    Dismiss Notice
Kawasaki Versys-X 300
Discussion in 'Japanese polycylindered adventure bikes' started by shyam334, Nov 8, 2016.
  1. SoManyFish
    SoManyFish Been here awhile
    Apr 18, 2017
    785
    Canada
    LOL
  2. SoManyFish
    Apr 18, 2017
    785
    Canada
    They are, and they aren't. I have two broken plastics on my Versys-X and TBH I do not even know how they broke. They are ridiculously expensive to replace.
  3. SoManyFish
    Apr 18, 2017
    785
    Canada
    Glad to hear the inexpensive stand worked out well for you! The OEM unit is well-made but, as you know, it is also a tad over-priced. AFAIC the centre stand for Versys-X is a must-have item for changing tires, fixing flats, chain lube and slack adjustment, solo oil level check, long-term storage, etc.
  4. MJS5761
    MJS5761 Adventurer
    Feb 26, 2018
    53
    Parker, CO
    SW Motech is excellent and it does not roll forward easily, and much lower cost than OEM. I had one on my old 04 DL-650 also with no problems. Center stands are a must in my opinion for ease of maintenance and storage in the garage. Upright takes much less space than leaning on side stand. Versys x with SW Motech center stand.jpg
  5. gn83tm
    gn83tm Been here awhile
    Nov 7, 2015
    176
    Western IA
    I hold the bike vertical and look in the window...
    CRP6001 and Bt10 like this.
  6. gn83tm
    Nov 7, 2015
    176
    Western IA
    Didn't realize I was starting an oil discussion. Enjoy your center stands ;)
  7. Ken in Regina
    Ken in Regina Long timer Supporter
    Sep 12, 2010
    2,221
    Regina, SK, Canada
    You must have mighty long arms. My arms would need to be nearly a foot longer to be able to hold the bike vertical and bend far enough to see the sightglass.
    ...ken...
  8. Ken in Regina
    Sep 12, 2010
    2,221
    Regina, SK, Canada
    Ummm... that's erl.
    ...ken...
  9. jfauerba
    jfauerba Been here awhile
    Dec 18, 2015
    456
    Asheville, NC
    Here is how I check the oil:
    1) take a harbor freight free flashlight and velco and mount it to the right footpeg which makes it almost pointing to the window.
    2) put small block of wood under kickstand so bike will be almost vertical but still leaning on kickstand. If I feel it is a little too far upright, I will hold on to the bike as I walk onto the other side. It would be better to find smaller piece of wood.
    3) sit on the ground, still pushing bike towards kickstand if needed, make sure I have a good view of the oil window.
    4) grab handle bar and something on the rear, forgot what, and slowly pull the bike upright until I feel it is balanced keeping in mind to to pull to far, just enough that don't really need pressure eith direction to keep it up.
    5) look in window.
    6) push bike back on kickstand, add oil if needed, repeat check.
  10. Fuzzy74
    Fuzzy74 Been here awhile
    Mar 6, 2009
    698
    Cumberland Plateau in Tennessee
    Get a center stand. All you need then is flat ground.
    7thson likes this.
  11. rvarela
    rvarela Adventurer
    Nov 23, 2018
    25
    Gondomar
    +1 on the SW-Motech centre stand. Works nicely for me
  12. jfauerba
    Dec 18, 2015
    456
    Asheville, NC
    I have a center stand but two issues:
    1) Got a china one and lost the spring on the first day ride with it so now it is ziptied up. Will only use it for emergencies on the road.
    2) Bike was lowered so was really hard to get it on the center stand. Have to roll the back whell on a board to get it on center stand.
  13. twaldron
    twaldron Dudeman
    May 29, 2007
    549
    Dallas, TX
    I do that on my DS’s. On my Vx and Scrambler I installed center stands because, on those bikes, having one just isn’t a negative.
    Bullwinkle and Ken in Regina like this.
  14. SoManyFish
    Apr 18, 2017
    785
    Canada
    It seems like a lot of work.
  15. Lesharoturbo
    Lesharoturbo Nerdly Adventurer
    Mar 23, 2009
    3,042
    Austin TX
    I'm 6'7". I just hold the bike (KLX650C) vertical and squat down to see the oil level. 2 second to check.
    I know, not helpful
    SoManyFish likes this.
  16. Ken in Regina
    Sep 12, 2010
    2,221
    Regina, SK, Canada
    Completely off this subject... I think you may have a minor error in your signature line or whatever it's called. Yeah, I read them. They're often quite interesting.
    Should it be "Lesharoturbo" instead of "Lehsaroturbo"?
    Yes, picky, I know.
    ...ken...
  17. Lesharoturbo
    Mar 23, 2009
    3,042
    Austin TX
    Yep
    Fixed, just for you.
    Ken in Regina likes this.
  18. David JM
    David JM Been here awhile
    Dec 2, 2017
    170
    Anacortes Wa.
    Another Use for Apache 3800 top and side cases. If your out in the middle of nowhere and you get a flat and you don't have a center stand and there are no stumps, logs, or large rocks around to put your bike on top of to patch your tire, you can use your 3800 case like a stump. First remove it from the bike, then you might have to pile up some dirt under it to get the right height and then just lift your bike up on top of it. The case will hold the weight of your bike easily, but they don't like hot exhaust pipes. If your not able to lift the bike, then with the side stand in the down position you can grab the left handle bar grip and the right side of the back part of the seat and pull towards you to lean the bike over enough to slide the case under far enough to keep your back wheel off the ground. The bike will be resting on the case, front wheel, and the side stand. My tail case has I bolts on the lid, I would probably use them to tie the bike down, or tie the case to the bike, but I would much rather just use my center stand.
    Fuzzy74 likes this.
  19. BAGSTR
    BAGSTR One Project a Day
    Jul 8, 2006
    681
    San Diego
    Liking:
    Waffle Grips
    Adjustable Levers
    Removed Bar Weights
    Crate on rear Rack
    5-8,000 RPM
    Adjusted Windscreen angle using thick nylon washers and rubber washers
    Dissing:
    Child’s Seat - Sixth week of waiting for Seat Concepts High Comfort
  20. SeatConcepts
    SeatConcepts Adventurer
    Dec 27, 2018
    54
    Caldwell, Idaho
    Hello!
    We apologize your order has been taking this long. Unfortunately, we are behind on orders due to the amount of orders we've received over the past few months and not having a full enough team to keep up with all the orders. We can definitely provide an order update (if you've ordered directly from us). If you're interested, please provide your order number so we can look up your order in our system and give an estimation of when it might be shipping.
    Thank you!
