Husqvarna 701RR Builds
Discussion in 'Thumpers' started by David Coulthard, Feb 23, 2017.
  1. wass
    wass Been here awhile
    Jun 19, 2016
    103
    Wellington
    Since distances between pumps here in the land of the long white cloud are not what they are in the Australian outback I went for the Lite 701. Nav Tower arrived and greater part of Easter was spent deep down in the dungeon transforming this:
    Into this:
    Build quality of kit is absolutely top notch. Got a sneak preview of what final Lite 701 kit looks like and am not at liberty to disclose, but it really looks OEM. Wished the bike rolled out of the factory like that.
    First test ride with the nav tower:
    a2zworks, Kiwirich, DR DAN and 2 others like this.
  2. David Coulthard
    David Coulthard Been here awhile
    Feb 12, 2015
    208
    Sydney ozzieland
    Nice, may end up putting the lite conversion on myself next year for when I do not need the range.
    DR DAN and wass like this.
  3. kreativ
    kreativ OFFROADer
    Dec 14, 2011
    20
    Wroclaw, Poland
  4. David Coulthard
    Feb 12, 2015
    208
    Sydney ozzieland
    @kreativ, for the battery monitor/voltmeter, see this post http://advrider.com/index.php?threads/husqvarna-701rr-builds.1207074/page-6#post-32950887 I used the one from Sparkbright as it fits the holes in the 701RR tower without any modification. I personally prefer the simple LED as it gives the info I need and nothing more.
    Orange = Normal when not turned on, or voltage is 12v (i.e. a little low) when running
    Green = Normal voltage when running, all is OK
    Flashing Green/Red = Overcharge, like the regulator has gone
    Flashing Red (One, Two or Three as voltage progressively drops) = Battery shagged, or Stator not charging the battery.
    Here is a little video of the different stages, flashing red when ignition on is normal as the bike is drawing more load at that point.
    On the 12v/USB. I put mine just behind the GPS on the Nav Tower, it is protected from the rain here when riding, but also leaves it accessible to plug things in without taking the screen off.
    I wired this directly to the batter with a SPST waterproof switch to enable me to charge items with the bike stationary after a ride at the end of the day and not need the ignition on.
    DR DAN, wass and Kiwirich like this.
  5. kreativ
    kreativ OFFROADer
    Dec 14, 2011
    20
    Wroclaw, Poland
    what size of this Sparkbright? 3 available.
  6. David Coulthard
    Feb 12, 2015
    208
    Sydney ozzieland
    I used an eclipse10
    Kiwirich likes this.
  7. prs34
    prs34 n00b
    Apr 23, 2018
    6
    France
    Hi wass, how much did you pay for the navigation tower, I did not find it at Aurora retail. I'm looking for a light configuation.
  8. David Coulthard
    Feb 12, 2015
    208
    Sydney ozzieland
    A note on warranty from Husqvarna after fitting the 701RR kit as this was asked late last year but at the time there was no definitive answer other than Husqvarna should honour the warranty.
    My 701 has always used a little oil from new, recently however the oil use has increased. Bike has about 17000km on the clock. The dealer was contacted and after a test to measure the oil use Husqvarna approved the dealer to pull down the engine to investigate. The dealer is fully aware of the 701RR kit being on the bike.
    This is the important bit, it was requested that I remove my 701RR accessories to allow easy access to the engine before bringing it into the dealer. I.E tanks and fairing.
    This means that the kit is recognised as an accessory item and not a modification to the bike, plus Husqvarna will honour their warranty with the kit on, at least in my case.
    If others have warranty questions with the kit on in the future, it may be a good idea to reference this
  9. 640 Armageddon
    640 Armageddon Xplorer
    Mar 4, 2009
    4,173
    Greece
    This week the lite kit will be online, it will not be just the tower, but with ABS molded side panels and dedicated brackets. We tried with the team to minimize the aesthetic differences between the HQV bike and our parts. I think it looks spot on, should be online on Friday :deal
    Note to the Xplorer or Rally Replica users: Panels are designed so that when you remove the tanks, you install the side panels, leave the skid plate and the exhaust and go riding. In about 10minutes you can convert the bike from Xplorer to Lite. :freaky
    D.
    Nowwhat, DR DAN, Yellow Pig and 6 others like this.
  10. prs34
    prs34 n00b
    Apr 23, 2018
    6
    France
    An idea of the price ? and weight?
  11. David Coulthard
    Feb 12, 2015
    208
    Sydney ozzieland
    Update on the oil issue and warranty with the 701RR kit
    Oil found on pistons, new valve seals. One valve had a lip on it, new valve. Piston rings all within spec.
    All done under warranty within the week, no issues or questions by HQV or the dealer whatsoever.
    Kiwirich and 640 Armageddon like this.
  12. whatsupdoc
    whatsupdoc Been here awhile
    Jul 6, 2015
    199
    Chocolate Country
    The Aurora kit is probably not a problem since they're using original parts but does anyone know if the omega kit is streetlegal in France?
    I read a built thread in german where someone declared the front tanks a fairing and did not connect them to the fuel system to make it street legal. For me that would be a deal breaker...?
    David Coulthard likes this.
  13. 640 Armageddon
    Mar 4, 2009
    4,173
    Greece
    That is usually done with other manufacturers or 'racing use only' marking. When people go to get MOT, the yearly inspection, this can be done to get through it. They are like 'fairings' at the time of inspection, not used for fuel load. Dunno what will happen if they stop you for inspection though. Thomas (the Omega owner, is more than helpful) and kits have been around, I am sure you can get feedback on that. Depends heavily on the country. In Greece, put all the stuff you want, the bike can pass MOT (unless it carries a bomb :p ) . In Germany things from what I know from customers it is more strict. Same in Switzerland, which from my experience is the worst in that matter.
  14. whatsupdoc
    Jul 6, 2015
    199
    Chocolate Country
    I know ...I work in switzerland...:fpalm
    Traffic drives me nuts. But france is pretty liberal. But if I have a bike...with french plates...which is streetlegal here...they can't really fine me for riding it there can they? Or am I wrong? @Armageddon: you manufacture the Aurora kit, don't you. Have you sold some in france? How is order - delivery time ? I ride a 1190 R '16 model. I'm up to something new...
  15. 640 Armageddon
    Mar 4, 2009
    4,173
    Greece
    I have sold to Switzerland before and France yes. One of the owners of Kriega, the bike that was in EICMA exhibition last year, is located in France. Using the bike either as an Xplorer or a Super 7o1 conversion. - Delivery time. Waiting for 9 sets of tanks with all the paraphernalia at the moment to start clearing the queue. Should be here next week. Also supporting people for Hellas Rally makes things tricky at the moment.
    Things may be changing soon, but it is going to be in favor of minimum delivery time, hopefully next day shipping for most if not all parts is the target with the product range booming as well. Cross fingers I shall have news next week.
    D.
    DirtBrain likes this.
  16. wass
    Jun 19, 2016
    103
    Wellington
    My dream bike built:
    lindmark, Dukehunt, DR DAN and 4 others like this.
  17. justinope
    justinope Long timer
    Oct 28, 2013
    1,513
    St George, UT
  18. lindmark
    lindmark n00b
    Jul 21, 2017
    4
    DR DAN, wass and josip01 like this.
  19. doom
    doom bithead
    Dec 12, 2004
    205
    Seattle, WA
    After much thought I have decided to pull the trigger on an Xplorer kit. I’ll combine that with the Super 701 front panels as well for flexibility. I love love love the relative ease of switching between configurations as one of the things that I love about my 701 right now is the lack of bulk for more technical terrain. However, after doing many 200+ mile days in a variety of conditions and most recently 500+ miles, over half of which were higher speed paved sections I definitely want the option of a fairing for longer trips. In addition, having the easy option to carry more fuel for some of my remote adventures is fantastic.
    Thank you so much @640 Armageddon for answering the quick questions that I had. I look forward to working with you.
    DR DAN and David Coulthard like this.
  20. cosmic
    cosmic Been here awhile
    May 24, 2011
    365
    Split,Croatia
    I have a question regarding the Lite kit... Are some kind of graphics included in the kit to cover those lovely ABS panels? Thx.
