Identifying BMW Airhead petcock model?
Discussion in 'Airheads' started by shadeobrady, Apr 1, 2019.
  1. shadeobrady
    shadeobrady Adventurer Supporter
    Mar 30, 2016
    58
    Denver, CO
    Hey folks - having issues with gas flow and want to do a rebuild. As I understand it, the main two types readily available are the Karcoma (a new version of the original?) or the Everbest (the newest version?).
    The bike is a 1978 BMW R100RS if that matters for any reason.
    Is there anyway to know which these are so I can buy the correct rebuild kits?
  2. PaulBarton
    PaulBarton Long timer Supporter
    Apr 14, 2015
    6,844
    Seattle
  3. brfoster
    brfoster Baile Atha Cliath
    Sep 2, 2010
    846
    Australia
    @shadeobrady, the petcocks in the photos are Karcoma - the latest version.
    Everbest were usually fitted to early models ('55-69).
    See here for more detail:
    http://w6rec.com/duane/bmw/petcock/
  4. shadeobrady
    Mar 30, 2016
    58
    Denver, CO
  5. chasbmw
    chasbmw Long timer
    Feb 19, 2006
    3,831
    Bath Uk
    The original peacock should have the outlet pointing downwards......
    Before you order new parts, drain the tank, remove the taps and remove any watered grunge swilling in the bottom of the tank, then check again for flow.
  6. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    10,195
    The petcock used for a while, most notably in 1980 was the Germa. It is identified by the screw that retains the handle.
  7. dirtsurfer
    dirtsurfer Hapless airhead rescuer, Adventourer
    May 10, 2006
    5,652
    In the garage
    A few more pictures and I might be able to identify it
  8. boxerboy81
    boxerboy81 Stay Horizontal
    Jul 22, 2009
    4,824
    Melbourne, Oz
    [​IMG] [​IMG]
    #8
    dirtsurfer likes this.
  9. Disston
    Disston ShadeTreeExpert
    Aug 31, 2009
    22,037
    Silver Spring, Md
    You have Karcoma petcocks. They may only need cleaning. There are only 2 parts available if needed. An O-ring and a flat rubber disk with 5 holes. If anything else other than these 2 parts is needed you have to buy a new complete part.
    Most times all that's needed is a good flushing with compressed air and a flush of the debris in the gas tank. Get some new gas line too. The GL doesn't last very long.
    #9
  10. Solo Lobo
    Solo Lobo airhead or nothing Supporter
    Mar 16, 2004
    13,668
    Shoreline, WA
    The lower brass or aluminum washer connected to the screen can wear and not seal well.. those should be replaced as well.
    #10
  11. Disston
    Aug 31, 2009
    22,037
    Silver Spring, Md
    Right Solo. The filtration of the system is a large screen inside the tank that is held on top of the petcock straws and sealed by a metal washer on the modern screens and a separate red fiber washer on the old ones. You can still buy the red washers if that's what you have and they are worn out but the newer screen with a metal washer is one piece so if worn out you have to buy the whole screen. No problem really they only cost about $10. If the older screens are ratty just buy the modern ones.
    #11
    Solo Lobo likes this.
  12. Manks
    Manks Been here awhile
    Aug 12, 2010
    334
    I have two Germa taps for my big tank. did they make a right angle outlet (where the hose attaches) for these?
    #12
  13. chasbmw
    chasbmw Long timer
    Feb 19, 2006
    3,831
    Bath Uk
    And clean the internal screen NO 3 on the diagram
    #13
  14. Disston
    Aug 31, 2009
    22,037
    Silver Spring, Md
    If you have one. Not all petcocks have the small screen in the bottom.
    #14
  15. shadeobrady
    Mar 30, 2016
    58
    Denver, CO
    Thanks folks - this was all incredibly helpful. I yanked them off... both had the screen filters that plug upwards into the gas tank. Disassembly was pretty easy besides getting that end with the incredibly strong spring screwed back on, but not terrible.
    The gas flows - we're good!!
    #15
    Square1, PaulBarton and brittrunyon like this.
