1. eNewsletter Sign Up
installing motech crashguards
Discussion in 'The Garage' started by elijahst, Jul 18, 2007.
  1. elijahst
    elijahst Adventurer
    May 17, 2007
    41
    8250 feet, Colorado mountains!
    any installation comments? suggestions?
  2. bereahorn
    bereahorn Long timer
    Mar 26, 2002
    1,071
    N.E. Ohio
    If these are the ones sold by Twisted Throttle they won't fit properly on the front if you have an after market shock;according to their web site. I have a brand new set in the box but never got to install them as I sold the '01GS,so I don't have hands on knowledge. Regards.John
  3. greywolf
    greywolf Unpaved road avoider
    Apr 2, 2006
    1,406
    Evanston IL
    Crashguards are uninvolved with the rear shock. That would be the skid plate. The only error I seen anyone make is not to use enough washers on the large through bolt to keep the guards from touching the frame on either side. Use a pipe extension on the wrench to get the nut off that bolt and everything els is pretty straightforward.
    edit: Whoops! Wrong bike.
  4. Bentley
    Bentley Wannabe Adventurer
    Jan 15, 2003
    236
    Austin
    I installed the SW Motech guards on my 1100gs. I had heard that they would not work with aftermarket front shock (says so on their website AFTER I bought them). They weren't kidding. They will not work with Ohlins shocks due to the slightly larger diameter of the Ohlins front spring interfering with a bracket. I had a buddy do a simple cut and weld on the offending bracket ($20) and made it work.
    I don't know if this applies to an 1150, or if they have subsequently redesigned the guards.
    Ben
  5. bereahorn
    Mar 26, 2002
    1,071
    N.E. Ohio
    Thank you Ben. That's what I was trying to convey in my previous post. I just visited their site(Twisted Throttle) and they apparently have modified the original version because they now state the guards will work with Ohlins on the 1150GS.
