Husqvarna FE501S & FE350S
Discussion in 'Thumpers' started by trailrider383, Sep 11, 2014.
  1. Anyone
    Anyone Been here awhile Supporter
    Apr 21, 2018
    543
    Astoria oregon
    Glad to hear it Was something simple.
  2. AMCJEEP
    AMCJEEP Been here awhile
    Apr 27, 2009
    362
    CT
    Glad you figured it out. But just to keep in your head if funky stuff pops up again. I have also had things like this happen when I had a bad/ loose ground.
  3. Fast1
    Fast1 Twisted Throttle
    Aug 18, 2007
    5,287
    Bridge over Troubled Water
    Pulled my old 4cs forks apart today to do a simple fluid change with the Redline synthetic fork oil (like water).
    Everything was going smoothly until during filling the first fork from the bottom and I noticed that oil was leaking out of the dampener rod from the oil separator o-ring when upside down.. Seems like it is known problem from extended use.
    Decided to give Stillwell Performance a call to see if they had the seals and could just replace them if I sent
    the removed dampeners in.. Seems like it will be a rather painless cost and quick turn around.
    What I thought was going to be a quick fluid change... instead wasted one container of Redline fluid.. Seems my 4cs were turning into open chamber forks with that seal leaking.
    The oil separator seal sits around the dampener rod right above the area located near the outer blue o-ring seal. Will get the blue O-ring changed out at the same time. Didn't have the special tools (dampener vice clamp and pics) or more importantly the oil separator o-ring so sent the dampeners off.
  4. OneManWolfPack
    OneManWolfPack Been here awhile
    May 21, 2018
    710
    Calgary
    Well not as fancy as the fork blow up but here is a picture of a failed Magura clutch master piston seal (top piston). Service time 104 hours till failure. Better than the slave I suppose. Good riddance Magura on the new bikes.
    RTWstare and Rot Box like this.
  5. Comanche13
    Comanche13 Been here awhile Supporter
    Mar 13, 2016
    244
    Campbell River
    No wolfman not as fancy but still good quality with a name like Fast hard to keep up to his tech info plus it looks like he spanked back 3 beer while doing it , the empty beer bottles in the picture , the impedimy of cool good luck with your slave update you will be cool once you get out riding
  6. Fast1
    Aug 18, 2007
    5,287
    Fork Beer!
    RTWstare likes this.
  7. Comanche13
    Mar 13, 2016
    244
    Campbell River
  8. Rot Box
    Rot Box Diesel and Dust
    Oct 31, 2010
    463
    Smithfield Utah
    Not a difficult fix just annoying as hell I can imagine. Hope you get it sorted keep us posted. I’m in constant fear that my Magura components are going to fail based off everything I’ve seen on the forums. Never did get a clear answer if the 20+ bikes are any better when it comes to master/slave cylinders
  9. new2adv
    new2adv Converting gas into wheelies since 1974
    Nov 5, 2018
    1,239
    Great White North
    I think it's a total crap shoot with Magura. My current bike has been going for 6 years with no problem. Previous bike failed in less than a year. Bike before that was 6 years old when the slave went out.
  10. matloik
    matloik kludge Supporter
    May 23, 2008
    2,537
    White Salmon WA
    And is the crap shoot statistically any worse than a lot of components? Failures certainly get inordinately amplified on the internet. I still have the Magura on my MY18 501. Though the hubbub did cause me to purchase a spare backup last year.
    PDXR650 likes this.
  11. Fast1
    Aug 18, 2007
    5,287
    What year did Husky switch to a Magura system?
    Seems 2014 had Brembo right from the factory and confirm mine has performed flawlessly for 306 hours and a bit over 10,000 miles.
    Anyone likes this.
  12. new2adv
    Nov 5, 2018
    1,239
    Great White North
    I can only compare Magura against Brembo. 3 Magura failures vs 1 on Brembo.
  13. OneManWolfPack
    May 21, 2018
    710
    Calgary
    Magura clutches were on the original RFS bikes albeit with mineral oil. The swollen seal in my picture confirms that Magura is/was struggling with seals that are compatible with brake fluid. Simple fix but the OEM Magura rebuild kit was $150 Cdn from the dealer which is crazy for two rubber seals, a plastic washer and a tiny piston. They should be providing them for free with an apology for manufacturing crap. I went with the all balls kit so now my system is all ballz / oberon.
    new2adv and Rot Box like this.
  14. ztrab
    ztrab Long timer
    Jan 13, 2006
    1,252
    Tucson, Az
    Interesting. I just converted my CS into open chamber. About 5K on them and seem to work well for me. '15 501 FE
    Doc Sarvis likes this.
  15. Fast1
    Aug 18, 2007
    5,287
    Did you purchase and install a kit conversion yourself or have it done by a company?
    Most significant changes you noticed after the conversion?
  16. Doc Sarvis
    Doc Sarvis Advent-ia before dementia Supporter
    Dec 11, 2015
    539
    Carp Ca
    I sent my 4CS forks to ZipTy and it's worlds better. I think it was $300? Open conversion with new base valves.
  17. Finnyfire
    Finnyfire Jedi Master
    Nov 27, 2013
    425
    Big sky country
  18. OneManWolfPack
    May 21, 2018
    710
    Calgary
    you running stubby fuel line with check valve off your gas cap?
  19. Finnyfire
    Nov 27, 2013
    425
    Big sky country
    Yes. I was. Stubby line with check Valve end cap. I have since removed the check ball from the cap but haven’t had a chance to test it yet.
  20. OneManWolfPack
    May 21, 2018
    710
    Calgary
    I had to remove mine. For some reason my 2 strokes are ok with it but not the 4stroke with big tank. Perhaps too much volume to vent. This pressurizes the tank which theoretically should reduce boiling. Higher elevations will also make the tank more prone to boiling. If tuned stock then a lean tune will also make things hot.
