Just A Tool Tube on my 8GS
Discussion in 'Parallel Universe' started by Lost Roadie, Mar 18, 2009.
  1. Lost Roadie
    Lost Roadie Rider Supporter
    Oct 15, 2006
    3,886
    Sequoia National Forest
    Since my Vario Bags are being retired after just 6 weeks [​IMG], now going to a lightweight camping setup with no panniers, I needed a way to carry tools without having a bag on the seat. Bouncing between inner city and camping adventures I want to have all my tools with me all the time, and not have to remove them.
    The isn't exactly an original idea, using a PVC tube for tools, but this is what I came up with to carry all the tools I need on the road to do basic maintenance and adjustments, plus in the Pelican 1300 there's spare tubes, patch kit, air gauge, and Slime air pump that will move to the dry bag when camping.
    All purchased at Lowe's
    3" x 13" PVC Tube
    3" end cap - "welded" on to the tube using special PVC cement
    3" closable "tester" cap, rated for high pressure sewage lines
    10" aluminum "L" bracket or whatever you call it ( I threw away the receipt)
    pipe clamps
    black spray-on rubber coating
    It might not win any beauty contests, but it's very secure and blends it nicely, or will after it gets dirty!
    [​IMG][/quote]
  2. M N B
    M N B would rather be riding
    Nov 26, 2008
    1,261
    San Jose, CA
    You should get one the same size as the exhaust, paint to match and mount it at the same angle. :evil
  3. GreyDR
    GreyDR Been here awhile
    Nov 8, 2006
    326
    St Paul, MN
    Why? ChiTown...looks great, very functionable. Good job.
  4. onefastrph
    onefastrph Shut up and ride.
    Apr 30, 2006
    291
    Ocomukowonowaukesha, WI
    I used one of these on my Strom. Not quite as big as yours, but I didn't have to fabricate it either. Just zip tied it to the inside of my pannier rack on the non-exhaust side. Welding rod tubes also work well, and are watertight.
  5. John Spartan
    John Spartan Middle Age Crazy
    Feb 22, 2009
    46
    Red Deer, Alberta, Canada
    Nice piece of work! Did you need to add any foam rubber on the inside to keep stuff from rattling around or is the tube pretty much packed from end to end?
  6. pbansen
    pbansen Hosehead Supporter
    Jul 8, 2001
    437
    Reno, Nevada
    That looks great! I have a similar tube mounted inboard of the left pannier on my Strom. Holds a lot of stuff that you'd just as soon not mixed in with the clean stuff.
    Nice job!
  7. Lost Roadie
    Oct 15, 2006
    3,886
    No I didn't do anything inside, it's pretty well packed. Most of the tools are split up between two pouches in the tube to keep the rattling down.
    Thanks, just recyclin' good idea's shared on ADV! :deal
  8. bomber60015
    bomber60015 Hold fucking fast Supporter
    Sep 11, 2008
    77,295
    Chicago-ish
    Great minds run on parallel tracks . . . . . .
    and so do ours ;-}
    #8
  9. Singletrack_mind
    Singletrack_mind Cave Man
    Aug 29, 2008
    498
    Northern New Mexico
    A good idea for sure, and decent looking. You must have some confidence in that expansion plug though, I'd be worried a bunch of wrenches knocking around in that tube would eventually loosen it up & dump the contents. I understand the glued on end cap is better looking from the back of the bike than the butterfly nut & expansion plug, but I'd feel better orienting the tube the way the Triumph rider did.
    #9
  10. Lost Roadie
    Oct 15, 2006
    3,886
    Nice lookin' bike you got there bomber!
    I do have confidence in it...
    I did some testing in the store by putting a plug in a 3" x 4' tube, then taking a 2" x 4' tube and dropping it in the 3". About the third time I did this is when a clerk came over, (looking horrified) and explained to me that this plug (that didn't budge) was rated for high pressure sewer systems. It seems incredibly strong.
    I guess we will find out next week in Arkansas if my calculations are correct. :evil
    #10
  11. Bigem
    Bigem Long timer
    Aug 30, 2007
    2,824
    Qld
    Mines a little different but works nicely
    #11
  12. PackMule
    PackMule love what you do
    Aug 8, 2005
    19,493
    New Hampshah
    Nice. I've got my tools in a fenderbag strapped to the rear rack, but want to move them so I can put a topcase on the rack for commuting.
    I'll have to look around and see what I can come up with for mounting without that little rail that you have. Also, I'll definitely have mine facing upward, just in case.
    #12
  13. bomber60015
    Sep 11, 2008
    77,295
    Chicago-ish
    Thank you Chi! I dig it muchly . . . . . .
    #13
  14. Bucko
    Bucko In a parallel world
    Mar 20, 2004
    831
    South Coast, CA
    I've got a lot of tools stashed under the seat, but you've got me innerested. I'm going to look for space behind my right side Jesse rack when I get home.
    #14
