Husqvarna FE501S & FE350S
Discussion in 'Thumpers' started by trailrider383, Sep 11, 2014.
  1. Fast1
    Fast1 Twisted Throttle
    Aug 18, 2007
    5,287
    Bridge over Troubled Water
    Besides the impact of a non-balanced wheel .. if one of the bearings was not seated to the correct depth in the hub center bore... side load could jeopardize bearing longevity too, if I am understating the assembly correctly.
    Good discussion with lots of variables that impact bearing longevity.
    empedrado likes this.
  2. NicKel78
    NicKel78 Been here awhile
    Jun 1, 2020
    454
    Kerrville, TX
    Does someone by chance have the bearing number for the OEM bearings available?
    There are a lot of great points brought up here in regards to seals, bushings, etc. KTM has done a pretty good job of spec’ing high quality components from the start. There are some good bearing brands out there also but it seems like many of the aftermarket all in one kits are probably Chinese crap. All-Balls comes to mind in that category. I likely impossible to determine but it would be interesting to see a comparison of failures from OEM (or equivalent quality) vs. the no-name stuff. I would suspect there is a significant difference.
    Same goes for seals. Possibly an even bigger difference in quality on the seals compared to bearings just because the compounds used are trickier for the Chinese to get right than hardening and grinding bearing steel these days. Elastomer is not just elastomer but they haven’t figured that out yet. I have seen SKF seals with lots of hours on them be in great condition and brand new Chinese seals come out of the package already hardened up and unable to seal.
  3. Fast1
    Aug 18, 2007
    5,287
  4. OneManWolfPack
    OneManWolfPack Been here awhile
    May 21, 2018
    711
    Calgary
    The Husky/KTM/Husaberg? lol packaged bearings I have in my spares box are NSK (Japanese) and are a quality manufacturer.
    Anyone and Bitingdog like this.
  5. NicKel78
    Jun 1, 2020
    454
    Kerrville, TX
  6. OneManWolfPack
    May 21, 2018
    711
    Calgary
    Rears 6005 2RS
    Fronts 6906 2RS
    BogeyMan likes this.
  7. NicKel78
    Jun 1, 2020
    454
    Kerrville, TX
  8. Bitingdog
    Bitingdog That's not my dog
    Apr 2, 2015
    19,390
    The bad side of the PNW
  9. Takataka
    Takataka Been here awhile
    Sep 26, 2014
    803
    NZ
    The inner races shouldn't load much if the spacer tube is in good condition. Perhaps if you over torque the wheel nut it will squash the spacer though.
    Is the spacer alloy (I can't remember)?
  10. RTWstare
    RTWstare Dismissed! Supporter
    Apr 26, 2017
    94
    New Mexico
    Horn relocation on my 2020 FE501;
    Want mine up out of the mud from the front tire, and generally out of harm’s way. Possibly not quite as loud in this location??, but sounds the same to my ears.
    Used the OEM bracket, slightly hand-bent to suit, and rounded/deburred a few of its corners. Then added a small welded triangular tab with a pressed in 1/8” pin (mated to a 1/8” newly drilled frame hole) to keep the now horizontal horn and bracket from wanting to rotate away from the chosen location. Also fashioned an aluminum spacer to place the bracket a hare’s breath away from the frame’s paint when fully installed. The mounting screw head is low-profile to avoid its touching the radiator. That screws into an M6 compression-nut which was installed directly into an existing frame hole. Note the valve cover barely touches/flexes the horn bracket during removal for valve clearance checks, so I chose to loctite the bracket screw, as there’s no need to remove it during any routine maintenance.
    All fits without interference under an IMS 4.7 gallon tank. Horn’s “bell” doesn’t touch anything around it so nothing mutes it, and the horn aims directly out a fuel tank air vent opening to the right.
    FCEB2CC7-7B01-4144-81A6-FE56739C0C12.jpeg 686FBFA4-4B02-4AB7-9E7C-0F008AC25FB3.jpeg 99239796-868F-45A5-BE72-A069E3305CB5.jpeg 56FD20F5-DD7D-47D6-9831-EDE56D16184C.jpeg
    Bitingdog, Anyone and NicKel78 like this.
  11. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    2,256
    USA
    You get a Cerakote kit for Christmas?
    Old_Fat_and_Slow and RTWstare like this.
  12. RTWstare
    Apr 26, 2017
    94
    New Mexico
    Disclaimer;
    The tank came that color, it's not Cerakoted.
    Project bike, not finished yet
    LANCIVPT and Gaup like this.
  13. Doc Sarvis
    Doc Sarvis Advent-ia before dementia Supporter
    Dec 11, 2015
    542
    Carp Ca
    I will not sleep until I see the color way on the mysterious missing chain.
  14. OneManWolfPack
    May 21, 2018
    711
    Calgary
    There is a lot going on in that picture.
    Baroquenride and RTWstare like this.
  15. timeOday
    timeOday Long timer
    Jun 20, 2008
    4,286
    New Mexico
    Even the shock spring is painted!?
    Is that a carbon-fiber header guard, painted beige!?
    You just blew my mind dude.
    Mrstig likes this.
  16. Gaup
    Gaup Adventurer
    Mar 26, 2007
    34
    Northen Sweden
    The Renazco seat looks god... And same Clake as i have.. nice bike..
    RTWstare likes this.
  17. Fast1
    Aug 18, 2007
    5,287
    what crawled up here?
    Bitingdog and Baroquenride like this.
  18. RTWstare
    Apr 26, 2017
    94
    New Mexico
    A piece from a toy dinosaur set dad gave me when I was 4 or 5, that’s been zip-tied to nearly every dual sport throttle cable I’ve owned…
    and in case anyone was curious, that’s a McCruise controller next to the throttle.
    Anyone and Fast1 like this.
  19. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    2,256
    USA
    "Project bike, not finished yet".
    I'm trying to imagine. Guess I'll just wait! :rofl
    Baroquenride likes this.
  20. Fast1
    Aug 18, 2007
    5,287
    Like to know your opinion of that device after you get some time testing and using it.
    Who makes the silver bar clamp that you have mounted?
