1. eNewsletter Sign Up
Husqvarna FE501S & FE350S
Discussion in 'Thumpers' started by trailrider383, Sep 11, 2014.
  1. Fast1
    Fast1 Twisted Throttle
    Aug 18, 2007
    3,807
    Bridge over Troubled Water
    When I changed the oil weight (lighter weight) in my Husky 630 and increased the air gap it was night and day different from stock configuration. This solved the issue I was faced with, granted I wasn't altering suspension characteristics for specific race courses in an attempt to win but it did solve the problem for what I used the moto for.
    Anyone likes this.
  2. Benduro
    Benduro Rex Everything Supporter
    Jul 11, 2012
    26,633
    El Portal, Ca
    That said, it also depends a lot on tire choice.
    I don't care about punctures in my rear tire because I run 0 psi because the sidewalls are so stiff.
    Front, not so much, but as you say, the punctures are easy to fix.
    GT216aa in the front, you can tell when it's below 10psi
    Snake Oiler likes this.
  3. mo_rider
    mo_rider the dude abides Supporter
    Nov 29, 2016
    414
  4. Sidehil
    Sidehil On any Sunday
    Mar 28, 2013
    1,397
    Bremerton WA
    I’m getting one soon... but I’m working out the bugs in my knees and legs after the last bit of passing on a street bike.....
  5. Sidehil
    Mar 28, 2013
    1,397
    Bremerton WA
    It’s true....
  6. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off
    Apr 22, 2016
    3,713
    Pennsylvania, but living in a toy hauler full-time
    I know it at least it makes this old man think he's getting better at riding
    Sidehil, RideAbout and John_B like this.
  7. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    8,384
    On the Ground Laughing
    Brp submounts for the 2020 501 available Monday
  8. Snake Oiler
    Apr 22, 2016
    3,713
    Who manufacturer's the stock counter sprocket for the 501?
  9. Dan950ser
    Dan950ser Two Wheeled Addict
    Sep 24, 2010
    2,400
    Olympia, WA
    ktm does.
    here are the part numbers
    13 tooth P/N 79233029013
    14 tooth P/N 79233129014
  10. Nowwhat
    Mar 2, 2007
    8,384
    Consider ironman sprockets and their dome washer
    Dan950ser likes this.
  11. Snake Oiler
    Apr 22, 2016
    3,713
    Thanks. I wasn't sure about the huskys, but I know that my X Challenge is known to have soft splines on the shaft that would strip over time if it wasn't a good fit
    Anatoli likes this.
  12. Snake Oiler
    Apr 22, 2016
    3,713
    Thanks for reminding me about the washer
  13. MaineDrummer
    MaineDrummer Adventurer
    Nov 16, 2018
    91
    SoCal
    Can someone tell me what's the most powerful Shorai battery that will fit in the 2020 501s?
  14. Snake Oiler
    Apr 22, 2016
    3,713
    Are those Dirt Trick? If so are they really worth the extra cost?
  15. Nowwhat
    Mar 2, 2007
    8,384
    Yes and yes
    Great little company too...
    Sidehil, Thumperama and Snake Oiler like this.
  16. dogsslober
    dogsslober No neck tie, Ti neck
    Feb 10, 2009
    3,833
    Morgan Hill Ca
    On Shorai web site they give dimensions of there battery's, also when I was shopping for one for my 950 they show there standard replacement and the biggest that would fit
  17. aai
    aai Adventurer
    Jun 15, 2014
    98
    DC
    View attachment 1952917 View attachment 1952911 that's the one I installed on mine. Had to add an 1/8" of padding on the back side of it, slightly smaller than oem. The plastic battery bracket hold down didn't sit quite right so I had to bore out the hole with a round file to get the screw to grab.
    I couldn't find the specs on the oem battery just for sake of info (skyrichbattery) Regardless mine was weak, maybe due to poor setup or charge when bike was prepped. Just want to add a big shout out to Moto Minded if they are on this site. Installed mini dash to monitor voltage, relocate switches, USB ports etc.
    Ginger Beard and Snake Oiler like this.
  18. OneManWolfPack
    OneManWolfPack Been here awhile
    May 21, 2018
    214
    Calgary
    Pulled the shinko fatty off the front of my 501 (I absolutely hated this tire for the 501, horrible sidewall flex, slow numb steering) and replaced with a Pirelli MT16. The shinko was 1.5 kg (3.3 lbs) heavier, no wonder the bike felt like such a pig with it on.
    Snake Oiler and Nowwhat like this.
  19. MaineDrummer
    Nov 16, 2018
    91
    SoCal
    Thanks for the battery spec. confirmation aai!
    aai likes this.
  20. Fast1
    Aug 18, 2007
    3,807
    Do you recall the total weight of the Shinko?
