1. eNewsletter Sign Up
Jim Davis/easternbeaver.com
Discussion in 'The Garage' started by MArecycling, Jul 13, 2007.
  1. MArecycling
    MArecycling n00b
    Nov 15, 2005
    8
    Just wondered if anyone has installed one of the H-4 relays on an R1150 BMW. If so, what were your feelings on the kits effectiveness?
  2. jdiaz
    jdiaz .
    Feb 27, 2002
    32,448
    Flyover State
    I haven't used Jim's kit (I made my own), but if you run higher-wattage bulbs than stock, you need relays to keep that handlebar switch from melting. Jim's kit just makes the job easier.
  3. Jamming
    Jamming Desert RAT
    Sep 7, 2005
    3,085
    Buckeye AZ.
    I've used Jim's stuff. Good stuff. After a couple of emails he sent me what I needed and it worked out great.
  4. rdsmith3
    rdsmith3 Long timer
    Apr 3, 2006
    1,422
    NW NJ
    I have been using one of their relays for several years along with a 90/100 watt headlight bulb. It works great and is easy to connect. I do not have to worry about all that current draw going through the headlight switch because it is pulling right from the battery via much heavier gauge wiring and a direct connection. Using a relay is the best way to go for a headlight upgrade, and Eastern Beaver makes it easy to do.
    (I have no connection with the company -- just a satisfied customer.)
