ICEBEAR VISION 150 (Zuma clone)
Discussion in 'Battle Scooters' started by WR450FADVn, Apr 12, 2020.
Tags:
  1. Bar None
    Bar None Long timer Supporter
    Mar 2, 2007
    13,493
    SWFL WNC
    Great. Start a thread here in Battle Scooters so can follow along.
  2. Alzero
    Alzero Been here awhile
    Jan 13, 2019
    238
    Onboard
    minimac likes this.
  3. Bar None
    Mar 2, 2007
    13,493
    SWFL WNC
    There are big bore kits for the GY6 and even more CC GY6 engines available.
  4. WR450FADVn
    WR450FADVn Adventurer
    Sep 25, 2009
    80
    Eastern VA
    5E2F8E57-6529-43DC-9E40-52D84D16E531.jpeg 15DF65FE-0C3D-42FB-AAD7-53F8658D8A65.jpeg Rode down to the Chesapeake Bay this morning. 78 miles at pretty much full throttle and burnt 1.38 gallons(56.5 MPG). I used an app called Bikemap which sent me down only small back roads. Had a blast!
  5. Bar None
    Mar 2, 2007
    13,493
    SWFL WNC
    59.4 MPH Max Speed?
  6. WR450FADVn
    Sep 25, 2009
    80
    Eastern VA
    must have been on one of the 5 hills we have here in eastern VA lol. It goes 53-54 on flat stuff
    Salth2ofish and Bar None like this.
  7. minimac
    minimac Long timer
    Jun 8, 2015
    1,140
    Central NY & Central Fl
    That's why I said driveline, not merely engine. It would extend the wheelbase(longer case & swingarm) besides being stronger. That would only leave beefing up the front end slightly.
  8. Bar None
    Mar 2, 2007
    13,493
    SWFL WNC
    I need to go back and readjust the valves. Should have read this label on the engine. I set them too loose using the owner's manual specs. Just off a bit. Next adjustment at 1k KM. I am at 500 KM. Hope to get my tag on Wednesday so I can ride her more.
  9. WR450FADVn
    Sep 25, 2009
    80
    Eastern VA
    what did you set them to? .6mm is nothing
  10. Steve_h
    Steve_h Long timer
    Sep 15, 2016
    1,060
    Spartanburg, SC
    .6mm is .023 inch
  11. Bar None
    Mar 2, 2007
    13,493
    SWFL WNC
    .05 mm to .08 mm as according to the label on the engine.
    Also add a mini tach
    WR450FADVn likes this.
  12. Bar None
    Mar 2, 2007
    13,493
    SWFL WNC
    Finally got my scooter tagged so I am legal on the road. Also installed some fixed highway pegs on the scooter. I will give them a test ride tomorrow.
  13. Bar None
    Mar 2, 2007
    13,493
    SWFL WNC
    Took a ride out to our ranch about 30 miles East of our house in Fort Myers,FL. Nice ride except for the love bugs that are bad East of town.
    Arriving at the front gate.
    Found two new calves in my brother in law's herd. He is leasing the ranch because his place is almost out or grass. We are in a drought so grass is not doing well.
    Scooter seems to have more pep, maybe broken in more, close to 800 km now.
  14. Bar None
    Mar 2, 2007
    13,493
    SWFL WNC
    Took a ride out to Fort Myers Beach and Lover's Key State Park. Just about perfect weather and not many people out so was nice.
    Getting about 80 MPG for the last several tanks.
  15. Bar None
    Mar 2, 2007
    13,493
    SWFL WNC
    Had a nice ride out to Captiva Island
    and then back home to do the 1k km oil change (actually 950 km on the scooter) using 750 ml of Rotella Synthetic 15W40 .
    The magnetic drain plug was pretty much free of metal which was nice to see.
    Salth2ofish, Moat and klaviator like this.
  16. Bar None
    Mar 2, 2007
    13,493
    SWFL WNC
    Nice ride out to Sanibel/Captiva the other day looking for a bikini model like this one from a few years ago.
    No luck.
    Did a chop job on the rear fender, not as severe as the OP's.
    Moved the reflector to the support bracket attachment.
    WR450FADVn and klaviator like this.
  17. Bar None
    Mar 2, 2007
    13,493
    SWFL WNC
    WR450FADVn and tbonestone like this.
  18. WR450FADVn
    Sep 25, 2009
    80
    Eastern VA
    Somehow I have worn my rear tire out in just 700km. Got a real Kendra from the local Vespa dealer. The only size that had was 130/70/12. Fits perfect and is the stock size for the rear on the zuma125
    58C1A0DF-9AB2-45A8-8E58-3B626E72A351.jpeg B882A503-1192-4A89-9A70-677FAA28CA1A.jpeg
    The Virginian likes this.
  19. Steve_h
    Steve_h Long timer
    Sep 15, 2016
    1,060
    Spartanburg, SC
    That's that wonderful chinese rubber for you. The stock chinese tire on my 50 was gone very early too. I've put more miles on the replacement than I got out of the original and you can hardly detect any wear in it.
    Sorry to hear you had a little setback. You should be good to go on the new tire.
    The Virginian and WR450FADVn like this.
  20. Bar None
    Mar 2, 2007
    13,493
    SWFL WNC
    Wow. I have 1400 km on my scooter and no sign of any wear on front or rear tire. Wonder what would cause that tire to wear out that fast.
