I could not resist... 950 Super Enduro's Photo Thread
Discussion in 'Dakar champion (950/990)' started by Jolly705, Jul 24, 2006.
  1. singlewideteamusa
    singlewideteamusa Been here awhile
    Jul 22, 2011
    154
    Montrose, CO
    Yesterdays ride in Colorado.
    Engineer, Cinnamon and Black Bear Pass.
    Pictures are not even close to adequate
    The SE was fantastic, not even a hiccup at 13K
  2. enduro16
    enduro16 Long timer
    May 15, 2012
    1,646
    The woods of northern IL.
  3. qwert70
    qwert70 Been here awhile
    Jan 7, 2016
    295
    czech republic
    Mohl by si ukázat svod 2-1 s výfukem na levou stranu?
    426john likes this.
  4. qwert70
    Jan 7, 2016
    295
    czech republic
  5. V2XS
    V2XS n00b
    Aug 11, 2020
    8
    Cahors, France
    Just bought a 2006 950 SE with 75,000 Km.
    Doesn't look like it's been off road much and pretty standard apart from fly screen, hand guards and devil exhaust. Gradually going through and checking everything...
  6. Dirt2007
    Dirt2007 Long timer Supporter
    Jan 12, 2007
    5,510
    NEOK
    Congrats and enjoy. Looks like the seat has been trimmed a bit. Also the chain looks a little tight to me.
  7. qwert70
    Jan 7, 2016
    295
    czech republic
    To jsou detaily..:-)
  8. V2XS
    V2XS n00b
    Aug 11, 2020
    8
    Cahors, France
    Well spotted Dirt2007. The seat was "professionally modified" at some stage - looks very well done such that you can't tell unless you know what the seat should loiok like.
    Chain tension - yes maybe tight, need to look at that. My manual says 15-17 mm slack with bike on side stand and measured on lower side in front of chain guide. Reading the forums shows a few variations on this so I might try aligning the two spprockets and pivot and checking the slack at mid point which should apparently be 1/2 to 3/4 of an inch or 13-19mm.
    It doesn't get anywahere near the swining arm which is another quick check I read about and suggests it is too tight...
  9. qwert70
    Jan 7, 2016
    295
    czech republic
  10. TMoore
    TMoore Arai Helmet Test Dummy Supporter
    Jan 8, 2005
    1,445
    OK! (Formerly from The Peoples Republic of Mass)
    Fuel pump woes....@Dirt2007 gets a rescue
    mountaincadre and outbacktm like this.
  11. qwert70
    Jan 7, 2016
    295
    czech republic
    Dirt2007 likes this.
  12. Superhunk
    Superhunk Been here awhile
    Jun 4, 2003
    179
    Sonoma, CA
    I've been thinking of mounting my new facet fuel pump to the bike (vs. tank). Has it worked well? any drawbacks??? (heat?)
  13. bigborett
    bigborett Hipster Supporter
    Nov 29, 2014
    7,289
    Melbourne, Australia
    singlewideteamusa and outbacktm like this.
  14. skuikka
    skuikka Been here awhile
    Jun 23, 2009
    376
    Finland
    I've allways kept the pumps in the frame. Easier to remove the tank. When I yad the stock box, I had the pump bolted to the back of the box. Now with the TCM foam filter, I keep the pump in front of the fliter. No heat issues up to 28°C slow riding. We call that "hot" in Finland, you might see it otherwise.
    VikingMiko, Down and Superhunk like this.
  15. qwert70
    Jan 7, 2016
    295
    czech republic
    S podtlakovou pumpou žáden problém.Pumpu i klakson jsem umístil na rám pro snadnou demontáž nádrže..
  16. qwert70
    Jan 7, 2016
    295
    czech republic
    Jeremy K likes this.
  17. Superhunk
    Jun 4, 2003
    179
    Sonoma, CA
    That's a great idea. So you just extended the wires, and fuel lines? I have the Rottweiler intake, so I can mount it in a similar location. Thanks for the feedback!
  18. skuikka
    Jun 23, 2009
    376
    Finland
    You are welcome. And yes, extented lines and wires. I have also routed the lines so that they go straight up to the pump, so that I can lift the tank up for maintenance if needed.
    This might not work with normal fuel system but I have a return line in front of the fuel cap that flows fuel back from the carbs and keeps the level supposedly even on both sides of the tank. Even though the lower parts of the tank are not connected under the radiator. The main function of the return line is to keep the pressure down but I found out it has a side effect. This is still being tested, haven't ran the tank empty yet. 13.5liters is the biggest fill up so far, the pump was sucking air bubbles occasionally but no hickups from the engine.
  19. qwert70
    Jan 7, 2016
    295
    czech republic
  20. qwert70
    Jan 7, 2016
    295
    czech republic
    Dimer13 and Jan Inge Sageie like this.
