"Indirect" battery charging
Discussion in 'The Garage' started by double_entendre, Jul 5, 2010.
  1. double_entendre
    double_entendre It's nothing personal; just your existence.
    Aug 11, 2008
    12,267
    Huntington Beach, CA
    I've got a Blue Seas fuse block hooked directly to my battery with huge ass(tm) cables. 6 gauge or something ginormous like that.
    I want to hook the battery up to the charger overnight tonight--just a standard 2 amp charger, not a trickle charger--and was wondering if I could hook the charger cables up to the positive and negative cables that are hooked up directly to the battery rather than to the battery itself, only because the fuse block is much easier to get to than the battery is.
    Any risk of damage I should be aware of?
    :ear
    Rancho
  2. Railbender
    Railbender Long timer Supporter
    Oct 3, 2006
    1,275
    NW PA
    "Any risk of damage I should be aware of?"
    No. What you want to do should be fine.
    :freaky
  3. markjenn
    markjenn Long timer
    Nov 9, 2003
    10,728
    Bellingham, WA
    Cables should handle it fine, but I'd be cautious about "fast charging" a motorcycle battery. The generally accepted guideline is that you should never charge a lead-acid battery at more than 1/10th its amp-hour rating, so for example, a common 14AH motorcycle battery, this would mean a maximum charge current of 1.4 amps. Even this rate may be somewhat detrimental to battery life. Slower is better.
    And if you're charger is not "smart" (reduces the charge as the battery approaches capacity), you'll probably overcharge and badly overheat it if you go 2 amps overnight.
    - Mark
  4. double_entendre
    Aug 11, 2008
    12,267
    Thanks both of ya's for the thoughts. It is a "smart" charger, so I'm safe there.
    Rancho
