Husqvarna FE501S & FE350S
Discussion in 'Thumpers' started by trailrider383, Sep 11, 2014.
  1. LANCIVPT
    LANCIVPT Carbon Pilot
    Jan 15, 2015
    195
    Cremona
    No I did not - no cutting required as the tail piece is a two piece assembly I.e upper and lower. I used the Sicass plate support. The tail light has a light that comes on with the number plate light and will have to double as the number plate light.
    guns_equal_freedom likes this.
  2. guns_equal_freedom
    guns_equal_freedom Long timer
    Jul 1, 2007
    7,330
    Thanks for the reply!
    LANCIVPT likes this.
  3. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off
    Apr 22, 2016
    3,606
    Pennsylvania, but living in a toy hauler full-time
    Hey folks. It's time to get new chain and sprockets. I'm still running the stock size, but was thinking about making the gal a little more dirt friendly . If I'd do a 14/48 would that still be good on the slab? And just how big can I go with the stock chain guide at the sprocket end?
  4. NVTS
    NVTS Arrivee Secteur Special Supporter
    May 18, 2006
    1,351
    Big Lick Virginia
    Roger that. My confusion stemmed from the stock size listed on RMATVMC as a 110.
    Here's what the good folks in Mattinghoffen reccomend..
    keepshoveling likes this.
  5. Snake Oiler
    Apr 22, 2016
    3,606
    Damn. I don't know if a 140 would fit in there.
  6. NVTS
    May 18, 2006
    1,351
    Big Lick Virginia
    I've got a Michelin Desert Race in there and it fits fine.
    I wouldn't put a Pirelli Scorpion Rallye however. I've got one mounted on my 950SE and that's a lot of tire to push around.
    NVTS
    Snake Oiler likes this.
  7. Sno Dawg
    Sno Dawg Long timer
    Mar 18, 2007
    2,565
    Philadelphia, PA
    Asking the experts...
    I have been looking to pick up a used 2017 - 2019 Husky FE350 and I found a nice 2017 FE350, but was wondering exactly what I should look for. It has 2,750 miles and is loaded with a Rekluse, skid plate, shark fins, rad guards and seat concepts. The owner rode it in dual sports and it looks to be clean and well kept.
    What types of things should I look for/ask about - be concerned about?
    I am a bit short on money to buy a brand new/leftover one at $8500 so that is why I am looking at a used one. I plan to use it for dual-sport rallyes, 24 hour race I do and general woods riding. I am not as fast as I used to be and now ride events to finish, not to place.
    Thanks,
    Sno Dawg
  8. Fast1
    Fast1 Twisted Throttle
    Aug 18, 2007
    3,590
    Bridge over Troubled Water
    I noticed that incorrect size previously at RMATV also..
  9. Fast1
    Aug 18, 2007
    3,590
    Any suggestions on a source for the Michelin Desert with good pricing? I've worn my Desert out and am looking for a replacement.
  10. OneManWolfPack
    OneManWolfPack Been here awhile
    May 21, 2018
    201
    Calgary
    The stock Conti is undersized at 120/90-18. FWIW Michelin uses their own sizing so a 140 Michelin is usually closer to a 130.
  11. Fast1
    Aug 18, 2007
    3,590
    Not the 140 Michelin Desert..
    Yeti2ride and Snake Oiler like this.
  12. Snake Oiler
    Apr 22, 2016
    3,606
    Really. You are running a $200 rear tire? I'm living life wrong I guess
  13. OneManWolfPack
    May 21, 2018
    201
    Calgary
    Kenda Trackmaster II
  14. OneManWolfPack
    May 21, 2018
    201
    Calgary
    I am running 13:48 on both my wheel sets. For technical single track I would drop 13:50 to be perfect. 13:48 is still fine on the pavement. Interesting tip is reversing the spacer blocks on the rear axle is exactly two on the rear sprocket. In the future I may run 13:46 for the dual sport set and 13:48 for the knobbies. No need to mess with the adjustment bolts.
  15. Snake Oiler
    Apr 22, 2016
    3,606
    Hey thanks for the input. I was looking at the Dirt Tricks sprocket and they aren't available in the 46 that I can see. The only reason I was considering them was they were so talked up on the thread in the past. I've never really had a problem with chains and sprockets wear, but I never really pushed it hard. But since I'm in the desert more now and have a power house of bike I was wondering if it would be best if I upgraded to them. That's an interesting bit of information about the blocks. I'll definitely store that thought.
  16. guns_equal_freedom
    Jul 1, 2007
    7,330
    I changed the rear sprocket to a 50 tooth sprocket, so it's 14/50.
    I also bought a 13 tooth front sprocket just in case I want to mess with the gearing using the 48 tooth sprocket.
    14/48 = 3.43
    14/50 = 3.57
    13/48 = 3.69
    13/50 = 3.85
  17. OneManWolfPack
    May 21, 2018
    201
    Calgary
    I have been running stealth supersprox and very happy with them. Strike the balance between light and durable.
  18. Snake Oiler
    Apr 22, 2016
    3,606
    That was my first choice to be honest.
  19. Fast1
    Aug 18, 2007
    3,590
    I swap in a 13, 14, 15 with a rear 48 and use the same chain. Covers everything from single track technical to those rides you run at 60mph+. Sprockets, chains and brake pads wear quickly if you ride a lot in mud.
    ha... I've got mountain bike tires that ran close to $100/ea..
    I need a rear tire that will last at least 3500 miles but am open to try alternatives besides a Michelin Desert. Alternatives such as Dunlop 908RR, Motoz Rallyz or a Mefo Super Explorer.. the Desert seems to be the most dirt offroad worthy of that group though.
    I got 3500 miles out of the Goldentyre front fatty last year. Will stick with that for front replacement.
    If you are just riding super technical or single track I'd consider a narrower tire than 140 on the back like a 110 or 120 Motoz Arena Hybrid Gummy.
    MaineDrummer likes this.
  20. Snake Oiler
    Apr 22, 2016
    3,606
    No I'm not doing much if any technical stuff. But being not the best rider I like all the help I can get. I'm a fan of the MotoZ tires. But the Kenda Parker DT has worked pretty well. Be to try something different I just mounted a MotoZ Tractionator IT on the rear with the tubliss to try. Really haven't nailed down a front for the 501 yet. At present I went cheap with a Tusk, and I'll say it seems harder tread than I'd like. But time will tell.
