In which Plaka builds a Cafe bike.
Discussion in 'Airheads' started by Plaka, Oct 30, 2018.
  1. NitroAcres
    NitroAcres MotoBiggots Suck Supporter
    Mar 28, 2010
    1,055
    A ChickenHouse in NorthGeorgia
    Iron Wood and add in some Brass cross pins, properly peen'd would be perfect.
    BMW851 likes this.
  2. infinityedge
    infinityedge Long timer
    Jun 27, 2013
    4,845
    Tuolumne County
  3. BMW851
    BMW851 Piston Broke
    Dec 4, 2010
    177
    Blue Mountains, Australia
    Plaka I've always figured a serious lack funds always tends to help create some fairly unique work arounds.
    Looking forward to see how it all holds together, good luck with it :lurk .
    No hard rock maple at all in your offcuts bin? or is what your planning all that's to hand, like the idea of locating pins either end, plus maybe some more laminating around the sections when fitted seems like an idea as well
  4. Kiwiabbo
    Kiwiabbo Been here awhile
    Apr 16, 2014
    782
    Why did you cut it in the first place and not just grind off the brackets??? Seems rather drastic with your method
  5. ME 109
    ME 109 Long timer
    Jun 25, 2009
    8,587
    Albury Australia
    This would be the only option then, unless you're planning on not actually riding your project to Starbucks.
    The shop would probably be interested in the pieces cut out, if matching tube size is an issue and also because the rear engine mounts are attached.
  6. ME 109
    ME 109 Long timer
    Jun 25, 2009
    8,587
    Albury Australia
    Ok, so you're going to ride it to Starbucks. I'm in. Is it a flat six blocks? Imagine the design potential if you could push it there and back.
  7. AndrewSJC
    AndrewSJC Out of round & off center, but not rusted through.
    Sep 11, 2014
    267
    San Juan Capistrano, CA
    I guess I don't understand this frame mod. Plaka, why did you cut out a section of tubing?
    infinityedge likes this.
  8. infinityedge
    Jun 27, 2013
    4,845
    Tuolumne County
    To get rid of the center stand and make it a short wheelbase r65 style frame.
    Or to make people cringe.
  9. infinityedge
    Jun 27, 2013
    4,845
    Tuolumne County
    Replacing welds with wood and epoxy is not only something you could easily advocate, but you’d also claim it was the superior choice while savaging anyone who disagreed.
    Just like the deist position is indistinguishable from the atheist position, Plaka being a lovable curmudgeon, Plaka joking, and Plaka being an ass is hard to separate.
    Cho_Matt, photorider, Brun and 2 others like this.
  10. sky44
    sky44 Been here awhile
    Jul 12, 2009
    691
    CO
    I thought you were a farmer...…
  11. infinityedge
    Jun 27, 2013
    4,845
    Tuolumne County
    I bet an epoxy soaked hemp stalk would be a good contender.
    sky44 likes this.
  12. infinityedge
    Jun 27, 2013
    4,845
    Tuolumne County
    Smoke the flowers not the lumber.
    Isn’t this mandatory training for living in CO these days?
    photorider likes this.
  13. misterpepper
    misterpepper Been here awhile
    Oct 28, 2015
    192
    Utah
    Are you planning to use the traditional "V" configuration for your dual engine swap? It seems to me that inverting the second engine would provide better cornering and possibly allow you to share a starter.
    sprouty115 likes this.
  14. Tiggum
    Tiggum Retired
    Mar 2, 2015
    460
    Nashvegas
    A seam ripper, known to every husband whose wife sews. Actually a pretty good tool for the task you describe. Just don't stab yerself.
  15. washpark
    washpark Adventurer Supporter
    Jan 31, 2013
    72
    Park City, UT
    Are you modifying the fairing?
  16. washpark
    Jan 31, 2013
    72
    Park City, UT
    Silver metallic Sharpies are available.
