Husqvarna FE501S & FE350S
Discussion in 'Thumpers' started by trailrider383, Sep 11, 2014.
  1. Anatoli
    Anatoli Pale rider
    Nov 6, 2016
    3,622
    Skagit Valley, Washington
    40481197-34B2-4685-BA89-6554A19CDA1F.jpeg Friend Nic bought his 501 a year ago. Now he is riding ST like this. Sticky tires and TuBliss really make a difference in these slick winter conditions.
  2. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off Supporter
    Apr 22, 2016
    7,433
    Pennsylvania, but living in a toy hauler full-time
    I have a question. You say headlight, are you referring to the bulb? And if so which number bulb? I have two of the cyclops LED bulbs laying around back home in my basement for an old lights I had in a lynx fairing. Maybe they can work for the new bike.
  3. mo_rider
    mo_rider the dude abides Supporter
    Nov 29, 2016
    436
    Yeah sorry...headlight led bulb.
    https://www.cyclopsadventuresports....-Newer-Dirt-Bike-LED-Headlight-Kit_p_127.html
    Item: KTMDB-H4-XCW
    (I have a non-s 2016 FE501)
    Snake Oiler likes this.
  4. Snake Oiler
    Apr 22, 2016
    7,433
    Ok. Thanks. Those are different than the ones I have . I figure that my 17 probably has the same as yours. I don't think they changed the bulb type. But who's know.
  5. Aviatordoc
    Aviatordoc Hooligan extraordinaire
    Dec 25, 2008
    1,630
    Chattanooga, TN
    I may be wrong here, but the S bikes have Hi and Low to be street legal.
  6. Snake Oiler
    Apr 22, 2016
    7,433
    You are correct. My mistake.
  7. mo_rider
    Nov 29, 2016
    436
    That bulb has a high and low too. I'm actually unsure what the difference is between fes and non s in the cyclops versions. I hooked it up to my high low switch (tusk Enduro lighting kit) and it works great. May want to email them and see what the diff is. Either way, great bulb so far though I haven't really been able to ride test it yet.
  8. Grayjet
    Grayjet Ride on!
    Jun 14, 2008
    651
    Va Beach
    All of today's take offs:
    The smog stuff came out pretty easily, but I chose to leave the brass fitting in the intake for now with a vacuum cap on it. I will fish the charcoal canister out of the frame tube one of these days, but I suppose that will require replacing the exhaust gasket. (Or does it? Anyone just reuse the one in there?)
    Weird thing, though. After getting the bike back together, I took it for a spin, and it seemed more sluggish than before. It was slow to respond to the throttle. Removing this stuff shouldn't have affected performance at all, since the Vortex was in there (SAS not operating) and the air injection valve was blocked before I removed this stuff. It was below freezing here today, but I doubt that makes a difference. Any ideas?
  9. SoilSampleDave
    SoilSampleDave Dr. Zaius was right!
    Jan 21, 2005
    12,257
    The Delta Ghetto, GA (aka PTC)
    I think it’s a good idea to leave the brass fitting and just seal it off. Sometimes the ktm loctite is too strong and they snap off when trying to unscrew it. There is really no reason to remove the charcoal canister; it weighs next to nothing. SAS/air injection has zero effect on performance, just popping in the exhaust. As far as the performance, go back through and check every connection/connector you touched. Did you have the fuel line quick connect apart? Pull it back apart and reconnect it to make sure it is fully seated. I assume all the adjustment dials on the Vortex are still sitting at zero or close to it?
    WIsixfitty likes this.
  10. Grayjet
    Grayjet Ride on!
    Jun 14, 2008
    651
    Va Beach
    I did have the tank off to remove the air injection valve. I will reconnect it as you suggested. Hopefully it’s that easy. The Vortex dials are all at zero (but I will recheck that as well).
  11. RideAbout
    RideAbout Mentally Retired
    May 3, 2004
    2,947
    Oregon
    Lo, mid and hi should be at 5 to start. X10 at 0 is the full power map.
  12. Grayjet
    Grayjet Ride on!
    Jun 14, 2008
    651
    Va Beach
    Ah, yes, you are correct. The fuel trim settings are at 5, and the map is at 0, the factory settings. Thanks for the correction.
  13. SoilSampleDave
    Jan 21, 2005
    12,257
    I just wanted to be sure they weren’t all turned all the way up; I doubt it would cause what you are seeing, but always rule out what you can. I didn’t notice much difference on mine between 0 and 5, except going to 5 made the bike less snatchy at low speed. Re-seat the fuel line quick connect yet?
  14. Grayjet
    Grayjet Ride on!
    Jun 14, 2008
    651
    Va Beach
    I did. All seemed well there. There is still a slight hesitation off idle. Maybe it’s because the ambient temps are below freezing. It’s throwing off my timing for slow speed stuff like jumping up little curbs.
  15. SoilSampleDave
    Jan 21, 2005
    12,257
    Did you try turning your idle up? What my ear thinks is a good idle speed for these bikes is a little too low. Also, the end cap looks different on your newer bike. Is there still a screen you can remove right at the end?
  16. avconnect
    avconnect Long timer
    Apr 22, 2012
    1,170
    Salt Lake City
    Remove the reed cage in the air box. That will make a difference.
  17. Grayjet
    Grayjet Ride on!
    Jun 14, 2008
    651
    Va Beach
    I have removed the reed cage, which definitely made a difference in performance. Unintentional wheelies in 3rd gear! I also turned up the idle speed. The endcap is a KTM&Husky endcap with a USFS approved spark arrestor and a ‘quiet insert.’ The bike is not loud at all, which is great.
    I rode the bike after those mods, and it was fantastic. The hesitation off idle did not occur until after I pulled the emissions crap off the bike. It shouldn’t have made a difference to performance, so that may simply be coincidental and not causal. The only other thing that changed as far as I can figure is the ambient air temp. It’s been below freezing for a few days here. There is an ambient air sensor in the intake. I don’t know if that would cause the hesitation or not.
  18. thejrod
    thejrod Long timer
    Nov 2, 2010
    1,120
    Arlington, WA
    I finally installed the Cyclops Ultra on my 350.
    The Cyclops bulb eliminates the parking light, so I need to find a way to plug the hole. The beam pattern is still the shitty KTM pattern - yes it does maintain the stock cutoff though, if that's important to you. It is bright, but not nearly as much as I was expecting from 4 XHP50s (which is entirely due to the optics/reflector, not Cyclops' fault).
    Another issue is the rats nest of wiring behind the headlight mask. This is a weak point of KTMs in general, but not helped by my addition of heated grips and now the Cyclops with it's driver module.
  19. 98940
    98940 Been here awhile
    Oct 9, 2006
    371
    NY USA
    GREAT ADVICE, DAVE. The pain is very real, folks.
    SoilSampleDave and Snake Oiler like this.
  20. SoilSampleDave
    Jan 21, 2005
    12,257
    Yup. Broke off one on a 690, they get rubber caps now.
