    Dismiss Notice
Kawasaki KX 500 Adventure Bike
Discussion in '2 smokers' started by rednkarch, Apr 21, 2020.
  1. rednkarch
    rednkarch Adventurer
    Jan 5, 2017
    48
    New to the site, but not bikes. This recent creation stemmed from riding a KX500 desert race bike in the mountains and deserts of west Idaho. That bike was so easy to ride fast I couldn't help but switch from my trusty WR450. So... long story short I sold the yami' and bought an OK, but poorly put together KX 500. Now realize this build would not be possible w/o my best friend who's been a part of KX guru's who have been building "front cover" bikes for racer-x, motocross action and the like. He knows the intricate issues with these bikes and how to make them work, I just did the complete tear down and reassembly while he guided me on smart parts/upgrades and sourced the custom parts. I'll tell the rest of the story in pictures as i get time to upload. Enjoy.
  2. rednkarch
    Jan 5, 2017
    48
    110.jpg the bike right after I brought it home
      File size:
      390.8 KB
      10
    Bitingdog and aptbldr like this.
  3. rednkarch
    Jan 5, 2017
    48
      File size:
      348 KB
      10
  4. rednkarch
    Jan 5, 2017
    48
    Ater a weekends worth of work we're down to a box of parts
  5. rednkarch
    Jan 5, 2017
    48
    063.jpg Inspection time - needless to say it looked OK when purchased, but old bikes always tend to have a few "secrets" to pry out of 'em
  6. rednkarch
    Jan 5, 2017
    48
    065.jpg more broken parts - thankfully I had a plan and the factory brakes and wheels weren't a part of it :)
      File size:
      317.6 KB
      10
      File size:
      373 KB
      13
  7. rednkarch
    Jan 5, 2017
    48
    090.jpg Just a random picture of a 1,000 I took during the tear down. One piece of advice - when you are re-building old bikes you can't take enough pictures during disassembly. Besides this I had a bunch of plastic containers with lids that I used to mark and store parts for cleaning/reuse if needed (though I did end up replacing almost everything the containers were great for keeping it all together).
  8. rednkarch
    Jan 5, 2017
    48
    Part of the disassembly period was to mark, clean and re-sell some of the parts I didn't need like the forks, wheels, and such. This build was done as economically as I could, but doesn't mean it was cheap - all the "savings" went into putting in the best parts to increase performance and longevity.
    #8
  9. rednkarch
    Jan 5, 2017
    48
    #9
    spokester likes this.
  10. rednkarch
    Jan 5, 2017
    48
    Parts start to come in and reassembly of minor elements while I waited on engine/suspension
    #10
  11. rednkarch
    Jan 5, 2017
    48
    #11
  12. rednkarch
    Jan 5, 2017
    48
    20180727_220340.jpg The bigger re-assembly. I'm starting to get excited as it's sort of looking like a bike again!
    #12
  13. rednkarch
    Jan 5, 2017
    48
    20180711_053308.jpg FYI - there's always a little install, test, remove when your building a bike. I had to pre-fit the 2008 KLX 450 forks in the partly stock triple clamps and had to install/remove the swing arm a couple times to get it all to work right.
    #13
  14. rednkarch
    Jan 5, 2017
    48
    20180707_083601.jpg more tear down and re-building. On a side note I wanted to have a rear rack (which didn't exist), because of this I was concerned with braking the factory motocross sub frame so thanks again to my buddy who sourced a great guy out of Europe who made a few replacements out of much stronger aluminum and better welds.
    #14
  15. rednkarch
    Jan 5, 2017
    48
    20180727_220824.jpg one of the many mods was to fit modern Kawasaki KX 450f brakes. This required cutting off the old post that's welded to the frame, then drilling and tapping a new hole for the KX450 brake lever. Just one of a myriad of little things that made this a complete "package" when it was all done.
    #15
    Bitingdog likes this.
  16. rednkarch
    Jan 5, 2017
    48
    1495294983101_0358680065_2c3e9e66.jpg Again - more parts to repair. My buddy completely re-built the old oil drain plug by machining out the old threads and welding in and threading in a new one.
    #16
    mikeysduck likes this.
  17. rednkarch
    Jan 5, 2017
    48
    1495297938894_0980151423_2c3e9e66.jpg One other "small" change was to mill off the face of the side case and weld on a ring that allows using a KX450 outer clutch cover - no more having to strip down the side of the engine to check/change clutch plates :)
    #17
  18. rednkarch
    Jan 5, 2017
    48
    1532381851071_0431219251_2c3e9e66.jpg another item was to modify the highway dirt bike hand guards to work with flex bars (less vibes in these bars).
    #18
  19. rednkarch
    Jan 5, 2017
    48
    1535574907564_0240903426_2c3e9e66.jpg one other fun part was that my buddy Alex worked with TMR (Tom Morgan)racing to cut the head and install a chain saw decompression mechanism - no more hard kicks (not that i needed it, but just in case)
    #19
    spokester and mikeysduck like this.
  20. rednkarch
    Jan 5, 2017
    48
    20180727_220802.jpg Well by now most of the parts are here in one form or another. With winter in full swing and all new clean parts I was able to pull some shenanigans and build this inside the house w/o getting killed by the wife.
    #20
