Indian Scout FTR1200
Discussion in 'Road Warriors' started by cabanza, Nov 7, 2017.
  1. smcohio
    smcohio Equipment Tech
    Jul 31, 2016
    156
    Marysville Ohio
    Lol exactly
    scudrunner82 and gobux like this.
  2. markk53
    markk53 jack of all trades... Super Supporter
    Dec 20, 2007
    22,386
    Delaware Ohio
    Mid elevens ain't too darn bad!
    scudrunner82 likes this.
  3. smcohio
    Jul 31, 2016
    156
    Marysville Ohio
    For the power cruiser people
    and just an extra comment.. 8:58
  4. smcohio
    Jul 31, 2016
    156
    Marysville Ohio
    installed the RSD wheels and a set of Scorpion Trail II today, WOW what a difference...
  5. Florida Lime
    Florida Lime Long timer Supporter
    Sep 5, 2008
    11,126
    Florida, but soon fulltime in Robbinsville, NC
    Your pictures didn't come through.... :augie
  6. smcohio
    Jul 31, 2016
    156
    Marysville Ohio
  7. Mlazarus5388
    Mlazarus5388 Adventurer
    Sep 19, 2019
    37
    91020
    Running the same tires on stock wheels. Any notable advantage to the RSD wheels? Are they worth the dough?
  8. smcohio
    Jul 31, 2016
    156
    Marysville Ohio
    Well I only ran the stock tires on the stock rims but I will say that there is an extremely noticeable difference with rolling resistance and turning in. It felt so much more alive, I couldn't be happier.
  9. markk53
    Dec 20, 2007
    22,386
    Delaware Ohio
    Plus the part that really made you happy - it's only 88 dB A by the phone app! :zilla
    smcohio likes this.
  10. Timps27
    Timps27 Just here for the beer. Supporter
    Apr 17, 2019
    371
    Missouri
    The RSD wheels are 75% off, but they weigh the same as stock so it’s just a visual upgrade. They look great, and $875 for a set of rims is hard to pass up but I’m putting the $875 I wanted to spend on them into a fund for a Toce system.
  11. smcohio
    Jul 31, 2016
    156
    Marysville Ohio
    Yes they are the same weight but it is how the weight is distributed
  12. smcohio
    Jul 31, 2016
    156
    Marysville Ohio
    Darn, I won't be saving any lives with that low of decibels...:photog
  13. wpbarlow
    wpbarlow Long timer Supporter
    Jun 9, 2003
    18,862
    Central NJ
    How is it different enough? Considering that the wheel is unsprung weight, and unsprung weigh includes the wheel, tire, brake discs, calipers, axle, and lower fork sliders: I would think any distribution would not be very noticeable.
  14. Florida Lime
    Sep 5, 2008
    11,126
    Let's say you have 2 separate wheels that each weight 20 pounds.
    One wheel has an outer rim that weighs 15 pounds, with the spokes adding the other 5 pounds.
    The 2nd wheel has a 10 pound rim area, and 10 pounds supporting that rim.
    They both add the same to unsprung weight, but as each wheel rotates faster, the effects of the weight distribution will be more and more noticeable. I think the wheel with more weight further out will have a much greater resistance to change direction.
    smcohio likes this.
  15. Mlazarus5388
    Sep 19, 2019
    37
    91020
  16. wpbarlow
    Jun 9, 2003
    18,862
    Central NJ
    I don't know if that's true- don't know that it's false either. It seems...tenuous at best.
    Do the new rims claim to be made as you describe?
  17. Florida Lime
    Sep 5, 2008
    11,126
    No idea. :D
    That is the claim of the poster made, that the wheels and tires made turn in easier, since the weight was distributed differently.
    Even a heavier tire alone can make a difference due to the imcrease in rotating mass. Slower acceleration, more braking force required to slow the wheel, and more force needed to change direction. The further the mass from the center of rotation, the greater the affect.
    smcohio likes this.
  18. markk53
    Dec 20, 2007
    22,386
    Delaware Ohio
    That's pretty much the science involved. That's why gyroscopes and flywheels usually will carry most weight to the outside. Some flat trackers are using wheels with material left in when machining them, the extra material is at the perimeter to work as flywheel weight to smooth power delivery and maintain traction coming out of corners.
    If they can't add flywheel to the engine due to the rules they do it to the rear wheel.
    Less weight on the outside will take less power to rotate and have less resistance to turning in
    smcohio likes this.
  19. smcohio
    Jul 31, 2016
    156
    Marysville Ohio
    Here a simple way of putting things without me boring the living crap out of you with physics of rotational mass.
    1. Think of a 25lb weight on a rope. Put that weight out at your wrist and try to lift it. Move the weight to your bicep and lift it. You are still lifting 25lb but the closer you move it to your body the easier it is to lift.
    2. Take two wheels of the exact same weight, one with more weight to the outside of the wheel, one with weight to the inside of the wheel. Grab it by the axle and spin it, try to tilt the wheel from side to side. The one with the less weight to the outside of the wheel will be easier to tilt. Rotational mass wants to stay in the direction that it is moving ( stay upright ).
    All of this equals less rotational mass that the engine has to move and less force that you have to exert to lean into turns.
    Is everyone still awake? :snore
    DirtMerchant and Florida Lime like this.
  20. Subito
    Subito Been here awhile
    Mar 12, 2015
    495
    Wisconsin
    Good to see the American educational system is crushing it.
