Husqvarna TE630
Discussion in 'Thumpers' started by Tagati, Sep 18, 2009.
  1. Rotax655
    Rotax655 Aprilia World Meeting
    Dec 10, 2009
    676
    Cerveteri (Rome)
    to me it all seems clear and legible. if you don't have a resistance of 19.5 Kohm (+/- 20%) the coil is broken IMG_20190809_080545.jpg
    we are fortunate to have SWM's cousins who sell it as a spare for the RS650R
  2. Ungarisch
    Ungarisch Adventurer
    Dec 1, 2007
    16
    Los Angeles
    what wasn't clean in the picture B is that he is measuring from plug wire to positive pin, and NOT plug wire to center mounting peg (ground) like it shows in the picture. We do not have a positive pin, we have wires coming out of our coils. Suzuki has pin.
  3. Fast1
    Fast1 Twisted Throttle
    Aug 18, 2007
    4,137
    Bridge over Troubled Water
    Did you zero out (0%) the throttle position at idle? @DYNOBOB may be able to advise on how to do this since I haven't messed with the Ibeat system for a few years or more. Have the complete Ibeat system listed in the flea market if anyone needs one.
    That fueling is too rich in the mid and for sure the high for a stock TE630 engine without any exhaust changes.
    These settings worked the best with my 630 mated with a full Leo Vince system running without a sparky in sumo mode.
    Rotax655 likes this.
  4. Fast1
    Aug 18, 2007
    4,137
    When I sold the SMS-630 with the stock exhaust system, these settings provided excellent results
  5. Rotax655
    Dec 10, 2009
    676
    Cerveteri (Rome)
    currently I have the bike removed for some maintenance. I wanted to check the kohm values of the ignition coil as described in the workshop manual. here is the value of the secondary circuit. check with your values. the measurement is taken between the spark plug cable and the chassis ground where the coil is mounted. Result secondary circuit 24,6 KOHM at 27 Degrees Celsius IMG_20190810_151048.jpg IMG_20190810_151042.jpg IMG_20190810_151119.jpg
  6. Ungarisch
    Dec 1, 2007
    16
    Los Angeles
    Rotax, Thanks for taking these measurements. When I measure in between the plug wire and coil ground while it's mounted to the bike, I get 26.6k Ohms at 26*C, however if I take the same measurement between the plug wire and the coil ground while its dismounted from the bike, I get open circuit. When dismounted I need to measure in between the plug wire and primary positive in order to read 26K Ohms.
  7. Rotax655
    Dec 10, 2009
    676
    Cerveteri (Rome)
    I don't understand how it is possible. maybe if you put a picture of the measurement we all understand better
  8. Gian
    Gian dreamer
    Oct 19, 2008
    2,359
    north east of Italy
    Any idea if it's possible to fit an Swm Superdual X rear wheel with rubber dampers on a TE 630 and maybe TE 610?
  9. Rotax655
    Dec 10, 2009
    676
    Cerveteri (Rome)
    I removed the fuel pump for a filter check. I would like to change the original filter with 13500 km but I have difficulty finding a new FT5721. have any of you used different alternative filters? Thanks for your help[​IMG][​IMG][​IMG]
  10. DYNOBOB
    DYNOBOB lucky dog Supporter
    Dec 15, 2008
    2,363
    Cincinnati, OH
  11. DYNOBOB
    Dec 15, 2008
    2,363
    Cincinnati, OH
    A fully loaded shakedown ride yesterday for upcoming 2500 mile/5 state loop ride out west in Sept. Removed my yellow Wolfman panniers and installed the Giant Loop Round the World panniers. Very impressed with them.
    WILL_S, chevmekanik, Rotax655 and 2 others like this.
  12. Rotax655
    Dec 10, 2009
    676
    Cerveteri (Rome)
    in the end I cleaned the original filter by washing it upstream and I reassembled everything with a new fuel hose. thanks to Dynobob for the indications on the alternative Purflux filter IMG_20190812_180713.jpg
  13. DYNOBOB
    Dec 15, 2008
    2,363
    Cincinnati, OH
    2 things... You might want to source some fuel injection hose clamps or Oetiker clamps (there 45psi in that hose), and make sure your fuel line is rated for in-tank use. I've seen them swell up like a sausage.
  14. Rotax655
    Dec 10, 2009
    676
    Cerveteri (Rome)
    what do you think about it? this is the reference standard. http://www.hosestechnology.it/schede/CARBO-73379-HT-Scheda-Tecnica.pdf
  15. Rotax655
    Dec 10, 2009
    676
    Cerveteri (Rome)
    most likely you are right about the need to use a tube suitable for continuous immersion in gasoline. but this type of tube conforming to the SAE30R10 standard I find it difficult to find. I saw this kind on amazon maybe compatible. https://www.amazon.com/Brand-Flexible-Fuel-Guzzi-Ducati/dp/B00LPX1JHY. can you give me some help for a more precise and better search? I put one photos of the current broken pipe IMG_20190813_122841.jpg
  16. Rotax655
    Dec 10, 2009
    676
    Cerveteri (Rome)
  17. DYNOBOB
    Dec 15, 2008
    2,363
    Cincinnati, OH
    I think most auto parts stores have hose that is suitable for in-tank use since this is the norm in the automotive world now.
  18. DYNOBOB
    Dec 15, 2008
    2,363
    Cincinnati, OH
  19. Rotax655
    Dec 10, 2009
    676
    Cerveteri (Rome)
    unfortunately it is not so easy to find it. the NBR tube should comply with the SAE30R10 standard which provides for testing with a completely immersed tube. I only shot 5 spare parts for cars this morning but none had SAE30R10 tubes. I found only DIN73379-1-2A tubes. Only the "Gates" with the type 27093 is SAE30R10 but has a minimum internal diameter of 8 mm. Thanks for the Dynobob collaboration.
    DYNOBOB likes this.
  20. Rotax655
    Dec 10, 2009
    676
    Cerveteri (Rome)
