inReach SE Powered Ram Mount
Discussion in 'Mapping & Navigation' started by dstock, Nov 26, 2013.
  1. Ogre_fl
    Ogre_fl Long timer
    Oct 13, 2004
    4,027
    Cook Bayou, FL
    Kind of old and I am sure you have gone through 9 or 10 bikes since this. :D
    How has the SMAKN converter held up?
    Does it have a constant parasitic drain on the battery or only when powering a device?
    #41
  2. krussell
    krussell Long timer
    Nov 19, 2009
    3,058
    Portland, Oregon
    Well, not 9 or 10, but there's been a few. That S10 got replaced with a GSA about 2.5 yrs ago. I have not hard wired the Delorme to the GSA, the Delorme battery live is really good so I haven't bothered.
    I ran it about six months without issue. They are really cheap, I figured I'd just replace it as needed. They are potted, so I think it would have ran forever unless vibration bothered it.
    I bought an eastern beaver 3 circuit solution, they make a kit specific of the S10. I put the smakn ' delorme on a switched circuit. I suspect there would be some drain, even when not powering anything.
    #42
    Ogre_fl likes this.
  3. chrisnack
    chrisnack Been here awhile
    May 1, 2012
    122
    Madison, WI
    Hmm glad I'm not the only one with issues... mine shows powered but I constantly slowly lose power while it's on and in the cradle. Annoying as the damn thing is powered.
    #43
  4. chrisnack
    May 1, 2012
    122
    Madison, WI
    That's probably my issue actually as I have 12v going to the inreach.. didn't realize it was 5v
    #44
  5. ztrab
    ztrab Long timer
    Jan 13, 2006
    1,118
    Tucson, Az
    The issue on mine is loss of contact between the cradle and the unit. It will urn on then lose power and drain the battery. It beater to leave it in power saver mode and not bother with the cheap-ass charging cradle. I carry an aux battery since it won't do you much good if you have been out on the trail for days and have zero charge left on the unit.
    #45
  6. chrisnack
    May 1, 2012
    122
    Madison, WI
    yeah i'm only concerned with a longer trip.
    Mine shows powered but it doesn't charge, makes no sense to me...
    #46
  7. fasteddie23
    fasteddie23 Been here awhile
    Mar 24, 2012
    130
    Danville, Ca
    Did anyone ever find an unpowered cradle that you use with a Ram Mount setup? I just want to carry it on my bars and use the internal battery, not worried about actual charging. I can't seem to find one that works anywhere. Weird that RAM offers like 6 different mounts for the older InReach but not the later one...?
    #47
  8. chrisnack
    May 1, 2012
    122
    Madison, WI
    Yeah, It's on amazon, I have unpowered on my MV and powered on the GS.
    #48
  9. chrisnack
    May 1, 2012
    122
    Madison, WI
    I redid my mount this weekend and did what krussel did
    #49
    krussell likes this.
  10. Texas Mud Taco
    Texas Mud Taco Ants in my pants
    Sep 2, 2016
    77
    San Juans
    I am trying to find a cradle (powered or non) for my DeLorme InReach Explorer. I have found some InReach cradles, but the ads have a caveat stating the cradle is for the Garmin InReach and NOT the DeLorme.
    Can anyone confirm that my DeLorme will/will not work with the Garmin cradles?
    #50
  11. chrisnack
    May 1, 2012
    122
    Madison, WI
    If it's the inReach SE, should be same thing just renamed. Don't think it changed, just got rebranded.
    #51
  12. Texas Mud Taco
    Sep 2, 2016
    77
    San Juans
    #52
  13. chrisnack
    May 1, 2012
    122
    Madison, WI
    Yeah that's definitely not the right now...
    yeah i'm not really seeing them anywhere.. that sucks... i need another one for my 3rd bike...
    #53
  14. Motorius
    Motorius Road trippin'
    Dec 7, 2016
    3,311
    Seattle & Phoenix
    I stalked the evil bay for months to score a couple of these things, and have yet to find a powered one, just the regular ones. I even did a search on the goog once i had the part numbers looking for retailers maybe still blowing some out from old stock with no luck (so i'll save you the time there).
    #54
    chrisnack likes this.
  15. Motorius
    Dec 7, 2016
    3,311
    Seattle & Phoenix
    at least one powered version new up for the Delorme Inreach on Amazon now.
    #55
    krussell and waylongway like this.
  16. GCecchetto
    GCecchetto Long timer
    Jun 29, 2013
    2,744
    Woodside CA
    I probably still have my old style powered mount if someone is interested in it. It’s modified so it has a USB plug on the end of the cord rather than the cigarette plug.
    I now have a Garmin inReach due to the not charging issue mentioned above. Mine kept getting worse to the point that it wouldn’t even change with a USB cable plugged into it, then failed altogether.
    #56
