I have no idea what to do with this dt175
Discussion in '2 smokers' started by bike, Oct 8, 2020.
  1. bike
    bike Been here awhile
    Apr 13, 2010
    239
    Central VA
    Picked this up last night, and just like the title says, I'm not sure what to do. I can take anything apart and put it back together, but my knowledge on 2strokes and motorcycle transmissions is limited. I'd like to learn more.
    It was supposedly sitting in the same spot for the last 20+ years
    It's pretty complete
    I don't have a key or title. Title shouldn't be a problem...
    The shifter moves both ways, but nothing happens.
    Right side engine cover is loose, and everything that you'd have to get out of the way to get to it is missing (kicker, footpeg, etc)
    There was a bolt threaded in place of the spark plug
    Clearly it was running, then it wasn't, and someone started digging into it then quit.
    Do I...
    1. Rebuild/replace the motor, get a key, and ride it like it's 1987
    2. Make it into something cool/custom... I've always thought it would be cool to put modern suspension/wheels/brakes and motor in an old enduro. I know I said my 2stroke knowledge is limited, but I do have access to legit fabrication/machine work.
    3. Part it out
    PXL_20201007_223832795.MP.jpg PXL_20201007_232854828.jpg PXL_20201008_002935287.jpg PXL_20201008_003007702.jpg PXL_20201008_003105294.jpg PXL_20201008_003232589.jpg
    Jeathrow Bowdean likes this.
  2. RustyStuff
    RustyStuff Long timer Supporter
    Jan 14, 2012
    13,165
    Crakima,Wa
    Fix it and ride the tar off of it more or less as is.
    If you want to put modern suspension and stuff on something, I don't think this bike is it.
  3. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    13,872
    Omicron Persei 8
    Typically a bike like that will cost you more than it's worth to restore it.
    Bolt in spark plug hole? :hack Pull the top end to see what lurks inside. Pull that side cover off to see what might lurk in there too. Not good that the oil filler cap for the trans is missing. Transmissions were pretty strong so doubtful that it could be toast, but the all of the bearings could be rusted. Easy to check the clutch while the case is off too. Crank seals on the older two strokes that have sat for any real length of time will leak and need to be replaced. That's where I would start before putting a dime into it.
    Modern suspension will improve it but the old dual shock bikes are limited to the amount of travel available. You might get a real plush 4" of travel out of it.
  4. bike
    Apr 13, 2010
    239
    Central VA
    No doubt on the cost/value.
    And my vision for the modern stuff on an old bike isn't really for performance, just a fun bar-hopper/conversation piece.
  5. bike
    Apr 13, 2010
    239
    Central VA
    Any recommendations on the key situation? Pull the ignition cylinder and take it to a locksmith?
  6. jimroid
    jimroid Long timer
    May 14, 2013
    1,462
    Pisgah Forest,N.C./USA
    BACC306A-3F44-46E3-895D-C23EC645E36A.jpeg CA9CB89A-1AE2-4C13-BFA7-EF30EC59006D.jpeg That is not a bolt in the head. That is a dummy plug where you can put a spare plug in case you fouled the main plug. Or if you wanted a different heat range. Assuming there is a plug already in place. Can’t tell on my phone.
  7. Strong Bad
    Oct 29, 2007
    13,872
    Omicron Persei 8
    Now that could be. Back in those days guys racing scrambles/TT on two strokes also put compression releases in the "extra" hole.
  8. aptbldr
    aptbldr easy rider
    Apr 20, 2009
    1,598
    Upstate South Carolina, USA
    Naa, an operable key-switch is for later-on down this road you're on.
    Don't spend much money 'til you know more.
    "Hot-wire" around the ignition switch for now.
    Tend to transmission and oil-injection; case integrity & oil levels.
    Clean-up carb & air-box.
    Then, see if it runs from a remote fuel tank.
    #8
    spokester likes this.
  9. bike
    Apr 13, 2010
    239
    Central VA
    Yeah, the tank was my immediate concern. But remote tank makes way more sense. I'm also 99.9% sure it won't run as is, so I guess I'll just thinking about further down the road.
    #9
  10. bike
    Apr 13, 2010
    239
    Central VA
    #10
  11. jimroid
    jimroid Long timer
    May 14, 2013
    1,462
    Yeah! That’s not going to work! I wonder what heat range that is???!!!
    #11
  12. bike
    Apr 13, 2010
    239
    Central VA
    Not even the right threads.
    #12
  13. bike
    Apr 13, 2010
    239
    Central VA
    Today's news:
    complete clutch assembly: awol
    rotating assembly: seized.
    Not surprising. Still disappointing.
    #13
  14. brg
    brg 1977 XT500, 2000 ST1100, 1995 r100r Mystic
    Dec 13, 2014
    863
    southern ca
    That is really just a part bike. Unless it had / has sentimental value, it's not worth messing with, I know this from experience, more than once. :roflWhat I have learned about buying old bikes is, they should be complete, unmolested, and since I'm in California, they must have a signed off title with no back fees, generally speaking.
    #14
  15. Jeathrow Bowdean
    Jeathrow Bowdean Long timer
    Nov 12, 2012
    1,132
    Western Canada Dream
    Id get it running,,, leave the battle scares the way they are...
    And ride it too car shows along with trail rides...
    It will have lots of life in it...
    Do just enough too get it running,,, your friends will help you along the way...
    J.T.
    #15
  16. PSchrauber
    PSchrauber Long timer
    Jan 3, 2011
    1,367
    Summer: Kemiö, Finland; Winter: North Germany
    To me it depends to the overall status of the bike, if it would be mine I would taje it aoart and evaluate the complete bike then do the guessing math of costs and add 100%.
    Then I would think about if it us worth and also take time in consideration.
    If I have enough time and if I like to rebuild bikes I personal would do it. If not I now can sell it in parts.
    To the bike, it looks very nice, if rebuild proper the engine is also very nice, you can get better suspension for it you can even pimp the engine to 200cc.
    I have the trialsmodel a TY and I am very pleased,butthisparticular bike needs a lot of work.
    Parts are not so difficult to get, of this bike many where build soare parts are easy to find.
    #16
