Husqvarna FE501S & FE350S
Discussion in 'Thumpers' started by trailrider383, Sep 11, 2014.
  1. OneManWolfPack
    OneManWolfPack Been here awhile
    May 21, 2018
    676
    Calgary
    Start simple.
    1) Sag. Are you able to get the sag adjusted properly fully loaded (bike a, rider and gear)? If not then you need a different rear spring rate.
    Once this is set what is the complaint regarding the forks? This will steer you in the proper direction on what to do to them. I believe stock was 4.6 spring rate for the forks. I went to 5.0s and I like where they currently are. Still supple on slow speed trail junk but rarely bottom on the high speed stuff. Front end feels solid up to 80 mph without a stabilizer. If you need more stiffness don't forget the Huskys come with the adjustable preload on the top of the forks.
  2. new2adv
    new2adv Converting gas into wheelies since 1974
    Nov 5, 2018
    1,230
    Great White North
    For what it's worth, I was very happy with the performance of the suspension on my 2015 FE350s once I got the right springs, set the sag, and played a bit with the clickers. It transformed the bike and gave me a lot more confidence to ride fast through the trail trash. It is absolutely the best bang for your buck of any mod you can do to your bike.
  3. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off
    Apr 22, 2016
    5,539
    Pennsylvania, but living in a toy hauler full-time
    Yes I know there's a lot of veritable's that comes into play here.
    I'm just an middle aged old man that mostly dual sport rides with some fast gravel/dirt involved. Not much if any single track unless it's something stupid I got myself into or to get to a oportun out of the way campsite. As far as gear I wear that changes from day to day. And most if not all other gear is put on the rear suspension, which by the way seem good for me and the gear.
    So back to the front. Just I'll just try new springs and get the rate advised from Racetech which if I remember correctly is .042 or .42. Something like that. But I'd really like to know the stock spring rate first. Maybe the springs are marked somehow, I'll have to pull out one and check if it's not in the book.
    Thank
  4. Grayjet
    Grayjet Ride on!
    Jun 14, 2008
    635
    Va Beach
    This made a huge difference for me... but I am heavier than your average guy. I think the stock springs are set for a 145-165 pound rider, or somewhere near that range. If you are in that range and can't make the stockers work for you, contact Alex at Konflict Motorsports. I haven't heard a bad review of Konflict yet. I recently read an article claiming that a popular FE suspension mod is to go with cone valve forks with a Trax rear shock. (Link) Not sure if anyone on this thread is running that combo, though.
    I gotta say, I am pretty happy with the stock suspension (sprung for my weight). I just rode my FE in the Shendandoah 500, a dual sport ride with everything from long technical, rocky uphills to fast forest service roads with jumps (rain cuts that acted like jumps). The bike was awesome. You may ride far more aggressively than me, though.
  5. Snake Oiler
    Apr 22, 2016
    5,539
    Believe it or not the sag was almost dead on from the shop. All I did was okay around with the comp and rebound and not much of that until I started loading up camping gear. So I believe that the rear spring rate is pretty good
  6. Snake Oiler
    Apr 22, 2016
    5,539
    No I'm not aggressive rider, but in personality I've been told I was at times :thwak
    Bitingdog likes this.
  7. Emgo
    Emgo Started on a CT70 almost 52 years ago
    Feb 23, 2015
    575
    Gladeville, TN
    I don't think there are any marks, any way of measuring the wire diameter or counting coils to determine the spring rate on stock Xplor springs. Unlike the older WP forks, hope I'm wrong.
    Ken
  8. new2adv
    Nov 5, 2018
    1,230
    Great White North
    Stock spring rate should be in the owner's manual.
  9. Snake Oiler
    Apr 22, 2016
    5,539
    The only thing in the manual is it gives me three rider weights and the spring rate for each.
    I'd fall into the the rate of 4.4 according to the manual and Racetech calculator. So Racetech gives the price of $129, is that each? And RM springs are $110, and says 1 in the quantity blocks which leads me to believe that for a pair. But that doesn't sound right. Any help would be appreciated on the quantity. And is Racetech the extra money?
  10. Emgo
    Feb 23, 2015
    575
    Gladeville, TN
    Here are screen shots from my TE300 and FE501 owners manuals. Neither say which spring came in the bike.
  11. Snake Oiler
    Apr 22, 2016
    5,539
  12. new2adv
    Nov 5, 2018
    1,230
    Great White North
    Hmm OK, well USUALLY it's sprung for a rider in the 75-85KG range. But why do you need to know the stock rate? Can't you just extrapolate based on the info there to get the spring rate you need? (Go up or down 0.2NM/mm per 10kg rider weight)
  13. ovlaicu
    ovlaicu Noob
    Apr 8, 2018
    367
    Ontario, Canada
  14. ovlaicu
    ovlaicu Noob
    Apr 8, 2018
    367
    Ontario, Canada
    I swear my screenshot looks clear as day, I dont know why after the upload it looks so fuzzy:(
  15. Dan950ser
    Dan950ser Two Wheeled Addict
    Sep 24, 2010
    2,508
    Olympia, WA
    The springs that come in the bike are always the middle ones listed in the manual. For 165-187 lb rider. Hope this helps
  16. Snake Oiler
    Apr 22, 2016
    5,539
    Yes it does. Thanks. I believe on Monday I'll call Racetech and have a chat with them. Looking at springs at least. Anyone have an opinion on their gold valve on the explorers? I know on my CRF 250L they made a huge impact, but that suspension totally sucked from the factory.
  17. AndyB21
    AndyB21 Adventurer
    Feb 9, 2008
    52
    Bedford UK
    It’s been a long time since I last posted on the forum but now I’ve pressed the button on purchasing an MY20 501 I thought I’d put an appearance in again.
    The plan is to turn it into something that I consider suitable for lightweight touring on the slightly dubious quality roads found in Eastern Europe as well as a bit of gentle off roading closer to home. This is going to involve a larger fuel tank that can be fitted when I’m away from home, a lightweight luggage rack that will take my 15l Wolfman panniers plus a rollbag for a tent/sleeping bag and I’ll probably blow a more substantial chunk of my hard earned cash on a travel tower from those nice gents at Nomad in the NL.
    Why a 501? Because over the last few years I’ve been using bigger capacity bikes for my travels and the combination of excess weight and ridiculous traffic regulations in Europe that now allow them to chase me with fines once I’m home have made me re-evaluate my needs and it was either a 500EXC or the Husqvarna.
    I’ll no doubt be pestering you guys about how far I can stretch the time between oil/filter changes on long trips, suspension changes and perhaps a couple of tweaks to the performance level as well :D
    Bitingdog, Nowwhat and Snake Oiler like this.
  18. Anatoli
    Anatoli Pale rider
    Nov 6, 2016
    3,043
    Skagit Valley, Washington
    I think that you will really be happy with the 501. Many in the Adventure community are embracing the 500 twins as a rational alternative to bigger, heavier, and more costly bikes. If you never leave the tarmac the big bikes are ok, but the stellar dirt credentials of the 500’s open up vast exploration opportunities. The bottom line is that the solo adventurer needs to be able to extricate and recover the bike solo. The heavier the bike, the more difficult or impossible the task.
    The excellent suspension and ground clearance are important too. My 501 has 48 mm fork tubes: my 125 lb heavier Africa Twin has 45 mm tubes with 3 inches less travel. Guess which flexes more when stressed? The rubber clutch dampers are another nice touch that extend driveline life. 60 mpg is possible with a judicious throttle hand. Combined with even a smallish 3.1 gallon tank and 180 mile range is in hand without an excessively large tank.
    The 501 power plant is tuned to provide impressive torque right off idle. This means less wear, noise, and fuel consumption. Nobody complains about a lack of peak power when slightly modded. I can’t get 6th gear wheelies on the Africa Twin, but they are thrilling on the 501. Durability is excellent with proper care: many examples show 700 hours or more with no engine work. Of course the smaller oil capacity requires more frequent changing, but it is a simple and inexpensive matter. Bottom line: the 500 twins provide unmatched performance and enjoyment for the serious adventurer. Slab riders will want to stay with their mobile reclining chairs, but will miss much of the adventure.
    mo_rider, craigt, Bitingdog and 3 others like this.
  19. Snake Oiler
    Apr 22, 2016
    5,539
    You silver tongue devil
    Bitingdog and Anatoli like this.
  20. Ned1
    Ned1 Opinions are like <fill in the blank>
    Dec 20, 2005
    1,203
    BC/WA
    :lol3
