Husqvarna FE501S & FE350S
Discussion in 'Thumpers' started by trailrider383, Sep 11, 2014.
  1. meltdown350
    meltdown350 Adventurer
    Feb 2, 2013
    65
    East Troy, WI
    I'm also curious.
    Because of the straight fitting coming out of the master cylinder I would have to make an immediate hard 90 degree turn to get down the right fork tube.
    Why the F couldn't they just use a banjo bolt? Ugh...
  2. Baroquenride
    Baroquenride Everyone dies, but not everyone truly lives.
    Apr 10, 2011
    5,545
    Clark Co, Wa
  3. AlexSonoma
    AlexSonoma Adventurer
    Jul 12, 2011
    58
    Golden, CO
    Just picked up a used FE501S. Did an oil change, oil was black and looked like the previous owner hadn't changed it in a while. Still, no metal specs on the magnet. Put in new oil, changed the filter, started it up, idled fine, oil level was fine, but when I put it into gear it stalled and then started smoking on startup which took a few tries. I turned it off, noticed the oil level was low - still in the circle in the window but towards the bottom. So I topped it off, started up no problem and then it rode fine without any issues. Any ideas what the issue might be?
  4. spaceman_spiff
    spaceman_spiff Long timer
    Jul 24, 2008
    2,655
    Santa Cruz, CA
    I wish I could! I work in AK during the summer and have to leave the bike behind. The thread linked above shows what to do. I also believe "the rolling hobo" did his 500 exc like this
    Snake Oiler likes this.
  5. OneManWolfPack
    OneManWolfPack Been here awhile
    May 21, 2018
    729
    Calgary
    Did you try to start it in gear the first time when it started smoking? Smoke from exhaust?
  6. AlexSonoma
    Jul 12, 2011
    58
    Golden, CO
    Yes, from the exhaust. I don't think the bike was in gear when it started smoking but since it had just stalled when I shifted, maybe I didn't put it back into neutral.
  7. renogeorge
    renogeorge Let's ride!! Supporter
    Apr 7, 2007
    6,922
    Reno
    Did you have bike laid over on its side? It is possible for oil to run through breather line into air box, saturating filter and causing smoke. FWIW
  8. OneManWolfPack
    May 21, 2018
    729
    Calgary
    Saturated filter is a good place to start. My old 525 would lay down a temporary smoke screen if it got upended. The oil drop is probably normal. Did you prefill the oil filter cavity when you did the change?
  9. AlexSonoma
    Jul 12, 2011
    58
    Golden, CO
    i did lay down the bike to prefill the oil filter cavity.
  10. OneManWolfPack
    May 21, 2018
    729
    Calgary
    ok. no idea on the oil drop perhaps an air pocket that worked itself out. How is it running now? What year is it and was it desmogged?
  11. AlexSonoma
    Jul 12, 2011
    58
    Golden, CO
    It is a 2020 and no it is not desmogged. Seems to be running perfectly now. No smoke, no clutch issues.
  12. OneManWolfPack
    May 21, 2018
    729
    Calgary
    Ride on. As the other response noted likely oil got into the intake tract. Free smoke screen. Is desmogging still a thing on the S's?
    AlexSonoma likes this.
  13. XRYoda
    XRYoda n00b
    Mar 30, 2016
    3
    Portland
    Question for you folks.. I have a low hour 2017 Husky 501 with a JD tuner and a FMF 4.1 can. The bike runs great and I love it. I have read that the 2017 FE501 has about a point lower compression, probably due to emissions. I would like to raise the compression up about a point. I found a mention on a forum that the 501 has used a thicker head gasket to lower the compression, but that is the only mention that I have found in the forums. What are my options to raise it up? Piston, thinner head gasket? I am headed out tomorrow morning to do a few days of riding (Giant Loop organized dual sport ride in Oregon, I cant wait!) so I will be away from my computer for a few days after tonight for responses...
    Anyone likes this.
  14. Fast1
    Fast1 Twisted Throttle
    Aug 18, 2007
    5,325
    Bridge over Troubled Water
    Instead of playing with a minor compression increase, I'd get rid of the JD tuner and install an aftermarket ECU with both fuel and timing changes (and adjust an increase in the rev limiter) for more performance.
    Bitingdog and NoelJ like this.
  15. Anyone
    Anyone Been here awhile Supporter
    Apr 21, 2018
    546
    Astoria oregon
    @Fast1 my bike came with a jd tuner. I have no reference point to what the benefits of a after market ecu. what are the improvements over the jd?
    Fast1 likes this.
  16. Fast1
    Aug 18, 2007
    5,325
    Improved fueling throughout the entire rpm range, especially with an aftermarket exhaust and the timing is advanced at certain rpm ranges which dramatically improves acceleration. You can also add a map switch that detunes output for mud/single track. Will be night and day over the JD tuner. There is also an option to increase the rev limiter setting.
    I'd suggest looking here https://tacomoto.co/collections/engine-management
    If I hadn't had the Euro unrestricted map installed on my ECU when my moto was new, I'd be all over an aftermarket ECU to get as good or better performance.
    Bitingdog and Anyone like this.
  17. Fast1
    Aug 18, 2007
    5,325
    Got out for the first ride of the year on my 501 this late spring in the upper midwest and got to test out my Zumo XT. Chose an easy 180 mile dual sport ride that had near 14,000 of elevation change. The route is used annually for this 185 mile gravel bike race. I'd make about 50 miles on my pedal bike if I was lucky.
    https://grvldrma.com/
    The route here: https://ridewithgps.com/routes/35309655
  18. Fast1
    Aug 18, 2007
    5,325
    Got a delivery today.. Redline Synthetic Like Water Suspension fluid
    Seems I have a fork fluid change coming up soon..
    Bitingdog, Snake Oiler and Anyone like this.
  19. OneManWolfPack
    May 21, 2018
    729
    Calgary
    So this is lighter than a 2.5W?
  20. Fast1
    Aug 18, 2007
    5,325
    It is lighter than Motorex 2.5w and all others at two different temperatures.. see chart and link below the chart for a complete understanding
    thanks to @renogeorge for bringing up these articles and reminding me what I used back in 2012 for my TE630 fork fluid change. I did find a partial container of Redline (like water) still in the cabinet from back then..
    https://advrider.com/f/threads/husqvarna-fe501s-fe350s.1009100/page-1324#post-42415077
