I Like Station Wagons, I cannot Lie!
Discussion in 'Shiny Things' started by vegasphotog, Nov 2, 2009.
  1. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    18,837
    Zer0-Zer0-Zer0-Zer0
  2. troidus
    troidus Long timer
    Sep 1, 2010
    53,218
    Georgia
    Reverse rotation as in Marine? The oil pump still needs to rotate the correct direction, so does it use a gear driven cam so it still spins the right way, or is there a reverse oil pump, too? I would think the thrust loads would be all wrong, so there'd be all kinds of stuff that'd have to be subtly different. Maybe @Mongle can shed some light on this.
  3. Mongle
    Mongle Knuckle dragger
    Dec 4, 2009
    15,096
    North Carolina Y'all
    Most use a gear drive camshaft, crank spins opposite normal, cam spins normal. I have seen some Ford that cut the distributor gear so the crank and cam spin opposite, but distributor and oil pump still spin correctly. I believe there used to be oil pumps that were designed to spin the other way, but I never worked on one.
    Reverse rotation engines pretty much ended with the release of Mercuiser Bravo One Drive. With the Bravo 1 they run the counter rotation prop via the drive. Both engines spin normal.
    Piston offset is switched around and you have to pay attention to seals that have rotation direction.
    Uke and troidus like this.
  4. Cycledelic Relic
    Cycledelic Relic follow old goatpath
    Dec 5, 2009
    3,366
    skinny Cen-Tex pavement
    I didnt read the whole Hagerty write up in detail...but it said the 283 was chosen for the Corvair swap specifically because there were readily avail marine kits for it.
    Uke and Mongle like this.
  5. troidus
    troidus Long timer
    Sep 1, 2010
    53,218
    Georgia
    The original SBC was designed with boat racing in mind. That's why the original displacement was 265 cubic inches, to meet a particular class limit.
  6. bk brkr baker
    bk brkr baker Long timer Supporter
    Jul 19, 2006
    12,041
    The Bluegrass
    RedRocket and Uke like this.
  7. Mudclod
    Mudclod Mojo Moto
    Jun 19, 2010
    23,943
    Killeen, TX.
    Custom built for Wayne Newton.
    RedRocket and Dorzok like this.
  8. troidus
    troidus Long timer
    Sep 1, 2010
    53,218
    Georgia
    Is that a Pinto glassback rear hatch, or something else?
  9. Cycledelic Relic
    Dec 5, 2009
    3,366
    Could be a pick up bed topper rear glass.
    Ive seen some with very angled rear lift glass.
  10. Mongle
    Dec 4, 2009
    15,096
    I had never heard of this. What kind of boat racing? I'm trying to think of the time period, best I can think of is Jersey Skiff racing.
  11. Uke
    Uke visualist Super Supporter
    Oct 9, 2013
    6,178
    HouTex USA
    I hope this is real and not P-Shopped, the doors are too cool.
    I would have been tempted to integrate a Vista-Cruiser roof while I was at it.
  12. Uke
    Oct 9, 2013
    6,178
    HouTex USA
    I've seen reverse rotation done on a Ford Flathead, remember it from a hot rod show I dragged my Dad to, he explained to me why the exhaust was coming out the top and carbs were on the side.
  13. Lead Wrist
    May 26, 2007
    18,837
    Zer0-Zer0-Zer0-Zer0
    It is coach built custom... Similar like below except this one is in a bit rougher shape...
    Few pages back I posted couple of Rolls Royces, of various MY/models, all custom built as shooting brakes/station wagons...
    ca.gearhead, RedRocket and Uke like this.
  14. troidus
    troidus Long timer
    Sep 1, 2010
    53,218
    Georgia
    I think it was hydroplane racing.
    Mongle likes this.
  15. thumpism
    thumpism Between bikes
    Dec 16, 2005
    8,754
    Richmond, Virginia
  16. Lead Wrist
    May 26, 2007
    18,837
    Zer0-Zer0-Zer0-Zer0
  17. Lead Wrist
    May 26, 2007
    18,837
    Zer0-Zer0-Zer0-Zer0
    Uke and STBNE like this.
  18. Lead Wrist
    May 26, 2007
    18,837
    Zer0-Zer0-Zer0-Zer0
    ca.gearhead likes this.
  19. troidus
    troidus Long timer
    Sep 1, 2010
    53,218
    Georgia
  20. Lead Wrist
    May 26, 2007
    18,837
    Zer0-Zer0-Zer0-Zer0
    You'd expect nothing less from custom coach built Lincoln...
