8. Dryslick
    Dryslick Been here awhile
    Feb 11, 2011
    336
    Lake Berkely, Montana
    I installed the BRP bar clamp and stabilizer mount on my bike this morning. I need more bar height, so I also ordered a BRP's 15mm bar spacer. I ended up not installing it as there doesn't seem to be enough slack in the brake line leading to the front master cylinder. 15mm isn't much (1/2"), but the BRP clamp also raised the bars 15mm so it would be an inch total. Do I need to use a longer brake line to make this work? Not sure I want mess with bleeding ABS brakes. I'll need to install lowered foot pegs anyway, so it might just be a matter of how big a drop I go with.
  9. Brmax
    Brmax Been here awhile
    Oct 19, 2020
    248
    Missouri
    On mine a blue frame 20 model right side is mounted the rear brake hose and attached abs cable with black aluminum clamp and its thru bolt
    mjskier likes this.
  10. Brmax
    Oct 19, 2020
    248
    Missouri
    I
    I haven't seen one in person, though that to me does look wider in a useable area. Yet looks factory thin.
    Im confident if one never gets their feet of the pegs a wider seat more forward can work. Just another opinion
    Snowq likes this.
  11. Dryslick
    Feb 11, 2011
    336
    Did you ever wish you’d taken a few more minutes to sort through a problem before you posted a silly question? Got it sorted out, and the bar risers installed. Just wasn’t that hard.
    HBSURFDAD likes this.
  12. Kiwirich
    Dec 26, 2007
    1,004
    Toowoomba Australia
    You're certainly not the first.
    Kiwirich
    Dryslick likes this.
  13. mjskier
    mjskier Been here awhile
    Aug 14, 2010
    868
    Colorado
    Has anybody run into an issue fitting a stiffer shock spring?
    I'm trying to go from the stock 7.6 kg/mm to an 8.0 ('17 701 enduro)
    The spring is about 4 to 5mm wider and doesn't seem to fit between the front of the swing arm and the rear of the frame.
    No matter how much I rotate it to try to find a sweet spot I can't align the bottom holes.
  14. Yaay
    Yaay Been here awhile
    Dec 10, 2016
    124
    Hey guys,
    i've heard there are adjustable steering locks (to decrease the turning cycle) available for the 2020+ 701s. Couldn't find them online yet though. Anyone has a link or atleast the name to search for? The standard turning radius on this bike is quite annoying :/
  15. Big_John
    Big_John That'll be the day
    Aug 11, 2007
    4,406
    Further out West than Before
  16. Big_John
    Aug 11, 2007
    4,406
    I know from a lot of Enduro Touring experience with a loaded bike, I will want the "Willy's Jeep Gear" in a lot of riding situations.
    Stock being 15/46.... I would like a 14/50 or so, as someone already mentioned, especially if the bike is capable of 65mph with this gearing. Having the bike loaded and riding the Rocky Mountain Region, its nice to crawl around without slipping the clutch so much.
    I do wonder about the rear chain guide continuing to fit, moving from a 46 to a 50.
  17. Big_John
    Aug 11, 2007
    4,406
    I ordered this one......
    Snowq likes this.
  18. Big_John
    Aug 11, 2007
    4,406
    You have my attention and duly noted. I will continue to pay close attention to how she behaves and perform the necessary modifications. I do all my own work and will re-valve if necessary.
    hardhat and smackyface like this.
  19. Graniteone
    Graniteone 3,2,1...Beer me! Supporter
    Jul 25, 2011
    868
    Golden, Colorado
    My 701 LR needs this badly as it seems to find the false neutral between 5th 6th regularly. I am running 14 in the front and stock rear and the bike will climb without too much clutch interference. Highway the bike will hum along at 80 no problem and still have plenty of juice left.
  20. Yukon Ho!
    Yukon Ho! It's a big world! Supporter
    Oct 2, 2011
    429
    WA State
    Yes I have had the shift-pro in mine for 2-3 years now, solved the 5th-6th shift misses for me nicely.
    Graniteone likes this.
