Ignitech TCIP4
Discussion in 'Dakar champion (950/990)' started by martinbuchmayr, Oct 11, 2019.
  1. martinbuchmayr
    martinbuchmayr Carb 950s
    Jun 20, 2015
    35
    Austria
    I dont know if you have once seen the products of Ignitech? You can fully program your ignition
    http://ignitech.cz/en/
    Someone ever thought of using their ingnition in a 950 Adventure or SE?
    I have those running in several mid 2000 bikes, like the Kawasaki ZRX1200R/Zephyr1100, Yamaha BT1100 - every bike runs really smooth with the TCIP4
  2. Le mani del Caos
    Le mani del Caos Adventurer
    Oct 6, 2017
    10
    italy
    I am working on it.
    There is a problem with connectors that are not waterproof.
    With this test bench using the same 24-2 teeth trigger wheel of the 950 works perfect.
    I also find the teeth sequence on the original ignition but I don't know the mechanic advance of the trigger whell.
    A job for the future.
    Helibee, martinbuchmayr and Salzig like this.
  3. martinbuchmayr
    Jun 20, 2015
    35
    Austria
    Awesome!
    Thanks for having a look into that, this will be a great modification!
    Keep us updated!
  4. gearheadE30
    gearheadE30 @LC8Adventures Supporter
    Jan 20, 2012
    2,165
    Indiana
    Cool! I have an Ignitech on my CX500. It is pretty slick and has some interesting built-in features, but the connector is a bit disappointing. The pins are the same as 1990's Harley turn signals though, which is handy. No reliability issues with mine so far, and there are a lot of trigger options for different engines. Documentation online is a bit spotty for some of the more obscure features.
    The 950's ignition seems to be pretty well tuned from stock; I've not seen a lot of people out there going to different advance settings. Aside from being an interesting project, any particular goal you're looking to hit?
    Gratuitous CX500 pic:
  5. opanos
    opanos Been here awhile
    Aug 12, 2015
    403
    Rotterdam, Flatland
    I cannot agree on that. I would say that especially on 950s, ignition timing is adjusted more for meeting requirements than achieving optimal performance. Custom ignition curve is something that I think of for a long time, but on a TPS equiped bike, building a decent 3-d map would be a real PITA with a lot of dyno work.
    The reason why I say that is because, I have seen dyno curves from adv and sm models which vary a lot despite the fact that engines are identical. The sm model has more torque eveywhere, and doesn't run out of power even close to the rev limiter, when adv models feel softer on low end and lack top end performance. I was initially thinking that this difference was due to different exhaust pipes, but after running a few engine simulation models of the 950 engine, it looks that it's not the case. Besides, SM and Adv models have different ignition modules. Interestingly enough, sm models seem to work better with richer fueling, probably because due to better ignition timing, they can burn fuel more effectively. Last but not least, stock SM/Adv 950 engine seem to be good enough for 110 hp @ rear wheel
    I believe that there is a big potential in a custom ignition map, but no one has tried that so far.
    Crazygreek and mountaincadre like this.
  6. mountaincadre
    mountaincadre Long timer
    Jul 18, 2012
    1,766
    Mid Calder,Scotland
    So fitting an SM cdi to a adv?
  7. opanos
    Aug 12, 2015
    403
    Rotterdam, Flatland
    it might not work well, SM models have different headers so a different ignition timing should be required.
    mountaincadre likes this.
  8. mountaincadre
    Jul 18, 2012
    1,766
    Mid Calder,Scotland
    I have a 990smt motor in it opanos with the full mass moto exhaust which has large headers.
    #8
  9. opanos
    Aug 12, 2015
    403
    Rotterdam, Flatland
    not only you have different headers, but your engine has different displacement and camshafts too :D
    but I think that your bike would definitely benefit from a custom tailored ignition map
    #9
  10. opanos
    Aug 12, 2015
    403
    Rotterdam, Flatland
    maybe it would be easier to just use a 990 harness and ECU...the ECU is going to be responsible only for the ignition timing, and would be rock solid reliable...
    #10
  11. mountaincadre
    Jul 18, 2012
    1,766
    Mid Calder,Scotland
    I'm still in the searching stage opanos, I've got some playing about to do with the carb set up as the dyno figures aren't very good .
    #11
  12. opanos
    Aug 12, 2015
    403
    Rotterdam, Flatland
    what do you mean? What is the dyno reading now?
    #12
  13. mountaincadre
    Jul 18, 2012
    1,766
    Mid Calder,Scotland
    89rwhp opanos from a 990smt motor with itg filter, the dyno was showing it running out of steam at just over 8k revs which makes me think go larger on mains to start with,(170/172 jets Just now), the old 950 engine was getting 98rwhp with twin akro's and standard airbox, hmmmm.
    #13
  14. opanos
    Aug 12, 2015
    403
    Rotterdam, Flatland
    maybe your single exhaust is messing up with your top end...
    Why don't you try to switch back to stock headers and mufflers to see if the exhaust is the issue?
    Do you have an AFR diagram with your dyno chart?
    I have jetted a SD-motored adventure in the past and I used (as expected) smaller main jets...No dyno chart though, but the jetting was done using a wideband sensor
    #14
  15. mountaincadre
    Jul 18, 2012
    1,766
    Mid Calder,Scotland
    The mass moto exhaust is designed for mid range grunt but I didn't expect such a drop in hp, (this is with baffle in though) I'm still trying to get info from mass themselves regarding wether I should run it without,(It's notably stronger with the baffle out) I don't have the originals anymore and as it's designed for the 950A it doesn't have the brings fitted for testing .
    #15
  16. opanos
    Aug 12, 2015
    403
    Rotterdam, Flatland
    Re run it then with buffle out and check results
    To be honest, i really doubt if all these exhaust systems are trully designed for anything.
    #16
    gearheadE30 likes this.
