    Dismiss Notice
ICEBEAR VISION 150 (Zuma clone)
Discussion in 'Battle Scooters' started by WR450FADVn, Apr 12, 2020.
Tags:
  1. dp064
    dp064 Been here awhile Supporter
    Nov 11, 2019
    309
    Nashville
  2. Bar None
    Bar None OLD DUDE Supporter
    Mar 2, 2007
    13,800
    SWFL WNC
    Here is the tire I ordered
    https://www.amazon.com/gp/product/B00A4BG9LE/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
    130/70R12
    Here are the specs for the scooter
    http://www.icebearatv.com/product/PMZ150-17
    Tire size(Front/Rear) 120/70-12
    I agree that it does look like more than 10 mm difference. The oe tire is worn in the center but not much on the edges. I will measure the tires.
    I will change the tire in a couple of weeks after the 120/70-12 and the exhaust gasket arrive. Just want to have a new 120/70-12 on hand if the 130/70-12 doesn't fit.
    dp064 likes this.
  3. dp064
    Nov 11, 2019
    309
    Nashville
    I hope it fits with no issue.. it's going to look great with the bigger tire.
    Don
  4. Bar None
    Mar 2, 2007
    13,800
    SWFL WNC
    The oe 120/70-12 is 110 mm wide while the 130/70-12 is 130 mm so about 3/4" wider but it sure looks like more.
    dp064 likes this.
  5. sanjoh
    sanjoh Purveyor of Light
    Feb 13, 2007
    9,016
    ADVmonster, CFL, WNC
    Better have the grinder handy when you install!
  6. Bar None
    Mar 2, 2007
    13,800
    SWFL WNC
    That is why I am waiting until I get the new 120/70-12 just in case the 130/70-12 is too big.
    The OP did replace his tire with a 130/70-12 and it fit. He seems to have gone away. Hope he is OK health wise.
    sanjoh likes this.
  7. Bar None
    Mar 2, 2007
    13,800
    SWFL WNC
    Tires! Received the 120/70-12 today. Obliviously the OE 120/70-12 is smaller than the new 120/70-12.
    new 120 old 120 new 130
    new 120 new 130 The new 130 is about an inch taller than the new 120.
    front new 120 old 120
    Got three exhaust gaskets just in case.
    dp064 likes this.
  8. Bar None
    Mar 2, 2007
    13,800
    SWFL WNC
    I put the 130/70-12 tire on the rear and it fit just fine. Think I will fit a 130/70-12 on the front too.
  9. dp064
    Nov 11, 2019
    309
    Nashville
    Looks great.. I bet it rides better as well.
    Don
  10. Bar None
    Mar 2, 2007
    13,800
    SWFL WNC
    I can feel the difference in height with the new 130/70-12 vs the old worn-out 120/70-12. Seems to ride just fine.
    minimac, Salth2ofish and dp064 like this.
  11. sanjoh
    Feb 13, 2007
    9,016
    We need some profile pictures (hopefully with your assistant) to confirm:brow
    dp064 and Bar None like this.
  12. Bar None
    Mar 2, 2007
    13,800
    SWFL WNC
    I need to get her to come do part of the 4K maintenance on my scooter. I can handle the oil change but need her to check/adjust the valve clearances.
    Will post photos of her doing the work. :rofl
    dp064 and sanjoh like this.
  13. sanjoh
    Feb 13, 2007
    9,016
    I'll volunteer for gofer duty, finally made it to WNC.
  14. Bar None
    Mar 2, 2007
    13,800
    SWFL WNC
    Unfortunately I don't need her as the valves clearances were in specs. :dirtdog
    All done with the service but raining so no riding.
  15. Salth2ofish
    Salth2ofish Long timer
    Nov 28, 2019
    1,209
    NC
    I would like a tutorial on how you mounted the tire. I need to change my rear reflex tire- same size and bought a set of tire spoons. Never changed one.
  16. Bar None
    Mar 2, 2007
    13,800
    SWFL WNC
    I always look for videos on YouTube because I don't change tires that often and always learn something new. Look at several
    For example Google how to change scooter tires
    Here is one
    dp064 likes this.
  17. Bar None
    Mar 2, 2007
    13,800
    SWFL WNC
    AS far as removing the Reflex rear wheel this was the closest I could find. This guy was removing the disk.
  18. Bar None
    Mar 2, 2007
    13,800
    SWFL WNC
    I just put a 130/70-12 on the front so the the tires are the same size front and rear. Will give her a run tomorrow assuming it is not raining. Yesterday we had 3.44 inches of rain thanks to Tropical Storm Beta. The creeks are roaring. Returning the two 120/70-12 tires.
    dp064 and minimac like this.
  19. Bar None
    Mar 2, 2007
    13,800
    SWFL WNC
    130/70-12 on the front.
    Took a ride to Deal's Gap and didn't notice any difference in the handling with the bigger front tire. Big crowd there of Harleys and sporty cars so I didn't bother riding over the Dragon.
    klaviator and dp064 like this.
  20. Bar None
    Mar 2, 2007
    13,800
    SWFL WNC
    Doing a little light hauling today.
    dp064 likes this.
