ICEBEAR VISION 150 (Zuma clone)
Discussion in 'Battle Scooters' started by WR450FADVn, Apr 12, 2020.
Tags:
  1. Bar None
    Bar None OLD DUDE Supporter
    Mar 2, 2007
    14,002
    SWFL WNC
    The belt size for my Ice Bear Vision PMZ150-17 is 835-20
    As was suggested I pulled the cover to get the correct number.
    With 3k km on the belt on the scooter it looks just fine.
  2. Steve_h
    Steve_h Long timer
    Sep 15, 2016
    1,088
    Spartanburg, SC
    I remember years ago hearing ads about aramid fiber in radial car tires. It's got to be a stong fiber. I don't know if it's the same thing as kevlar, though.
    As far as belt size, the easiest thing to do is remove the cover now while your belt is in good condition and get the numbers off of it.
    My chinese scoot is a 50 and the original belt lasted about 4000k. It broke. I got another and it lasted about 500k and broke. I found out there was some sort of problem with the sheaves on the clutch and replaced the clutch assembly. Replacement has been on there for about 3500k and it still looks pretty much new. I am thinking the clutch problem killed my original belt.
    Since belts are super cheap for the 50's, I have a replacement sitting here for when I need it. I also have a spare CDI or two. They are known to die at inopportune moments. Don't waste your money on a performance or racing CDI. It does nothing but give you full spark advance at low speeds. Makes pre-ignition much more of a concern and usually makes it harder to start. You might want to get a spare spark plug cap. I have never had an issue with mine. My son had 3 fall apart in a couple months until he hit a good one.
    NJ-Bill likes this.
  3. tortoise2
    tortoise2 Been here awhile
    Dec 29, 2007
    929
    Nevada
    Also negates the objective of high-octane gas which RETARDS combustion closer to piston top-dead-center.
  4. Bar None
    Mar 2, 2007
    14,002
    SWFL WNC
    Have no intention of replacing the CDI. Had many Chinese bikes over the last 15 years and never had a CDI problem or spark plug cap problems.
  5. Steve_h
    Steve_h Long timer
    Sep 15, 2016
    1,088
    Spartanburg, SC
    I haven't either but I have seen many people who have. I think a lot has to do with the manufacturer. The guy at the scooter shop up the road from me tells me most problems are CDI, stator, or carb when it won't run. Of course, what he sees mostly is the cheapest thing you can buy type scooters that the drunks are riding around.
  6. dp064
    dp064 Been here awhile Supporter
    Nov 11, 2019
    389
    Nashville
    ..not a scooter but made in China just the same..
    klaviator and Bar None like this.
  7. Bar None
    Mar 2, 2007
    14,002
    SWFL WNC
    What make and model? Just sold the DF250RTG and the Ice Bear CT70 clone so am down to the scooter and a TU250X. Hope to stay that way for a while.
    dp064 likes this.
  8. dp064
    Nov 11, 2019
    389
    Nashville
    It's a CSC SG250.. had it for a little over a year. I like it.. had no issues but at the Beat the Heat scooter rally I really became a believer in the simplicity of the scooter / CVT transmission.
    Bar None and klaviator like this.
  9. Bar None
    Mar 2, 2007
    14,002
    SWFL WNC
    I was suppose to be there in MV but got hung up here at our place close to Robbinsville,NC. Maybe next year. I too like the simplicity of the CVT scooter.
    klaviator and dp064 like this.
  10. dp064
    Nov 11, 2019
    389
    Nashville
  11. Bar None
    Mar 2, 2007
    14,002
    SWFL WNC
    I just pulled the cover on the air filter to check/clean the element. It looked perfectly clean which surprises me since I ride about a mile or two of gravel whenever I leave the cabin here in the mountains of WNC.
  12. Bar None
    Mar 2, 2007
    14,002
    SWFL WNC
    Yamaha 2013 Zumba 125
    Another Zuma clone 150 and available under other names including Zuma.
  13. princess jamaica
    princess jamaica OLD DOG-NEW TRICKS
    Oct 13, 2006
    3,167
    KM111.5 POSADA CONCEPCION,BCS
    Here's mine.Italika ws175 sport.Chinese/Mexican mix.Just picked it up and am very pleased so far. IMG_20200806_1013211_rewind.jpg IMG_20200806_1013321_rewind.jpg IMG_20200806_1013321_rewind.jpg
    klaviator, dp064 and Bar None like this.
  14. princess jamaica
    Oct 13, 2006
    3,167
    While I'm here,what is a good source for aftermarket parts ?Specifically suspension.Also,is there a good read on belts,weights,variations and how they effect performance .Gracias !!
  15. Bar None
    Mar 2, 2007
    14,002
    SWFL WNC
    WR450FADVn to the bat phone.
    I am new to the GY6 so can't advise on belts,etc.
    I plan to not monkey with that stuff, famous last words.
    Like your location in the Baja.
  16. princess jamaica
    Oct 13, 2006
    3,167
    Come on down.
  17. Bar None
    Mar 2, 2007
    14,002
    SWFL WNC
    Long ride from SWFl to Baja. Maybe after Covid-19 is over???
    Yucatan Express Ferry from Tampa to Yucatan? Baja Ferry?
    Back in 1997 I rode a motorcycle from Fort Myers FL to Texas then with Pancho Villa Motor Tours on the border of Texas to Panama. Sold the bike in the no man's land between Panama and Costa Rica and rode a bus back to Panama and flew home.
  18. Bar None
    Mar 2, 2007
    14,002
    SWFL WNC
    dp064 likes this.
  19. dp064
    Nov 11, 2019
    389
    Nashville
    Just looked it up before I got to the bottom of the thread.. looks like about $1250usd..
    Don
  20. Bar None
    Mar 2, 2007
    14,002
    SWFL WNC
    That Zuma clone has a 168.9 CC engine?
