IPhone Mount for my Tiny Stalk
Discussion in 'Battle Scooters' started by conchscooter, Jul 28, 2018.
  1. conchscooter
    conchscooter Long timer
    Feb 3, 2007
    3,681
    Florida Keys
    I am planning a trip Up North with my Burgman 200, and am faced with installing a holder for my iPhone which I use for mapping. The mirror stalk on the left is the obvious spot as the power cord comes from directly below. The trouble is the stalk is of a tiny diameter, 3/8s of an inch possibly.
    Does anyone know of a ram or other secure type mount that will clamp here in some fashion?
    48F03227-D960-446B-A03D-B9CC845FF096.jpeg 73B37B83-F6F6-41D5-ADBD-88CDD4A1F77B.jpeg
  2. Duck Dodgers
    Duck Dodgers Scared shiftless ! Supporter
    Sep 17, 2005
    1,058
    37.12° N, 120.8° W
    Quad Lock
    Sent from my iPhone using Tapatalk Pro
  3. cdwise
    cdwise Long timer Supporter
    Oct 27, 2010
    5,815
    Houston, TX/Breckenridge, CO
    There is an adapter you can get for the rammount U bolt to git it to a mirror stalk. GPS City sells them. If you need the U mount too there is a serious which includes the assort on Amazon
  4. CaptnJim
    CaptnJim Scooter Pilot
    Mar 1, 2013
    4,768
    Wandering (but based in the Tropical Tip of Texas)
    This is the one I ordered (GPS City via Amazon)...
    https://www.amazon.com/gp/product/B0012TWRAO/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
    ... but it snugs down to .5". Not sure if the mirror stalk on my GTS is thicker than the one on your B200. You could always put some non-skid or rubber around the stalk - that's what I did with a GoPro mount, as well. The X-Mount from RAM works great to hold the phone.
    Phone on the left, camera and an additional adapter on the right.
  5. Jim T
    Jim T Been here awhile
    May 7, 2004
    446
    Oregon
  6. CaptnJim
    Mar 1, 2013
    4,768
    Jim T likes this.
  7. conchscooter
    Feb 3, 2007
    3,681
    Florida Keys
    Thanks for the suggestions. Some studying is necessary obviously.
  8. gogogordy
    gogogordy Long timer
    Feb 25, 2009
    2,915
    Winchester, Southern California
    3531D7AC-2365-494B-AEFF-7DFA121473A7.jpeg I’ll second CDWISE’s input.
    RAM makes a plastic “reducer” for use with the U-bolt and I rocked that set-up for years on my Vespa, Genuine Rattler, as well as DR650without issues.
    That part looks like this:
    #8
  9. cdwise
    Oct 27, 2010
    5,815
    #9
  10. conchscooter
    Feb 3, 2007
    3,681
    Florida Keys
    So the ram thing with built fits round the 3/8” mirror stalk with the spacer. I wish they’d show it clearly in their pictures. We all know a 7/8 or 1” handlebar works ...
    #10
  11. cdwise
    Oct 27, 2010
    5,815
    Yes, I'll check which mount I have on what when I next go in the garage. I know on the Vespa I use the mount that goes at the base of the mirror but I think the BV has a mirror mount with reducer on it.
    #11
  12. gogogordy
    Feb 25, 2009
    2,915
    I used that same set-up on my BV350 as well....
    #12
  13. conchscooter
    Feb 3, 2007
    3,681
    Florida Keys
    Thanks.
    #13
  14. MarylandStrom
    MarylandStrom Long timer
    Dec 7, 2007
    1,224
    Beltsville, Maryland
    #14
  15. cdwise
    Oct 27, 2010
    5,815
    This is on my BV mirror stalk. You can see the adapter half ring inside theU bolt
    #15
  16. cdwise
    Oct 27, 2010
    5,815
    C8ABD127-5537-447A-A391-B9A5F56B6E38.jpeg 23CA7473-DF45-4B2C-B454-0D456FF16BD2.jpeg This is on my GTS with the ball mount that gets screwed in between the mirror stem and headset cover.
    #16
  17. conchscooter
    Feb 3, 2007
    3,681
    Florida Keys
    I ended up ordering the Quad Lock. I like the simplicity of the bolt on. Plus the waterproof cover. It also had a spacer to grab the mirror stalk which I would have hoped to avoid but it seems to mount solidly enough. The brake reservoir cover is a nice one for scooters where there is a reservoir on each side of the handle bars
    #17
  18. conchscooter
    Feb 3, 2007
    3,681
    Florida Keys
    It comes with the dreaded inserts:
    The base plate screws down nicely but the angle needs to be determined.
    It’s not on quite right (work beckoned. This was a parking lot installation after my commute) but eventually the whole installation is no more and intrusive than that:
    My colleague had already gone to work so I couldn’t photograph my phone locked in. It gets its own cover with the lock in the back and you can also get a silicone waterproof cover. Which feels clumsy but I’ll be glad to have it if it rains when I’m traveling.
    Total cost $100. So there is that. When not traveling it will be stored somewhere safe.
    #18
  19. conchscooter
    Feb 3, 2007
    3,681
    Florida Keys
    I like the clean uncluttered fitting. And you can pop it on and off with no trouble. Two things I have discovered. The poncho, a waterproof silicon cover does not allow finger touch control if you have a screen protector on the phone.
    Observing the GPS speeds I noted much greater Speedo accuracy than I expected. Pretty much spot on to 45mph and at 70 indicated the GPS was wobbling around 66 mph. I was quite surprised as it means I have been speeding more than intended.
    #19
