Husqvarna FE501S & FE350S
Discussion in 'Thumpers' started by trailrider383, Sep 11, 2014.
  1. Hertz13
    Hertz13 Been here awhile
    Aug 19, 2018
    261
    Central PA
    a whole shim set is a total waste of money unless you have a bunch of bikes that use that size or are doing work on a lot of bikes.
    Pull out the one you need to adjust, measure it, and order a new shim.
    Sidehil likes this.
  2. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off
    Apr 22, 2016
    5,542
    Pennsylvania, but living in a toy hauler full-time
    Sounds good to me. Ok since I've got a larger gap than spec, I need a thicker shim right? And in my case again , from the photo I should get one .005" thicker? Will it change any of the other ones when I do that?
  3. backpain
    backpain Been here awhile
    Dec 1, 2013
    396
    around
    Brake cleaner/contact cleaner and a soft rag (even paper towel/paper shop towel) will remove virtually any dirt/stains. Then, when you wipe back over it with a dirty rag, you will see where the texture is the problem (which is where Magic Erasers excel). Smooth out the texture (scratches, etc) and the pieces will hold less dirt/wipe off easier. I'm too lazy to polish the plastics, so I keep using brake cleaner on the difficult sections. It will eat some types of decal ink, though.
    X3 on Magic Eraser for the textured metal, for sure.
    Bitingdog, Anatoli and Nowwhat like this.
  4. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    9,689
    On the Ground Laughing
    The 2020 build is progressing nicely
    Anyone, Dan950ser, Bitingdog and 5 others like this.
  5. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    5,119
    NYC
    Yes, yes and no, in that order.
  6. Hertz13
    Aug 19, 2018
    261
    Central PA
    if you want to get that 0.010” to 0.005” then yes, go 0.005” thicker. You’ll have to take the one you want to change out and measure what it is then add 0.005”.
    I like to use metric feelers and measure in metric because that’s what the spec is and that’s what the shims are sold as. Sure you can convert but you’ll want to use a mic to measure the shim
  7. Snake Oiler
    Apr 22, 2016
    5,542
    Thanks I'm looking for new shim now. I need a 2.260mm it looks like the stock was 2.1336 plus my .005" hopefully I did my math right
  8. Sidehil
    Sidehil On any Sunday
    Mar 28, 2013
    1,559
    Bremerton WA
    but they are a nice box of washers:) too or rivet backers for sled parts:)
    Bitingdog and Snake Oiler like this.
  9. Snake Oiler
    Apr 22, 2016
    5,542
    Yeah I'm sure metic feelers would be best. But I don't have any right now. I used dial calipers to measure the shim and came up with .084 which converts to 2.1336mm I can go to .090 which is 2.286. RM has shim sizes 2.24 and 2.28mm so I'll get one each. Hopefully the 2.28 works that would be good I think
    Sidehil likes this.
  10. Sidehil
    Mar 28, 2013
    1,559
    Bremerton WA
    I tried magic eraser but did not seam to work on my latest crash:) I can ride a dirt bike better than I can walk......
    ztrab, Bitingdog and Lurkerlou like this.
  11. Snake Oiler
    Apr 22, 2016
    5,542
    Ouch that one hurt.
    Sidehil likes this.
  12. Snake Oiler
    Apr 22, 2016
    5,542
    Almost erased the whole front end
    Sidehil likes this.
  13. Sidehil
    Mar 28, 2013
    1,559
    Bremerton WA
    Guy pulled a u turn and I did not have but a Mili second to respond.... lucky like the guy that fell into the river on the TPI thread, I’m hard to kill......
    Bitingdog and Nowwhat like this.
  14. Nowwhat
    Mar 2, 2007
    9,689
    You need to spray Simple Green with a little Wd40 on the magic eraser first and all that will buff out...
    Glad you are ok.....wow
    Bitingdog and Sidehil like this.
  15. Sidehil
    Mar 28, 2013
    1,559
    Bremerton WA
    Never saw my sweet FJR again... got pics from my firefighter cousin.....
  16. Sidehil
    Mar 28, 2013
    1,559
    Bremerton WA
    Back to bikes, I’m thinking a new 300 in blue will make me feel better or just break more bones :)
  17. Yellow Pig
    Yellow Pig Allergic to asphalt! Supporter
    Oct 28, 2004
    9,680
    Thousand Oaks, CA
    Magic Eraser is a NO GO.
    It works great, but is abrasive and will take off the sealed top layer of the plastics making them even more susceptible to staining.
    WD-40 + Rag + Elbow Grease works like a charm.
    Dirt2007, thejrod and Sidehil like this.
  18. Sidehil
    Mar 28, 2013
    1,559
    Bremerton WA
    I’ve used 15/40 diesel oil with absolutely no problem, chevron or shell work just fine, you never know what you will find on a long ride, but I’ve changed oil in the Fairbanks Walmart and their car shop takes your old oil.... and your new oil pan you just bought:))
    Snake Oiler and Bitingdog like this.
  19. N8
    N8 Masked pumpkin rider Supporter
    Dec 27, 2012
    8,591
    Lancaster, PA
    I hate oil posts but that pic was too cool to not like. Rotella T4. Nothing but the best for my girl.
  20. new2adv
    new2adv Converting gas into wheelies since 1974
    Nov 5, 2018
    1,230
    Great White North
    Yup, Rotella is great for these bikes. 5W40 if you can find it, 15W40 otherwise.
    Snake Oiler likes this.
