Is that an XT600? No way!
Discussion in 'Some Assembly Required' started by Battletoads, Mar 10, 2017.
  1. Battletoads
    Battletoads Adventurer
    Mar 9, 2017
    77
    So i figured i'd try to make an thread here, i have not seen to many builds like this, so im hoping for good ideas and feedback on my project :lol3
    It started out with an 91 3tb xt600
    But she was fat and started to look abit old. And it was like she was not able to bring me as long into the woods as i wanted too:muutt:icy
    So to skip the part u guys already missed out on, this is what i have done by now:
    -Frame cut in half-> 04 yz450f subframe fitted.
    -04 yz450f plastic/tank/seat/fotrests
    -husaberg fe 600 exhaust (ment for the orginal frame so its to low now)
    -pro taper handlebars,new levers etc
    -overhauled engine "ish" im running half a 3tb engine and half a 2kf (one half a crankcase of each) losing that useless external extra 5. Gear lube line. And fittet new bearings/piston etc.
    Plans:
    -Alloy front rim (xt 2kf) - not fitted yet
    -Ktm SX swigarm - not fitted yet, need new rear shock and rim
    -Pumper carb (from crf450 prob.) Still have to buy this. But i already have an grizzly 660 intake (fits perfect on xt600 for single carb convertion)
    -new exhaust mod
    Anyone have ideas/experience/questions around any of this? Please tell/show :smooch
    Update! Sx(02) Swingarm, exc shock and rim (08) since last time i also fitted a dominator exhaust and a 08exc headlight!
    Fitting the parts are now in progress!
    Bananapete and pennswoodsed like this.
  2. 515
    515 Been here awhile
    Dec 28, 2016
    131
    South Pacific Workers Paradise
    Looking good
  3. upnorthhillrod
    upnorthhillrod Been here awhile
    Mar 23, 2014
    146
    maybe switch to a wr tank? that thing looks cool but a big slide carb with a accelerator pump is going to be thirsty and
    kill that gallon and a half quick
  4. Battletoads
    Mar 9, 2017
    77
    Hah, yeah i have been thinking the same thing :clap yz tank is only about 6-7 liters, but there is also the issue with room under the tank, but hopefully the carb i get uses less space then the twin carb stuff going on there atm. I was thinking acerbis tank or something like that to rly get some room for fuel :D but carb first, tank issues later :p
    Thanks for your toughts!
  5. brownvv
    brownvv Been here awhile
    Sep 23, 2012
    965
    colorado
    more pictures! I have been thinking about removable subframe conversions allot lately so its nice to see one.
  6. Battletoads
    Mar 9, 2017
    77
    For what bike? :D
    Also this was the newest pic i had :rofl
    Im gonna post another with more subframe stuff
  7. Battletoads
    Mar 9, 2017
    77
    I guess im gonna have to take more photos :-)
  8. brownvv
    Sep 23, 2012
    965
    colorado
    xr200 with cr85. or xr600 with crf450. just day dreaming about it. I probably should have done it on my dr350 builds but its way too late for that now
    #8
  9. Battletoads
    Mar 9, 2017
    77
    Don't wanna brake your dreams, but atleast for the crf450, u will have some problems swapping the fuel tank, but there is prob ways around it :D
    Also! Useless upgrades (spoke covers)
    And maybe a better look of the xt
    And yes i bough the wrong decal's set 06 insted of 04. But i figuree since everything else just sort-of-fits why not..
    #9
  10. Battletoads
    Mar 9, 2017
    77
    Still just need an rear rim
    I also did a exhaust swap, sadly i have no pics of that atm
    #10
  11. tntmo
    tntmo Oops, I did it again.
    Jan 31, 2012
    1,318
    San Diego, CA
    It looks really nice, is that XT electric start?
    #11
  12. Battletoads
    Mar 9, 2017
    77
    Kickstarter, idk if it's possible to get an E-start to without swapping parts of the crankcase, never lookend into it :p
    Also i found a pic of the new exhaust,
    The sloppy mounted airfilter etc is going away when im installing the pumper
    #12
  13. kenny robert
    kenny robert Long timer
    Aug 21, 2015
    1,652
    south orygun
    nice work
    be sure and put in new du fork slide bushings
    and check the clearance for extra slop the low bushing that wraps around the stanchion tube is quite easy to reduce clearance with some shim underneath it
    the upper bushing below the seal needs the ends filed in order to do any adjustement
    #13
  14. Battletoads
    Mar 9, 2017
    77
    Where on the bike are you now? :p
    sounds like front forks to me?
    #14
  15. kenny robert
    Aug 21, 2015
    1,652
    south orygun
    the gas tank
    :hide
    #15
  16. Battletoads
    Mar 9, 2017
    77
    In that case my english is WAY worse then i tough :p instructions to comfusing, got leg stuck in the handlebars
    #16
  17. OzCRU
    OzCRU Been here awhile
    Feb 16, 2015
    949
    Sydney Australia
    Nice Conversion! :-)
    I'm guessing not road legal - just for playing in the woods?
    Electric start could be added, but only if you have access to the 'E' parts from a 90 or later model.
    You'll need a 30mm longer crank on the left side for starters.
    (I'm gathering parts for a TT600RE Belgarda conversion also with the FCR carb. will go with a milled intake, but have seen the 660 Raptor versions as well.)
    Great work so far - I'll be staying tuned. Keep the photos coming!
    :lurk
    #17
  18. Battletoads
    Mar 9, 2017
    77
    Well, it's plated now, but if i ever get pulled over thats prob the end of that :p
    But yeah i mainly use it to play in the woods :)
    Ah i was afraid of that, that the e-start convertion would take to many new parts to it being worth it :p
    Im gonna try to post more, i tend to forget to take photos :p
    #18
    OzCRU likes this.
  19. Battletoads
    Mar 9, 2017
    77
    I have not given up guys, im just about done collecting all the parts needed. Only need a rear sprocket for the exc rim :)
    #19
    OzCRU likes this.
  20. Battletoads
    Mar 9, 2017
    77
    So i ripped apart my rear tire tube AGAIN! So i started fitting the KTM swingarm, shock and rim (18") WITH a tire lock. Im still i progress at fitting stuff to be perfect, atm it's "bolt-on" fitted exc 15mm swingarm bolt in the xt's 16mm holes and what not and the shock is in the stock frame mount. So far it has been WAY more easy to fit then i first even hoped for :p and... the ktm setup is TEN kg lighter then the xt setup! 10kg less! And im getting a shock i can adjust in 3 ways + the tire lock :clap:clap
    As for now tho the seat hight is about 25mm lower due to the free sag without a rider. So if it's not possible to adjust the shock as it stands now i might make a new frame mount for it. But this is how it stands today :)
    Im also fitting a fcr pumper carb with a grizzly 660 intake, plan B is just to add ramair podfilters to the stock carbs. But im gonna finish the swingarm first :)
    #20
