Ipad Mini 3 Plug Issues
Discussion in 'Mapping & Navigation' started by proslider777, Nov 15, 2017.
  1. proslider777
    proslider777 n00b
    May 3, 2016
    4
    Etowah, TN
    Anyone come up with a solution to keep the charger going? I seem to have intermitten problems with the plug connection failing to keep a charge going in rough adventure terrain.
  2. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    7,205
    Chambers Bay, WA
    Oooh. I always unplug my Mini in rough terrain. I plug it in only on paved roads and smooth gravel. The reason, as I guess you've found out, is avoiding wear-and-tear on the connection port. The only way to fix the port is to replace it. The cost of doing this is more than the value of the Mini3. You can buy a refurbed Mini4 Cellular on eBay for under $300. Might be your best option.
  3. proslider777
    proslider777 n00b
    May 3, 2016
    4
    Etowah, TN
    Yeah, I was afraid that would be the answer. I have mine in a zipper case which has foam sheets of varying thicknesses. Maybe I could wedge it in tightly with more sheets and come up with a way to stabilize the charger plug wire. Even thought about just gluing it in. My mini 3 is a refurb.
  4. ohgood
    Sep 21, 2010
    7,832
    alabama
    what about one of those magnetic connectors? rtv it in place?
