I Think I Might Build Me An RV...
Discussion in 'Camping Toys' started by Nailhead, Mar 13, 2018.
  1. RedRocket
    RedRocket Yeah! I want Cheesy Poofs
    Feb 28, 2003
    39,529
    SoCal
    How did piss become so valuable.
    The real test when hiring is can the prospect keep their hands off their phones for 10 minutes.
    Nailhead likes this.
  2. bmw318tech
    bmw318tech Long timer Supporter
    Dec 20, 2006
    2,608
    South west PA
    As fairly recent hire in the USPS VMF its not like its a shock that they ask for a clean piss test. You have plenty of time to study.
  3. Nailhead
    Nailhead Inclusion Rider
    Apr 6, 2003
    10,622
    Longmont, CO
    Back in the land of wind & cruise control, our story resumes:
    These are two of the four oak blocks from between the old flatbed & the frame. I didn’t pay them much mind previously, being old & weathered, with some areas of light surface rot, until I priced out options for their replacement starting at $400. They are now being treated with all the TLC I can give them, starting with a loving hand-scrubbing with a wire brush to remove funk the years have accumulated.
    Then some stain to preserve them as best I can:
    My kinda finishing: satisfying, and very forgiving.
    It took a surprising amount of time & stain to arrive at this:
    because it was like painting a sponge.
    Then some old guy with nothing better to do did some sanding:
    More later today. Got those damn red frame rails & the back of the cab painted in preparation for mounting the camper frame.
    Monkeys, lifting equipment, a big heavy object, a non-running truck, and bottomless coffee & Baileys won’t be boring.
    wilfred, mb8, WYO George and 3 others like this.
  4. Nailhead
    Apr 6, 2003
    10,622
    Longmont, CO
    Sunday morning, and we’re ready to set the camper frame. The necessary painting is done:
    Mostly.
    Rigging time:
    Up we go:
    Next we rolled the truck under that suspended load,
    set the blocks in their places, and lowered it.
    It went off without a hitch, and took maybe 20 minutes. A complete anticlimax.
    20 more minutes, some lock washers & Loctite, and it’s securely attached.
  5. Nailhead
    Apr 6, 2003
    10,622
    Longmont, CO
    We figured we had to test fit one of the side boxes, just for shits & grins:
    Those things are really heavy. They’ll hold a bunch, too:
    It looks like camper & boxes will fit together just right. Just have to weld up old mounting holes in the boxes, drill new ones, and paint them.
  6. Nailhead
    Apr 6, 2003
    10,622
    Longmont, CO
    I also took care of some front-end finish issues before heading south again. I wanted to get rid of the red overspray behind the grill with some undercoat:
    I’m pretty well satisfied with that. I painted the bumper, too, while Harry was away, and I’m not as sure about that. I think it may be too much, but I’m not really sure where to go with it. I thought maybe cutting the lower corners back at 45°, or maybe painting the lower half black would lighten it up a bit.
  7. Nailhead
    Apr 6, 2003
    10,622
    Longmont, CO
    While mocking up the layout last weekend, Harry & I discovered a problem: there’s no room for the spare wheel, and the details of the solution I came up with have been bugging me...until I found this:
    A swing-away spare carrier weld-on pivot kit!
    Seriously— hallelujah; the pivot was the biggest question mark I had in the design I worked up in my head. We just have to come up with a pivot mount location out of the path of the camper during loading & unloading.
    WYO George likes this.
  8. Nailhead
    Apr 6, 2003
    10,622
    Longmont, CO
    Since nothing is happening on the IH front, I thought I’d update y’all on what happened with the Jeep a while back.
    If you remember, it just shit the bed out of the blue driving through town. Here’s why:
    The oil pump/distributor drive gear.
    I’m at a loss as to what the cause is.
  9. Pressingonward
    Pressingonward Looking forward to what is ahead
    May 29, 2015
    166
    SW Washington State
  10. HapHazard
    HapHazard Be Kind - Rewind
    Dec 30, 2009
    5,503
    Central CT
    Something small & hard that doesn't belong there must be floating around in there.
  11. WYO George
    WYO George I have no idea
    Sep 1, 2005
    6,402
    left of nowhere, WY
    Does the distributor shaft spin freely with it removed?
  12. vtwin
    vtwin Air cooled runnin' mon
    Jan 11, 2005
    9,776
    NorCal
  13. Nailhead
    Apr 6, 2003
    10,622
    Longmont, CO
    ...she said. :lol3
    I figured it out last night with a little sleuthing, and a little more Tito's. An M715zone member posted up a pic of his engine during assembly, timing chain cover not yet installed. This guy has a lot of cred on that forum for the obsessive detail he goes to with the work he does on his trucks. Did ya ever see a transfer case so clean you could eat off of it? That's what Dan does. Anyway, I was staring at my gear, looking at the tooth contact patch when a light went on. A bright one. The gear in Dan's engine had been installed with the shoulder to the rear-- mine, if you'll notice, is the other way around. Backwards. I then consulted the online TM's on the Zone and, sure enough-- those fuzzy old photos verified my suspicions.
    Too much loading on too little tooth area on a bronze gear did it in. Add to it the 15-40 oil I run, and the force on those teeth was even greater. It was a ticking time bomb from the moment it was (mis)installed.
    This engine has showed me signs it was rebuilt not very long before it was taken out of service: numbers written in crayon on the block, a clutch & flywheel that was new when we removed the engine from the truck it was originally in. I think the gear was installed incorrectly when the chain & sprockets were replaced.
    cprbusa, villageidiot and WYO George like this.
  14. WYO George
    Sep 1, 2005
    6,402
    left of nowhere, WY
    I'm glad you got it figured out, that means you know how to prevent it in the future!
    villageidiot likes this.
  15. Nailhead
    Apr 6, 2003
    10,622
    Longmont, CO
    Once I find a gear, I’ll have ‘er nippled, George.
    The volume of replies to my “wanted” post on M715zone has been nonexistent, however.
  16. Nailhead
    Apr 6, 2003
    10,622
    Longmont, CO
  17. WYO George
    Sep 1, 2005
    6,402
    left of nowhere, WY
  18. WYO George
    Sep 1, 2005
    6,402
    left of nowhere, WY
  19. Nailhead
    Apr 6, 2003
    10,622
    Longmont, CO
  20. WYO George
    Sep 1, 2005
    6,402
    left of nowhere, WY
    Definitely not cheap, but that's the nature of the beast with stuff like this. I know of that site because of the Willys connection to Kaiser and since I own a Kasier I know about every place that sells parts that can even be cross referenced to fit!
    Nailhead and villageidiot like this.
