1. eNewsletter Sign Up
Husqvarna FE501S & FE350S
Discussion in 'Thumpers' started by trailrider383, Sep 11, 2014.
  1. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    8,384
    On the Ground Laughing
    Vortex is supposedly shipping the 2020 501 ECUs Friday
  2. OneManWolfPack
    OneManWolfPack Been here awhile
    May 21, 2018
    214
    Calgary
    5 kg (11 lbs) on the nose partially worn. A fresh one would be even more. IMG_4038.JPG
  3. Dirt survivor
    Dirt survivor Adventurer
    Jun 26, 2016
    94
    The lock nut for my rear brake adjusting screw came loose and my rear brake fried pretty bad. Put in new pads and rotor, but now I have very little rear brake action, is it time to rebuild or replce the caliper? 2015 501S
  4. craigt
    craigt I just wanna ride
    Oct 5, 2013
    159
    Upstate SC
    I had the same thing happen to me except I did not fry my brakes or rotor. I now clean my parts very well not just wipe them off before I Loctite them.
  5. Fast1
    Fast1 Twisted Throttle
    Aug 18, 2007
    3,790
    Bridge over Troubled Water
    I want to weigh the GoldenTyre version when I remove it and compare.
  6. Fast1
    Aug 18, 2007
    3,790
    How did the caliper piston move when you did the pad service? easily? stuck? Might just need a complete fluid change and bleed before going further. I'd start there.
  7. motodirtlover
    motodirtlover Motodirtlover
    May 20, 2004
    1,311
    Tecumseh land
    Before you pull the trigger on that battery, you may want to check out the Earth X units. Made in the USA and very robust. I've bought my last Shorai....
    keepshoveling and aai like this.
  8. OneManWolfPack
    May 21, 2018
    214
    Calgary
    Yes please do and be sure to share. After all I heard of fatty tires being the bomb I really found the Shinko to be a letdown. At speed you could move the bars a few inches and nothing would happen, just a bunch of sidewall flex. It took away all the feel in the front end. I run UHD tubes at around 12psi but then had to crank up the pressure to get rid of the marsh mellow handling feeling.
  9. aai
    aai Adventurer
    Jun 15, 2014
    98
    DC
    I was reading up on those also. This is my 3rd Shorai on different bikes and SXS and haven’t had a reason to switch brands yet. Earth X is definitely my option from what I’ve read.
  10. thejrod
    thejrod Been here awhile
    Nov 2, 2010
    700
    Arlington, WA
    I’ve tested and weighed both - the GT is almost a full 2 pounds lighter.
    Harder1 likes this.
  11. craigt
    Oct 5, 2013
    159
    Upstate SC
    That is a very significant unsprung weight difference. I have been trying to decide between the two of them and I guess that decides it for me.
  12. Dirt survivor
    Jun 26, 2016
    94
    Changed fluid several times, pistons move but not sure if they move like they should, probably time to rebuild or replace.
  13. Fast1
    Aug 18, 2007
    3,790
    Only one piston on the rear caliper.
    Looks like the parts are available. The excessive heat might have just ruined the sealing rings (#2) to hold pressure or the piston is
    distorted (#5) . You could pull them from the caliper and examine for issues.
    Thinking back a few years... I remember a friend that had a similar issue and if I remember correctly we replaced the sealing rings to resolve the poor braking.
    Ned1 likes this.
  14. thejrod
    Nov 2, 2010
    700
    Arlington, WA
    Yeah, you can feel it. Also, I got about 40 hours out of the Shinko before side knobs started to rip off. The GT is at 45 hours now with so little wear that I expect 70-80 hours out of it. It's worth the extra $30.
  15. Fast1
    Aug 18, 2007
    3,790
    Do you recall the weight of the GT? and was it new or used when weighed? I won't be removing my front GT for a while since we are in the off-season here in the upper midwest..
    Have ~3500 miles on my front GT (primarily easy dual sport use). Might have worn in the center quicker (scalloped) since I used low pressures in the rocks/roots/mud and wasn't always able to air up on short pavement sections at speeds above 65 mph.
    keepshoveling, Ned1 and Snake Oiler like this.
  16. Ned1
    Ned1 Back to bicycles
    Dec 20, 2005
    1,173
    BC/WA
    Good data on the GT vs Shinko, thanks bros. 2lbs, with the centrifugal factor is more like 8 or 10 once the wheel is spinning. Not ideal in fast, tight conditions with a lot of directional transitions. The business case for a couple wheelsets....
  17. thejrod
    Nov 2, 2010
    700
    Arlington, WA
    The GT was new, 8 lb, 12.8oz.
    The Shinko was used 40hrs, 10 lb, 8oz. (and missing a few side knobs).
    Fast1 and keepshoveling like this.
  18. Dirt survivor
    Jun 26, 2016
    94
    Many thanks, looks like the way to go!
  19. thejrod
    Nov 2, 2010
    700
    Arlington, WA
    Anyone tried the Tusk shift lever? I thought I read the Hammerhead levers strip easily. Wondering if the Tusk is the same. For $19, it's a steal compared to 75+ for OEM.
  20. Anyone
    Anyone Been here awhile Supporter
    Apr 21, 2018
    148
    Astoria oregon
    Snake Oiler likes this.
