Husqvarna TE-610 Owners Sign In Thread.
Discussion in 'Thumpers' started by buffallodan, Aug 3, 2006.
  1. kirbybikes
    kirbybikes Been here awhile
    Apr 13, 2010
    155
    I bought my R/R from a bike breaker in Edmonton. It was actually for some kind of side by side that blew the motor or stolen with only about 30 hrs for about $20. All the part numbers matched up exactly. I mounted mine in a similar location to Bob just used adel clamps instead of steel tywrap. I think the problem with the stock regulator is how it deals with the excess voltage (converted to heat) running at max., best described in Bobs thread.
    BLucare likes this.
  2. GHO100
    GHO100 George
    Apr 7, 2009
    1,643
    Queens, NYC
    See below:
    That's both ends of the 3 yellow wire connector that are part of the harness. I ended up cutting all of these off, and replacing with new connectors, but you can clearly see the heat cycle damage. Hard insulation, discolored, and close to burnt.
    With any of these, resistance build up would be high enough to cause poor connection, no recharging, battery drain, and likely set myself on fire at some point.
    I have yet to do another test ride, but hopefully this week.
    Check your wires!!
  3. Gian
    Gian dreamer
    Oct 19, 2008
    2,344
    north east of Italy
    Is it normal on my 610 '09 I can't use the 6th gear under 80 kmh? Stock sprockets, just changed along with the chain of course... and about this, the old ones only had 13000km :(
  4. Yossarian™
    Yossarian™ Deputy Cultural Attaché
    Jul 9, 2007
    12,639
    the 'Ha
    Can't use 6th as in "it has no pulling power" or that you cannot physically shift into 6th? If the latter, then there is an issue.
  5. OVERLANDLLAMA
    OVERLANDLLAMA Adventurer
    Sep 21, 2017
    16
    Colorado Springs, CO
    822A9413-6389-407D-9BFE-2382F3F92182.jpeg This 610 is now Maryland re-inspection ready as the final part (chain guard arrived on Saturday from Hall’s) is in place. Also had to replace front tire, brake/tag light, and add back side deflectors. I replaced all of the blinkers with some numbers from Baja Designs. With a new grease zerk, also from Halls, was able to add some much needed grease to the back pivot point... kind of scary how much it took. Back tire gets replaced this weekend. Will be nice to finally get this thing registered and on some trails. Hope you all had a great weekend.
    BLucare likes this.
  6. Gian
    Gian dreamer
    Oct 19, 2008
    2,344
    north east of Italy
    No problem to shift into 6th luckily, it's just that under 80 kmh there's not enough pulling power and the bike is jerking (sorry can't find maybe the right translation!)
  7. Yossarian™
    Jul 9, 2007
    12,639
    the 'Ha
    Understood. I went to a 47 tooth rear, if I recall correctly, and it's been a much better overall drive ratio.
  8. Huskyfatman
    Huskyfatman Stinky Wizzleteats
    Oct 23, 2007
    2,814
    Destroying skid plates
    +1, I like 15:47 for dual sport, and for off road duty, I’ll just slap a 14 on the front.
  9. C.Hensley
    C.Hensley Been here awhile
    Jul 15, 2015
    365
    Dirty Jersey
  10. BLucare
    BLucare What could possibly go wrong?
    Oct 6, 2016
    2,537
    Green Bay, Wisconsin
    ^ I would agree with Hensley. 6th gear is best above 100 km/h.
  11. ned37
    ned37 Been here awhile
    Oct 29, 2007
    350
    verde valley, az
    yep. bike doesnt like 6th gear below 50mph (80kmh)
  12. Gian
    Gian dreamer
    Oct 19, 2008
    2,344
    north east of Italy
    I can imagine the 47 sprocket is much better, but with the 45 at 100 kmh I'm already at 4400 rpm, with the 47 would be around 5000? Maybe too much for long highway transfers
  13. Gian
    Gian dreamer
    Oct 19, 2008
    2,344
    north east of Italy
    Last ride was with a friend on a 630, that engine works completely different, much closer to the Ajp PR7 one. I tried offroad so no idea if you can stay under 80kmh in 6th, with the Ajp PR7 absolutely was, and it was the "racing" type I had the chance to ride. For the kind of use I do, a 630 engine on my 610 would be great (the 630 is too low and soft, suspension talking, but the double exhaust is way less noisy that mine, which is a stock one).
  14. BLucare
    Oct 6, 2016
    2,537
    I believe the AJP PR7 uses the exact same 600cc engine as the TE630, so it would make sense that they felt similar. The PR7 (and the SWM SuperDual models) are very nice continuations of the old Italian Husqvarnas. I hope they do well here in the United States :thumb
    Gian likes this.
  15. Norman Foley
    Norman Foley Devotee of the Husqvarna Supporter
    Mar 20, 2004
    3,833
    New York... The Finger Lakes
    I just brought my '03 TE610E back to life, after a 3 year slumber. I bought the bike new in '04 and have always fought with a fuel siphoning issue on the Dell'Orto carb. Friend found a used carb at a swap meet, We gave it an ultrasonic cleaning and swapped the jetting and needle over..... all good! The old 610E is just slighty more street biased than the later 610, but a great bike.
    thn, Huskyfatman, rsl47m and 2 others like this.
  16. Huskyfatman
    Oct 23, 2007
    2,814
    Looks great, but you put the kicker on the wrong side!:ksteve
    You oughta post over at the older thread too, now than Cafehusky is MIA.
    https://advrider.com/f/threads/year-2000-era-husqvarna-te-610-info-thread.406358/page-47
    Scratch that CH is back up!:ricky
  17. Yossarian™
    Jul 9, 2007
    12,639
    the 'Ha
    Glad that CafeHusky is still going. I never would have met up with other Husky owners to do my Baja trip 10 years ago without it.
  18. Finnyfire
    Finnyfire Jedi Master
    Nov 27, 2013
    282
    Big sky country
    C7D41034-F2B5-42D3-98EF-BFE8008F299A.jpeg 61933D10-5428-45F7-91DB-5F4A6D00B315.jpeg Was finally able to get out and give the bike a decent flogging. Been a while since I have posted but shamefully it’s been a long while since I have been able to ride. The bike didn’t skip a beat. Handled superbly in some pretty gnarly stuff. Subframe stayed intact and the bike felt great on the single track.
    rsl47m, BLucare and Gian like this.
  19. motometal
    motometal i like motorcycles
    Aug 19, 2007
    4,310
    Baja, Motorcycle Heaven
    Have been thinking about replacing ‘07 (had since new) with a 701 or 500 but the 701 has suspect handling and the 500, odd 5th gear and $$$ to get it to run “right”. People hate carbs but I threw a $100 jd kit in the te610 when new and never looked back.
    rsl47m and BLucare like this.
  20. 1 wheel peel
    1 wheel peel Been here awhile
    Jan 14, 2010
    387
    East Texas
