Kartman´s 660 LC4 Rally Replica
Discussion in 'Thumpers' started by *kartman*, Apr 21, 2014.
  1. jasper74jasper
    jasper74jasper Adventurer
    Apr 4, 2007
    21
    Fantastic!!!!!
  2. jasper74jasper
    Apr 4, 2007
    21
    Fantastic!!!!!
  3. *kartman*
    *kartman* GO Bacon GO !
    Dec 29, 2008
    1,051
    Cottbus, Germany
    Some light in the pipeline ;) I want to do the Hardalpitour, but still no team yet :(
    Street legal Duo Lux 90mm LED low beam (23W ~ 2000 Lumen)
    Street legal high beam 50W ~ 3500 Lumen
    Evil Invader likes this.
  4. *kartman*
    Dec 29, 2008
    1,051
    Cottbus, Germany
    Lights arrived :) Just need to make a holding bracket for them...
    Some photos to compare ;)
    Stock TRIOM High Beam
    LED Low Beam
    LED High Beam :D :D :D
    joe cool likes this.
  5. tileman
    tileman Long timer
    Mar 15, 2007
    2,160
    Melbourne, OZ
    The low beam has a nice cutoff. Nice find.
  6. *kartman*
    Dec 29, 2008
    1,051
    Cottbus, Germany
    I made a mounting plate to carry the lights, but there is no way to fit the low beam into the bike :( It´s just to big, tried every possible way but the lights would stay way to far out front and there would be no clearance to the front fairing. So I can´t take the LED low beam. My new solution would be to cut the original TRIOM headlight in half and take one part (with a 55W Osram Nightracer instead of a 35W HS1) for the low beam. The LED high beam will then be fitted right next to it, sitting on a traverse over the oil cooler.
  7. *kartman*
    Dec 29, 2008
    1,051
    Cottbus, Germany
    Ok so this setup would work for the moment. What do you think ?
    I just don´t know how to set the high beam heigth now :twitch But maybe it will be fine as it is (need to check...)
  8. *kartman*
    Dec 29, 2008
    1,051
    Cottbus, Germany
    60mm inlet Akras are for sale, these two will be the new project ^^ I just need to cut and weld some pipe elbows and redesign the part from the footpegs to the exhaust pipes. The new 52mm inlet Akras will fit the 50mm manifold with a 52x1mm pipe.
  9. *kartman*
    Dec 29, 2008
    1,051
    Cottbus, Germany
    So this will be my setup for now. When participating the Hardalpitour, I may can install a second 30° high beam LED light and replace the H4 Triom part with it. On the photos the LED just is on 40% due to a flat battery ^^
  10. *kartman*
    Dec 29, 2008
    1,051
    Cottbus, Germany
  11. *kartman*
    Dec 29, 2008
    1,051
    Cottbus, Germany
    Just mounted the Akras to check my opportunities for the build. I need enough clearance to the swingarm, luckily the carbon clamps are asymetrical and I can play a bit with that. The alloy bushings are also designed to get a bit of a twist and the gap between the exhausts will be a bit wider at the front than at the end (or bottom and top). Tried both versions as to see on the photos. I´ll need to take out the rear wheel and remove the linkage from the swingarm and try what´s the best solution ... and in the end I´ll also need to to the fast and easy work of building two custom exhaust pipes :jack
    stupot and josip01 like this.
  12. DaniGAS
    DaniGAS Been here awhile
    Aug 8, 2011
    177
    lleida city
  13. Jabba600
    Jabba600 WA Adventurer
    Nov 22, 2010
    673
    Perth WA
    G'day guys any of you 660 owners wouldn't happen to have a spare head gasket by chance ....?
    Part number-58530036100
  14. tHEtREV
    tHEtREV Encouragement award recipient. tEAM iDIOT.
    Apr 14, 2007
    13,258
    Middle Park, Brisbane, Australia
    I was going to say Boltons have one in stock, but then I saw the $333.60 price tag...
    Jabba600 likes this.
  15. *kartman*
    Dec 29, 2008
    1,051
    Cottbus, Germany
    There are various to order in germany for about 100-130 Euro
  16. Jabba600
    Nov 22, 2010
    673
    Perth WA
    Do you have a link to the company who sell them mate ..?
    Lol I know right bloody hell !!! For a head gasket lol
  17. *kartman*
    Dec 29, 2008
    1,051
    Cottbus, Germany
  18. Jabba600
    Nov 22, 2010
    673
    Perth WA
    Thanks mate
  19. *kartman*
    Dec 29, 2008
    1,051
    Cottbus, Germany
    Here´s a possible solution of mounting the Akras with enough clearance to the swingarm. What do you think ?
    KEELAYMONSTER likes this.
  20. *kartman*
    Dec 29, 2008
    1,051
    Cottbus, Germany
    Started with the exhaust pipes, what do you think ?
    DC950, VEXX, stefanbuckowitz and 5 others like this.
