Issue with R/R on Transalp PD10 (1997 Transalp 600)
Discussion in 'Japanese polycylindered adventure bikes' started by Adrian B, Aug 6, 2019.
  1. Adrian B
    Adrian B Adventurer
    Aug 12, 2013
    50
    Hi
    A bit of details/history first:
    For some reason, a while back the regulator/rectifier on the Transalp was not working properly. It was overheating and the bike would not start sometimes (as the voltage monitor/ voltmeter in the dash showed 11.8V -12.2V)
    I decided to put the the R/R from my 1989 AfricaTwin (RD03).
    The pinout of the two Rectifiers differ, as in the one from the Africa Twinhas 5 pins and the one on Transalp has 4.
    I've been using the Africa Twin R/R for a while, and noticed that when I start the bike (with the choke on) it pumps out 16.9V-17.1V.
    When riding (let's say 3500 to 4500RPM) it also pumps 15.9V - 16.9V or even 17.1V
    It depleted the battery of acid, almost to half. I've refilled the battery with distilled water, but it seems that now it's almost dry (again).
    Obviously, a new battery is required, that i'm not even doubting.
    But I don't know what type of R/R to get .
    To be more exact, my question to you guys, is: what other Regulator/rectifier can I fit to the Transalp 600 (1997) (PD10) ? Besides the original one which is the same for PD6 and PD10.
  2. plumer1kt
    plumer1kt Adventurer
    Feb 11, 2015
    1,340
    Hellas
    Where did you connect the fifth cable of the XRV R/R?
    That's the ground one that the R/R needs to regulate the voltage.
    The other cables are three (same color) from alternator-3phase and one +12v .
    Transalp R/R is grounded probably direct to the frame so does not need the fifth cable...
    Ground the fifth cable and check voltage readings....then replace your battery.
