iPhone 7 camera damaged after using a handlebar mount
Discussion in 'Equipment' started by unit3890, Apr 24, 2019.
  1. unit3890
    unit3890 Been here awhile
    Jul 4, 2012
    340
    Chihuahuan Desert
    Has anyone else damaged the OIS (optical image stabilizer) on a phone due to vibrations from a handlebar mount?
    I believe that the camera on my iPhone 7 plus broke after using a ram x-grip mount on my klx400r, xt225 and v-strom 650. The grip was mounted to the motorcycles using the bolt adapter or u-bolt ram handlebar adapter depending on the motorcycle.
    The OIS doesn't stabilize the image which creates a wobbly effect and makes it impossible to take a good picture. I'll try to upload a video of it later since I upgraded to a galaxy s10 (it was time to switch back to Android).
    Has anyone else experienced something similar? I know there are mounts that claim to prevent this exact issue, but you pay for it $$$.
  2. AFRICA
    AFRICA Adventurer
    Jan 3, 2010
    23
    I think it's possible that the problem is not the mount. It might be the image stabilizer that's faulty.
    I had an iPhone 6 which did that since new. I sent it in twice, and both times they sent it back saying theres nothing wrong with the camera. If you keep it stable for a few weeks it corrects itself. But still makes it unusable for riding. I did a 7 day trip with no pictures as a result.
    Eventually they admitted to a weakness in the camera, and launched a global replacement campaign for the affected serial numbers. Problem solved for me.
  3. theregulator
    theregulator Shut Up and Ride Supporter
    May 26, 2002
    569
    Philly
    I broke the camera on two separate Pixel 2’s while mounted to the handlebars. Both replaced under warranty. The second replacement sold on Swappa, and I switched to a Samsung S8 Active. No problems since.
    slime likes this.
  4. foo
    foo Adventurer
    Jul 10, 2011
    57
    Sg
    Eatmore Mudd likes this.
  5. cblais19
    cblais19 Long timer
    Nov 3, 2017
    5,815
    NoVA
    Yup, I've damaged my 7 & X; after I got a TomTom & a Cardo with Hey Siri functionality I stopped using handlebar mounts.
  6. AdamChandler
    AdamChandler Ascending n00b
    Feb 29, 2016
    9,849
    Hanover, NH USA
    Perfect Squeeze + Buzzkill. Haven't destroyed a camera sense.
    Janus9 and Eatmore Mudd like this.
  7. spencermarkd
    spencermarkd Been here awhile
    May 10, 2017
    183
    Pullman, WA
    Broke two, one on a 6+ that I replaced myself, one on a ten that was replaced under applecare.
  8. BobcatSig
    BobcatSig Fresh Off The Couch Racing
    Aug 15, 2014
    4,099
    Protestlandia, OR
    Yup, killed my image stabilizer on my iPhone X by mounting it in a Ram X-mount on my KTM 690 Enduro bars.
    #8
  9. WJBertrand
    WJBertrand Ventura Highway
    Aug 5, 2013
    923
    Ventura, CA
    Wow, didn't realize this was possible. Does the damage happen even when not using the camera? I've used an iPhone 6 extensively with the Ram X-mount on the handlebars of my Super Tenere and never noticed an issue, but I just got a new Xs and sure don't want to screw it up!
    #9
  10. BobcatSig
    Aug 15, 2014
    4,099
    Protestlandia, OR
    Yes. It's the vibrations.
    Now, if your Super10 is mostly road focused; you'll be fine. If you're bombing washboard roads and rough dirt, expect to have problems.
    #10
  11. MotoChron
    MotoChron Got Dirt?! Supporter
    May 22, 2005
    1,549
    Tip of the Mitt
    Same thing happened to my 7plus. I stopped running my phone on the bars. I'll run my Duraforce Pro on the bike for GPS, but my good phone goes in my pocket now.
    #11
  12. Mulebiscuit
    Mulebiscuit Adventurer
    Mar 6, 2019
    17
    Upstate South Carolina
    +1 here ruined a pixel only 2 months old on x grip. Now old Motorola rides on bar for nav and good phone in pellican box on tail in foam insert.
    #12
  13. AdamChandler
    Feb 29, 2016
    9,849
    Hanover, NH USA
    Modern mobile phones that are premium ($500+) all have "Optical Image Stabilization" Best explained in my layman's way is is the image sensor sits on a moving plane. It will move side to side with the phone. This ALWAYS is moving even when the camera app is not triggered. This allows jitter / stutter when taking photos / videos to be reduced. Some cheaper phones or the GoPro 6/7 use "digital image stabilization" so no moving plane.
    Anyway, if your phone is mounted to a buzzy thumper / single (and maybe V-Twins depending on the age of the bike and vibration transfered to handlebars), this will destroy the OIS sensor.
    Here's the result:
    Under warranty, Apple has replaced my iPhone once with a failed sensor.
    I added this to my Perfect Squeeze iPhone mount - https://shop-hondogarage.com/collec...orcycle/products/buzz-kill-vibration-isolator and haven't had any future failures
    #13
    slime likes this.
  14. WJBertrand
    Aug 5, 2013
    923
    Ventura, CA
    Ok thanks for that information. I’ve only used the x-mount on the road, I don’t really trust it to hold my phone securely off-road anyway, so always stick it in a tank bag or pocket. Whew!
    #14
    slime and BobcatSig like this.
  15. szurszewski
    szurszewski Long timer
    May 26, 2010
    4,044
    Olympia, WA
    This happened to my iPhone X on a recent trip. It is only present on one lens/camera and I didn’t realize it was a hardware issue until now.
    #15
    BobcatSig likes this.
  16. Eatmore Mudd
    Eatmore Mudd Mischief on wheels.
    May 28, 2012
    4,141
    Wet side of WA.
    It's the frequency of the vibes that hurts the worst.
    #16
  17. unit3890
    Jul 4, 2012
    340
    Chihuahuan Desert
    #17
  18. unit3890
    Jul 4, 2012
    340
    Chihuahuan Desert
    I believe this is true because I didn't have issues on my thumpers. It broke after using the phone on my v-strom 650.
    #18
  19. Traxx
    Traxx Taxation is Theft Supporter
    May 14, 2016
    3,627
    Tejas
    I have had this issue with 3 different iphones and it has always been if I left the camera on. Stop - take a picture - remount the phone and go. I have not had it happen as long as I turn off the camera. Stop - take picture - turn off camera - remount and go.
    #19
  20. BobcatSig
    Aug 15, 2014
    4,099
    Protestlandia, OR
    For what it's worth, the x-mount did do a great job of keeping the phone secured on my 690. So it does work.
    Yup. And the bumps. And the rough roads. And the jumps. :D
    I did that, err... do that. Stop, take the picture, turn off the screen and go. I think the issue is whether the camera software running or not, the vibes still hammer on the hardware.
    #20
    Traxx likes this.
