Husqvarna 701 Super Moto and Enduro!
Discussion in 'Thumpers' started by Dozer720, Aug 13, 2015.
  1. Doc Sarvis
    Doc Sarvis Advent-ia before dementia Supporter
    Dec 11, 2015
    590
    Carp Ca
  2. Manic-Mechanic
    Manic-Mechanic Form follows function… Supporter
    Jun 11, 2008
    221
    New York
    No no guys STOP! Your ruining my business model!! Lol :rofl
    in all seriousness thought.
    The rubbermaid trash can windscreens the DR650 guys make are a thing of beauty coming from a trash can. Lol
    Bhart89 likes this.
  3. blackSP
    blackSP Im non praesto sum in orbita
    Feb 4, 2008
    1,174
    Amsterdam
    You just gotta love those big rally towers. The bigger the better!
    PYG RYDR, MaddMatt, Mad Matt and 11 others like this.
  4. waldecker
    waldecker Been here awhile
    Mar 15, 2009
    749
    Far South Coast NSW
    How relevant are those "tests "for actual crashes ?
    Probably not at all I would think, looking at pics from real rally crashes ( remember ,over in the OZ section, the Ktm vs roo(s) ), the forces there are more complex. Guess there's a reason some manufacturers have given prototype carbon bits fitted with accelerometers to guinea pig riders to use in competition...
    Plus fatigue from vibration etc might play a role.
    Nice bit of kit though...
    Doc Sarvis likes this.
  5. Pooz
    Pooz Been here awhile
    Mar 16, 2017
    429
    Savoie - FR
    KiwiPewe likes this.
  6. tomasv
    tomasv Check the Czech!
    Jun 14, 2006
    1,553
    Seattle area
    Agree on the complexity of forces - I slid my 701 under the bumper of a jeep (foot bones did not hold but foot pegs did, rally kit did as well) and it was interesting to see where the stress on the material was (white lines in fairing, windshield etc).
    Vibration fatigue is much worst with Aluminum/Dural compare to composites. That is/has been proven. With Rade's stainless steel reinforcement inside the mounting point in the carbon I am going to trust it much more. Plus don;t forget they offer the lifetime warranty on the 701 carbon towers.
  7. Sno Dawg
    Sno Dawg Long timer
    Mar 18, 2007
    3,398
    Philadelphia, PA
    Had a blast on my 701 in the PB500 today. I rode with two different groups and the trails were fast and flowy. I finally have my Scott Steering Stabilizer dialed in for sand, and I felt like I was cheating when we hit long-deep sand spots. This bike is so much fun to ride offroad, and I am constantly impressed by how smooth the engine is both on and off road.
    I rode the first part of the day (65 miles) with this motley-looking crew who had a fast and fun pace.
  8. Honda Rider
    Honda Rider Been here awhile
    Dec 25, 2008
    201
    I replaced my clutch slave cylinder with a recluse after the OEM failed around 1200 miles. I'm pretty sure the clutch throw was short before I replaced the slave but after I replaced it, it seems very short. In other words I only use the last 20% of the throw of the clutch arm to disengage/engage the clutch. Is that normal throw for a '20 701?
    I'm curious if it's because my clutch discs are worn. I am pretty sure that the slave cylinder has been bled correctly but I'm concerned that something is not quite right and will leave me stranded somewhere at some point. Any insight would be appreciated.
  9. Tangai
    Tangai Been here awhile
    Oct 28, 2006
    912
    Pocola, OK
    They changed the motor in 2017, but changed it again, new cylinder design, in 2018. From 18 on it's the same as the 19 and on KTM 690.
  10. Big_John
    Big_John That'll be the day
    Aug 11, 2007
    4,357
    Further out West than Before
    The bike was phenomenal today, guessing the Motoz tire broke in and was better. Very rough desert riding, but the bike performed awesome.
  11. Doc Sarvis
    Dec 11, 2015
    590
    Carp Ca
    Mine failed around 300 miles and I replaced the o-ring and it worked fine until I put a Radius X Rekluse in it. In both times that I had to re-bleed I found that reverse bleeding worked great and was pretty quick (other than getting the hose on the nipple which can be a royal PITA). Worn frictions should self compensate unless they are shot and you have run out of fluid.
    1) Hose on nipple on slave with fluid in bottle.
    2) Master cylinder cap off with fluid showing.
    3) Push fluid up into MC and suck it out so so the level stays within the limits.
    Should be a clear stream into the MC res pretty quickly. Button it back up. My lever disengages the clutch nearer the beginning of lever travel. Oh and make sure you are using the right DOT fluid. Ask me how I know this.
    Honda Rider likes this.
  12. Honda Rider
    Dec 25, 2008
    201
    I wasn't sure how to say it but mine is like yours then. My clutch disengages at the beginning of the lever travel as well and by the time you've pulled it in 20%, it's fully disengaged. I noticed it was very little travel when I first got it but wasn't sure if it got less after I replaced the slave cylinder.
    Thanks for the information about the clutch discs self compensating. My clutch plates seem to be working fine and I don't feel any slippage so hopefully it'll last a while.
  13. Honda Rider
    Dec 25, 2008
    201
    Laid my bike down for the first time when I lost my footing trying to turn around on on a camber with loose soil. The bike was laying down hill where the wheels were higher than the tank. Nothing leaked out like fuel or oil but when I started it and rode it out of the woods, it died several times like it was out of gas or the tank vents we're stopped up. Finally got it back to camp and let it sit for 30 minutes while I looked it over better. Nothing looked damaged so I started it back up and rode around the campground then on the road at speed and no problems.
    So my question is, what is the protocol for starting a bike that has been dropped and down for 10 minutes or so?
    Any idea why it died so many times after I got it back upright?
  14. Maugrim
    Maugrim Been here awhile
    Jun 4, 2016
    223
    SE
    Never had any problems after same kind of dirt naps. It has always ran normal afterwards
  15. 2whl-hoop
    2whl-hoop Long timer Supporter
    Jan 12, 2008
    1,778
    Woodbury, MN
    Do you still have the charcoal canister on the bike? On the 1*90s they get removed because they can get clogged with gas during a tip-over and then cause the bike bike to run like you described.
    renogeorge likes this.
  16. Honda Rider
    Dec 25, 2008
    201
    Yep, it's still on there so that is interesting. Thanks for the tip. I'll search a bit for that.
  17. BrittC
    BrittC Been here awhile Supporter
    Apr 10, 2009
    785
    Westmont, IL
  18. renogeorge
    renogeorge Let's ride!! Supporter
    Apr 7, 2007
    6,993
    Reno
    When did the 701 get the Explorer forks? Thanks
  19. raschaa
    raschaa Been here awhile
    Sep 5, 2018
    339
    beyond the 7 mountains, with the 7 dwarfs
    Yo, it's the charcoal canister... gets flooded and causes all sorts of problems if laid over to long...
  20. raschaa
    Sep 5, 2018
    339
    2019 iirc... (and it's Xplor)
