    Dismiss Notice
Husqvarna TE630
Discussion in 'Thumpers' started by Tagati, Sep 18, 2009.
  1. Rogue_Ryder
    Rogue_Ryder
    Dec 8, 2005
    8,346
    Pinewood Springs, Colorado
    Not really sure how to test it without a Multimeter. If there's a Supercheap anywhere near you, you could stop in and see if they'd loan you one or buy one. I do know there's a big fully stocked supercheap in Alice Springs, but that could be 1000+km away from you (there's also a couple bike shops there). Maybe if you're real lucky and your near a Cattle Station they might have one you could ask to use. Probably the best you can do is inspect all the wiring for any damaged connectors or insulation and make sure everything is tight and pray the RR & Stator are good. I've seen failed RRs on Hondas that wiped out the battery when the failures happened the batteries were super hot and boiling the acid out of them (overcharging), the stator could also be the culprit (didn't charge the battery), but no way to know without doing some troubleshooting with a multimeter.
    Here's a comprehensive video on how to test a Regulator/Rectifier.
    check the stator:
    Rotax655 and WILL_S like this.
  2. auto
    auto Been here awhile
    Feb 6, 2007
    506
    south jersey
    Looking on ebay I see a lot of inexpensive Chinese mosfet regulators.Do they hold up? Even if you bought two it's still cheaper than a OEM regulator.Anyone try one?
  3. WILL_S
    WILL_S OUTLAW POSTIE 001
    Feb 16, 2009
    3,465
    goodly satisfactory place, qld
    Bit of a update
    Riding with multimeter hooked into a wired charge port
    13.1-13.2 v
    Idle 13.8-13.9
    Headlight hi beam on 13.04
    +Light bar 12.98v
    Stator unplugged and measured at the reg plug idle 25v above idle 60v
    Does this sound reg related or stator ?
  4. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    8,353
    Is it down now? Can't get to it
  5. DYNOBOB
    DYNOBOB lucky dog Supporter
    Dec 15, 2008
    2,366
    Cincinnati, OH
    Is this with a new battery installed?
    Voltages seem pretty normal for a stock charging system with a good battery. I run about 1 volt higher then that since swapping to the Yam regulator and eliminating the stator harness plug above the engine. You might check that plug for melting or corrosion. Odds are you just had a battery die. Actual failures of stators/regulators on TE630 have been rare.
  6. WILL_S
    Feb 16, 2009
    3,465
    Yes new battery with those readings
    The one that died was put in new in the morning did about 300km and about 7 starts then flat and not taking charge.
    Right now am sitting at 500km to get it checked or 700km the other way to where I want to be but no easy recovery if it dies.
  7. KayDubbya
    KayDubbya Been here awhile
    Jul 26, 2014
    469
    @WILL_S the wires that come of the stator are run too close to the exhaust. Check them for melted insulation. When they short out it will cause the battery to stop charging.
  8. DYNOBOB
    Dec 15, 2008
    2,366
    Cincinnati, OH
    How old was the battery before the one that was put in and died in one day? What symptoms did it show?
    1. Yes, I'd check the wires near the header.
    2. Check the stator wire plug above the engine.
    3. Check the plug at the regulator for signs of heat/corrosion.
    4. Look at every fuse.
  9. Rotax655
    Rotax655 Aprilia World Meeting
    Dec 10, 2009
    681
    Cerveteri (Rome)
    for correct recharging of the battery, about 13.8-14.5 volts are required at 4000 rpm with the lights on. otherwise the battery does not last long. monitors all electrical connections of the generator near the exhaust manifolds and the voltage regulator
    WILL_S likes this.
  10. WILL_S
    Feb 16, 2009
    3,465
    Plug terminals , yellow wires not yellow now .
    BygDaddee likes this.
  11. Rotax655
    Dec 10, 2009
    681
    Cerveteri (Rome)
    combine the yellow wires individually with a tin solder. then isolated with insulating tape. most likely your problem with insufficient charging voltage depends on what you see in your photos. This is the work done on mine 20180526_160738.jpg
  12. Rotax655
    Dec 10, 2009
    681
    Cerveteri (Rome)
    you should also check the passage of the yellow cables in the middle of the exhaust manifolds. this is a very hot spot and as the miles go by the cables burn. look for a new route for these yellow cables. below I put some photos of the work done on my TE 20170604_150441.jpg 20170604_150349.jpg 20170604_152832.jpg
    Rogue_Ryder likes this.
  13. WILL_S
    Feb 16, 2009
    3,465
    My stator wires have no issue at the headers .
    New plug on yellow wires small improvement.
    Second earth from reg back to battery ground small gain.
    Tried a ktm 990 reg and we got 14.5v
    Then ran second red wire from husky reg straight to battery and we get 14.6 .
    Looks voltage drop at a couple of points in the loom.
    Rotax655 and DYNOBOB like this.
  14. WILL_S
    Feb 16, 2009
    3,465
    Engine oil in the slave , couple of grooves in the body
    Temporary fix , hone of anodising .
    Seals up to get home ,not sure how long it will last
    Will be replaced with upgrade
  15. Owen Snell
    Owen Snell Been here awhile
    May 21, 2008
    298
    Gainsborough, UK
    Cafehusky is back up and running guys.
  16. Rotax655
    Dec 10, 2009
    681
    Cerveteri (Rome)
    my connector under the voltage regulator is in these conditions. the recharge values are regular. I will cut and sold new connectors IMG_20190802_163345.jpg
    WILL_S likes this.
  17. Rob578
    Rob578 Long timer Supporter
    Dec 29, 2011
    1,537
    Atlanta
    and it took more of an effort than you might realize to make it happen.... you can thank Woodschick and Dirtdame
    Fast1, DYNOBOB and Owen Snell like this.
  18. cyclopathic
    Dec 23, 2007
    8,353
    Is there any aftermarket kickstand to fix the problem?
  19. Owen Snell
    May 21, 2008
    298
    Gainsborough, UK
    Thanks to them as well and a reminder to people to subscribe and support the site if we want it to be around in the future.
    Rob578 and Rotax655 like this.
  20. auto
    Feb 6, 2007
    506
    south jersey
    Cafe Husky is back.For how long??
