Kawasaki F7 175cc Thread
Discussion in '2 smokers' started by the_doc, Mar 4, 2014.
  1. sjc56
    sjc56 Long timer
    Oct 26, 2006
    2,283
    Broad Brook CT USA
    I did replace those already.
  2. Westcoasthumpin
    Westcoasthumpin Been here awhile
    Jul 20, 2016
    637
    Palm Springs of Washington
    Float level too high?
  3. RockyRue
    RockyRue Long timer
    Dec 19, 2008
    2,805
    On the carb, there is the main jet holder, is it tight, does it have a sealing washer?
  4. RockyRue
    RockyRue Long timer
    Dec 19, 2008
    2,805
    1972 F7 with stock everything and well setup with a top speed of 65.5 mph
    Nearly 9,000 rpm with stock gearing.
  5. sjc56
    sjc56 Long timer
    Oct 26, 2006
    2,283
    Broad Brook CT USA
    Yes. I just did about 30 miles on it and now it ran almost fine, only issue it will not pull red line, stays about a thousand under. I have been riding my 78 Honda XL125 and getting on the old F7 is like riding a super bike the odd thing is they both top out around 60.
  6. RockyRue
    RockyRue Long timer
    Dec 19, 2008
    2,805
    Heading up to 5000' with nearly 100F weather.
    Currently running a 107.5 main, should I drop to 105 or 102.5? or even down to a 100?
    Then it says online, raise the needle clip 1
    and one turn out on air screw.
    Or do I run it and see how she does
    Making the changes are pretty easy, so not to worried
    ordered 100, 102.5, 105, 107.5 and 110 jet kit so easy.
