I've got both the Inreach Mini and Spot X; ask me questions
Discussion in 'Mapping & Navigation' started by fhammond, Jun 7, 2018.
  1. HalcyonRider
    HalcyonRider peaceful, prosperous, carefree
    Aug 16, 2016
    75
    Just came off the COBDR using my inReach mini. It worked fantastically! There was one odd behavior I thought worth mentioning.
    If I wrote a message using the Earthmate app. Sometimes it would hang in the system and be sent very delayed. I never seemed to have an issue sending presets or receiving messages. But you can see in my track below the anomolies caused by the delayed messages. I knew when it was going to happen because the app would say "problem sending location" and ask if I wanted to wait for GPS or send anyway. I imagine if I selected send anyway, it probably wouldn't have tracked so bad.
    Overall, this was a minor issue because I wasn't in an emergency situation. And if I was I probably would be moving much.
    I'm very happy with the inReach mini.[​IMG]
    #61
  2. Buckee
    Buckee Scott
    May 17, 2013
    941
    Northern Neck of VA
    From my SPOT:
    1) All OK, just checking in
    2) All OK but will be late, no worry
    3) No emergency but send help
    The understanding is if she gets #3 once, it's mechanical help needed. Twice quickly means send med help.
    The unwritten #4 of course is the SOS button.
    #62
    dad2bike likes this.
  3. rider911
    rider911 Shortcut Navigator
    Sep 18, 2009
    1,244
    Australia
    Ive just bought the mini, and on the box it says "made for iPhone"
    Does anyone know exactly what that means?
    Are there functions on the Apple app that aren't available on the Android app?
    I was just about to tell Apple to shove their IOS dictatorship where the sun don"t shine
    #63
  4. ohgood
    Sep 21, 2010
    8,533
    alabama
    lol, that's marketing !
    #64
  5. motokeith
    motokeith Been here awhile
    Mar 29, 2012
    703
    Falcon, CO
    If you look carefully you will see that the Android robot is also on the back of the box, so fuck them too ;-)
    #65
    advmike.ca likes this.
  6. Ocho NA
    Ocho NA Been here awhile
    Sep 10, 2017
    169
    Austin, TX
    Will the inReach mini perform well if I have it inside my jacket's pocket?
    #66
  7. motokeith
    Mar 29, 2012
    703
    Falcon, CO
    I've been carrying mine in the chest pocket of my Klim badlands Pro and it has been working just fine. Unlike the SPOT units, the inReach Mini has an actual antenna appendage so I don't think it's as sensitive about being orientated a particular way like the SPOT.
    #67
  8. Menhir
    Menhir Been here awhile
    Mar 11, 2017
    141
    I use a similar set of messages:
    1) I'm OK. Just checking in.
    2) I've reached my destination.
    3) I need roadside vehicle assistance. No emergency. Send help. Remember to let them know it's a motorcycle.
    4) SOS
    I use the first one when I stop for gas or if I decide to go off-route. It's my way of letting Mrs. Menhir approximately where I am and that all is well. I'll check in a bit more often when I'm getting close to home so she can deduct if I'm going to arrive later (or earlier) than expected.
    The second one is when I've arrived at my campsite or hotel. There have been times, before SPOT, when I told my wife I'd call her when I got to my daily destination and I found that there was no service. This way, she doesn't worry.
    The third one is so she knows I'm personally OK, but I need a tow. Anything past that gets the SOS.
    My daughter likes checking the web map in when she knows I'm on the road. She calls it the "daddy finder." :-)
    #68
  9. trailrider383
    trailrider383 867-5309
    Jan 12, 2008
    4,599
    NP, ID
    The new one has an antenna.
    #69
  10. Roux-80
    Roux-80 Been here awhile
    Aug 21, 2011
    163
    quebec, canada
    With the inreach if you take the annual contract, like the safety plan, does the unused messages rollback the next month?
    #70
  11. max384
    max384 Bandaided Supporter
    Nov 23, 2011
    6,003
    Eagle Rock, PA
    With the ability to connect to my phone via the Earthmate app and being able to type out a message on the unit if the Bluetooth failed, I couldn't think of a good reason why I'd need presets. I never saved any presets, and when I stopped for the night, I texted my wife a regular message, filled her in on the day's ride, and she told me anything that happened that day on the home front. It was just like having cell reception, except that the messages were a bit delayed in comparison. To me, message presets on this device are a vestige of the past. YMMV though.
    #71
  12. Ocho NA
    Sep 10, 2017
    169
    Austin, TX
    It doesn't.
    #72
  13. Roux-80
    Aug 21, 2011
    163
    quebec, canada
    What are the tracking interval that can be set on the device? The safety plan is at 15$ a month in canada, no tracking included, but if you want it, its .15$ per tracking point so if I can set the tracking interval at 1 hrs, it wil be around 2.25$ a days for a whole big day of riding, still cheaper than the recreation plan, since I dont need tracking every time I go out.
    #73
  14. motokeith
    Mar 29, 2012
    703
    Falcon, CO
    The are actually two intervals related to tracking:
    Log Interval is how often the device records it's position in its internal log: 1 sec, 1 minute, 2 minutes, 5 minutes
    Send interval is how often the device reports it's position via satellite: 10 minutes, 20 minutes, 30 minutes, 1 hour, 2 hours, 4 hours
    Based on the behavior I've observed with my own device, I do believe it is the "send interval" that would dictate your .15c per track point. You can have the "log interval" set at high much higher frequency, like 1 minute, and that allows you to have a much more detailed and accurate track log that you can download from the device after the ride. Having the device paired to the Earthmate app on your phone, which I really recommend, makes it very easy to start/stop tracking and adjust these log intervals.
    #74
    HalcyonRider likes this.
  15. labenske
    labenske Criminal
    Dec 23, 2009
    92
    Shenandoah Junction, WV
    I've just picked up the inReach Mini. Did my first test this evening. When I'm logged into the inReach website I can see my track on the map. I see all the Tracking Points (every 10 minutes). My problem is that I've enabled the social site, but nothing shows up... it's public.
    Any ideas what I'm missing to get my tracking points to show up on the public MapShare site?
    #75
  16. motokeith
    Mar 29, 2012
    703
    Falcon, CO
    I took a guess that your mapshare name is the same as your name here and I see 7 tracks from 9/12 to 9/16
    #76
  17. AllSeasonRider
    AllSeasonRider Wandering, maybe a little lost...
    Feb 20, 2008
    1,756
    Los Angeles, CA
    I don't see a reason to include a breakdown/send help message as one of your three free ones, given how unlikely you'll need to use it. In the event you do need it, it's $0.40 to send (or free if you have one of the higher plans). If you need to think about if spending 40 cents before sending for help, you should probalby just stay home.
    I'll be picking one of these up soon, I think my three presets would be something like:
    1) Heading out now
    2) Stopped for the night
    3) Taking a rest, everything's ok
    3 of your presets are free to send, so that's the main reason to use them. I think you also get another 10 presets that are not free, but with how cumbersome it is to type on the device, they'd be useful to have in case you couldn't use your phone for some reason. For me, I would see keeping the phone on the bike (I use it for nav) and the device on me. If I got tossed from the bike, or fell down a ravine trying to take a roadside photo, or whatever, I'd be glad I could message easily on the device.
    #77
    max384 likes this.
  18. outdoorsman
    outdoorsman Lets Ride! Supporter
    Jan 19, 2011
    157
    Elk Grove, California
    This thread helped me made up my mind to get the Inreach mini. Thanks all!
    #78
  19. fhammond
    fhammond Been here awhile
    Sep 7, 2007
    361
    Bay Area, U.S.
    I’ve had to use the SOS button on my Iridium a few years ago and the experience caused me to change my third preset to “SOS you received was not for me. I am ok.”
    A few years ago, I came across a rider in Death Valley who’d crashed and was unconscious. I sent out an SOS from the Iridium which got help quickly but in the process, I also freaked out my wife who got my SOS. Ever since then, I’ve used the third slot as a way to use the SOS and quickly tell her that I’m ok.
    #79
    Bayner, ADVwxyz, max384 and 2 others like this.
  20. AllSeasonRider
    Feb 20, 2008
    1,756
    Los Angeles, CA
    That's definitely a good preset to have - not because it will be used often, but the need to get it out quickly is important. That said, I'd still choose to have that as one of my 10 non-free presets since it will rarely, if ever be used.
    #80
