Innovv C3 camera testing
Discussion in 'Equipment' started by Willy510, Aug 27, 2014.
  1. Willy510
    Willy510 Master of none
    May 23, 2011
    113
    Richmond,CA
    ***Group buy started over in the vendor section :thumb
    http://www.advrider.com/forums/showthread.php?t=1009833
    I've been looking for a dashcam style camera for my motorcycle for a bit after seeing a few accidents and I started talking to Rock at Innovv a little while ago about the motorcycle/action camera that he was developing over on the dashcam forums. He decided to let me do some pre-production testing on his new C3 remote lens camera. He sent me a unit to test and see what I thought of it.
    First off this camera unit and lens are pretty small and there is no plastic in either housing except for maybe the buttons on the recoding unit. Everything else is aluminum. The lens assembly is waterproof and the recording unit is not. The lens cable is 1.5 meters long.
    The comes full of mounts and cords and was surprisingly heavy when it showed up. Here's a list of what comes in the box
    1x Innovv C3 Camera
    1x Innovv C3 Lens
    1x lens mount
    1x USB cable
    1x AV cable
    1x Dashcam cable(4m)
    1x Camera bracket
    1x 3M Helmet mount
    1x 3M Dashcam mount
    1x Bar mount
    1x Head mount
    1x Microphone set
    1x Car charger adapter
    1x User manual
    Most of the mounts are useful and the 1/4-20 camera mounts are the most useful since they will let you use any camera mount that you may already have. I like using Ram mounts since they are pretty bulletproof and inexpensive. They don't come with the camera but you can find them almost anywhere.
    Rear facing mount on my Tuono
    I also used one of the included mounts with a plastic wedge to get the right angle for a helmet mount.
    The helmet mount works well for recording dashcam style footage but if you want footage that doesn't move around all of the time with wind buffeting and bumpy roads, it's best to find a stable place to mount the camera that's not attached to your wobbly neck.
    You get a choice of a 90 degree or 120 degree lens with the camera or you can buy both and swap them out for different shots. They both work great, I prefer the 90 lens for use as a dashcam and the 120 makes for good senic shots.
    You have a few options on how you can power the camera.Using the internal battery you can record for about 110 minutes. with an small generic usb external power pack you can go for a few hours depends on the size of the pack or you can plug it in to the usb adapter that takes 12v to 5v and record for as long as the memory lasts in single file mode or forever in loop recording mode.
    There is also a still picture mode but I haven't messed around with that function yet.
    You can set up the camera to act as a automatic dashcam when it's wired to the bikes power. When you turn your bike on it will automatically start recording and stop when you turn it off. The loop recording mode will record until the memory card is full and then it will start to overwrite the oldest files first. I get about 4.7 hours of video using a 32gb card so there's not much worry about losing a file that you want to keep if something happens. Also if your running on internal battery and you run out of power the camera will save the last file before it dies so that it doesn't get corrupted.
    I've been using it for the most part as a dashcam to record my daily commute and I haven't been gentle with it. The build quality seems to be very solid. It's also has a lot more uses that just a dashcam and I'll be posting those up as I test them over the next couple of weeks.
    So far everything is looking very promising, solid build quality and images :thumb
    I'm going to make a "how to" using the POV headset mount and remote microphone and I'm gonna mount it to a variety of firearms to get some real first person shooter video at the shooting range.
    Stay tuned for updates.
  2. fast4d
    fast4d Long timer
    Jul 27, 2007
    3,103
    Los Angeles, CA
    what is the expected msrp?
  3. Willy510
    May 23, 2011
    113
    Richmond,CA
    $129 for the camera with 90 degree lens and $139 for camera with 120 degree lens. You can the lenses seperate too, $30 and $35 each if you want to have both
  4. Willy510
    May 23, 2011
    113
    Richmond,CA
    New firmware update that smoothed out the video :thumb
    Just need to tune up and balance my Griso to get rid of some of the vibration.
    <iframe src="//www.youtube.com/embed/On8NOMefuqA?vq=hd1080" allowfullscreen="" frameborder="0" height="480" width="853"></iframe>
  5. Willy510
    May 23, 2011
    113
    Richmond,CA
    Got rid of some more vibration to the camera by using the shorter Ram arm mount and updated the camera firmware to latest release.
    Here are some day and night videos and a dropbox download link to the day video if you want to see it without Youtube compression.
    <iframe src="//www.youtube.com/embed/woRlls9LzYo?vq=hd1080" allowfullscreen="" frameborder="0" height="480" width="853"></iframe>
    Raw video file download
    <iframe src="//www.youtube.com/embed/CJUQIWP4RpY?vq=hd1080" allowfullscreen="" frameborder="0" height="480" width="853"></iframe>
    No streetlights just my headlight clip
    <iframe src="//www.youtube.com/embed/YocpN8MRy28?vq=hd1080" allowfullscreen="" frameborder="0" height="480" width="853"></iframe>
  6. Disston
    Disston ShadeTreeExpert
    Aug 31, 2009
    16,509
    Silver Spring, Md
    Will this be appearing in the Vendors section when It's ready for release? I think I want one camera for the front and one for the rear. So I have to by two separate units? I think wide lens on both would show the biggest field which is my concern. Tell Rock to make all the parts available individually so i can have custom mounts on two vehicles, maybe.
    I don't see a removeable memory so whatever you want to save has to be copied to the computer before it is written over? A removeable memory may give a little more versatility?
  7. Willy510
    May 23, 2011
    113
    Richmond,CA
    When they are ready to ship there should be an posting over in vendors section.
    If you want front and rear you'll want to order 2 units.
    You'll probably want to DIY your mount for your bike since the majority of the mounts are better suited for bikes with pedals or cars. There are good parts to use in the box but using a RAM mount or a few cheap but good DIY mount ideas that I'll be posting later that are better suited for security and vibration on a motorcycle.
    Comparison pics and videos of both lenses will be posted so that you can decide which lens is best for you.
    The memory is a removable microSD card, not included. With a 32gb class 10 card I get about 5 hours before it starts looping over the oldest files.
  8. Disston
    Aug 31, 2009
    16,509
    Silver Spring, Md
    Thanks. Please post here when the thread starts appearing in Vendors. I have followed this thread and should see it.
    #8
  9. refractor
    refractor Kick Start Biker
    Mar 24, 2009
    141
    North Eastern Missouri
    What is the purpose of having such a camera? Just to record your surrounding? Is it meant to compete with the Gopro type of cameras.
    How long does it record for?
    Not having a water proof housing and having a connector would limit it's appeal for many.
    I really cringed when you drove between cars
    #9
  10. Willy510
    May 23, 2011
    113
    Richmond,CA
    Main purpose for the C3 camera is as a motorcycle dashcam. If something where to happen during a ride, you'll have a record of it that no one can dispute. I ride to work everyday and I hope that nothing ever happens but if it does I don't want go through the "he said, she said" of what happened.
    Here's an example from my ride home the other day.
    Red Light runner.
    <iframe src="//www.youtube.com/embed/OYPilVCU6qA?list=UUmq8NdFgx7H2xP0cc00nfsg" allowfullscreen="" frameborder="0" height="480" width="853"></iframe>
    It will record forever if you have it set on loop recording mode and it will overwrite the oldest files once it is full. I get about 5 hours on a 32gb card before it starts overwriting files.
    It's not really meant to replace Gopro, You can mount this on your bike and wire it to switched power with adapter and it will start recording when you turn your bike on and turn off when you turn the bike off.The lens module is waterproof and the stock cable is 1.5 meters long and is extendable so you can hide the tiny recoding unit under your seat or in a saddlebag and the small lens module is barely noticeable when mounted. I'm sure a ziplock bag or tupperware container or a micro pelican case will take care of any waterproofing that will be needed for the recording unit until a purpose built case is made if there is enough demand.
    Sitting in traffic makes me cringe a lot more than splitting lanes. It is legal in California as long as you're not an idiot about it.
    After the 2:00 mark you can see that even dogs lane split here
    <iframe src="//www.youtube.com/embed/lQZbO5_q2Oo?list=UUmq8NdFgx7H2xP0cc00nfsg" allowfullscreen="" frameborder="0" height="480" width="853"></iframe>
    #10
  11. Willy510
    May 23, 2011
    113
    Richmond,CA
    Here's a comparison of the different lenses - 90 and 120 degree
    Cameras are mounted on each side of the headlight and are from the same location, the timestamps don't match because I wasn't paying attention when I set them.
    It also give you an idea of the quality of the images that you can pull from the video. Youtube kills the quality a bit with their compression
    90 degree lens
    120 degree lens
    90 degree lens
    120 lens
    #11
  12. refractor
    Mar 24, 2009
    141
    Man you have different driving conditions than I do. Most of the chance for damage is from deer. I don't think I could blame a deer for an accident.
    I never ride at night. Roads don't have the white line on the right.
    We meet may meet a vehicle in a mile or 4. No traffic lights.
    Most vehicles are older. Both of my cars are from the 80's. So are my motorcycles.
    Thanks for sharing your new camera
    #12
  13. highlight
    highlight Adventurer
    Sep 13, 2013
    47
    New England
    has been following this for a while. Hope that they have the product out asap.
    #13
  14. Willy510
    May 23, 2011
    113
    Richmond,CA
    I was told this morning that they should be ready to ship at the end of next week :D
    I was able to work a deal with the Innovv for a group buy, going to post up a ADV group buy for those interested in the next day or so.
    #14
  15. Willy510
    May 23, 2011
    113
    Richmond,CA
    Tried out the time lapse setting this morning on the way to work
    Warp speed Captain :eek1
    <iframe src="//www.youtube.com/embed/4c_9q1N_MV8?vq=hd1080" allowfullscreen="" frameborder="0" height="720" width="1280"></iframe>
    #15
  16. Honkey Cat
    Honkey Cat Tailights Fade!
    May 5, 2011
    1,438
    Sarasota, FL
    Im interested in a camera but im looking for one that when i have gone somewhere i want to record i can press a button and the last say 5 or 10 min gets saved
    #16
  17. Willy510
    May 23, 2011
    113
    Richmond,CA
    Haven't seen one with that exact feature yet, This one will save the last 5 or 10 hours depending on the size of the memory card you use
    #17
  18. Disston
    Aug 31, 2009
    16,509
    Silver Spring, Md
    I would like to hear more about the software that will be needed or used with this unit.
    Here is my agenda. I drive a Taxi Cab for a living. I could be driving a truck or anything else. I have been in a situation where other drivers and even witnesses lied about what happened. Fortunately I also had witnesses. It is a FACT, people see my Taxi Cab and they want to kill me. They want to blame me for anything that happens. Truck drivers suffer from the same prejudice on the road. Same thing with bicycles and motorcycles.
    Once I record something with the camera I have to be able to save that clip or time segment and later down load it to a computer for use in court cases or just to play back for the cop.
    I would like to be able to play the recording at the scene on my Tablet. My Tablet is a Samsung Galaxy. Then later down load to my MacBook Pro, not a Windows PC.
    Will included software with the unit do ALL of this?
    #18
  19. Willy510
    May 23, 2011
    113
    Richmond,CA
    There is no software needed to transfer files. The camera just produces .mov files, playable on any computer with video player software.
    Simplest way to a Galaxy tablet would be to take the microSD card out of the camera and put it in the tablet and copy the files to the tablet using the file manager in the tablet. You could also use the provided usb cable from the camera to a OTG cable, $5 on amazon, that plugs into your tablet and copy the files to the microSD in the tablet too.
    The best player for the files on your tablet is VLC player, free in the play store.
    #19
  20. Peanuts
    Peanuts Long timer
    Sep 12, 2009
    2,005
    Beautiful but often rainy North Yorkshire, UK
    I carry a spare SD card for my dashcam in my car. If I want to save anything I park up, swap cards then continue my journey. Then later I download the video to my PC and format the SD card then put it back as the spare in my car.
    #20
