Kawasaki Z650 / 1100
Discussion in 'Some Assembly Required' started by Bevelheadmhr, Nov 3, 2019.
  1. G 981
    G 981 Been here awhile
    Sep 7, 2010
    986
    West of Glaschu
    #61
  2. Bevelheadmhr
    Bevelheadmhr Been here awhile
    Mar 16, 2013
    675
    Cheshire, UK
    With the cylinder block back from the machine shop, the engine assembly could finally continue. Sadly I cant go to my mates workshop (due to our lockdown) where he's doing the build, but he did send me a few pics of progress. Also the head has been rebuilt with new valves, seals and guides..
    #62
  3. Bevelheadmhr
    Mar 16, 2013
    675
    Cheshire, UK
    It took awhile but finally got hold of a good set of GPz1100B2 cams, which allowed the top end to be finished at last. The stator and rotor and starter clutch were bought new, as used ones are both expensive and rare. A homemade manual cam chain adjuster was also fitted. The outrigger bearing plates wont be fitted until the engine is in the frame, which leaves just the inlet manifolds to be sourced, which in turn will have to wait until I can visit the local Zed shop, to make sure I get the correct parts to fit the Mikuni RS34 carbs.
    The frame and bodywork is almost ready for power coat and paint, the former having been braced and brackets added to support the seat base and battery box. The last job is to fabricate the stainless splash guard and undertray. Again something that will have to wait until the current lockdown ends next month. Getting a smooth finish on the fibreglass seat base has been difficult, in the end we glassed in an alloy plate with turned edges to help get a straight edges to sides of the seat.
    However, I have been recently bought another Zed, this time an unfinished Z1000Mk2 project, which happens to have the engine from my old Z1400 Turbo. The turbo has long gone, but it retains its Orient Express big block. The wheels and rear shocks in the pic below will be replaced with cooler and more expensive aftermarket parts. Oh and I've also been given a Z650 in pieces, which will be rebuilt and given to a friend as a surprise, who is currently bikeless.
    #63
  4. Bevelheadmhr
    Mar 16, 2013
    675
    Cheshire, UK
    The fibreglass seat base proved to be tricky to get right, in the end we cut away the most uneven section and used an aluminium plate glassed into the underside, to both support the threaded mounting studs and give a smoother, straighter edge to the seat base. Its now gone off to a local upholsterer, who said it'll be done in about 4 weeks. He specialises in camper vans, and he's never been busier than the last year.
    The frame is having a stainless splash guard and undertray made at the moment, and once that's done, just need to tidy up some of the welds, before it can finally go for powder coating.
    I'm going to have to finish my long running Guzzi project, before the final assembly of the Zed can begin, as I have no where else to build it.
    #64
  5. Bevelheadmhr
    Mar 16, 2013
    675
    Cheshire, UK
    Bought a fibreglass replica of a BMW R90S cockpit fairing, seems to fit the front end ok, without the need to modify the fairing. Still got to make its mounts, along with completing the mounts for the 7 inch Z1 headlight. Wasn't sure how it would look on a Zed, but looks ok. My mate said it reminded him of bikes in the first Mad Max film..
    #65
    villageidiot likes this.
  6. Bevelheadmhr
    Mar 16, 2013
    675
    Cheshire, UK
    Meanwhile the undertray and splash guard have been made in stainless plate, and the frame has now been powder coated. Just not had chance to go and collect it yet.
    #66
    BergDonk and villageidiot like this.
  7. Bevelheadmhr
    Mar 16, 2013
    675
    Cheshire, UK
    Finally got the Gpz1170 engine in the Z650 frame, though it put up a fight. We had to remove the sump and cut back a tab that had been added to mount the Z1 side panel. The latter being done after the engine had gone off to be rebuilt. There's enough left of the tab that I can drill and mount a replacement for the piece we had to hacksaw off. Thankfully it behind the side panel so will be hidden from view. Note that the front rubber engine mount has been replaced with a solid mount, using top hat spacers.
    #67
  8. HapHazard
    HapHazard Be Kind - Rewind
    Dec 30, 2009
    6,922
    Central CT
    ^That certainly fills up the space!
    Great progress!
    #68
  9. Tanshanomi
    Tanshanomi Your Favorite Uncle Supporter
    Jul 22, 2009
    3,904
    Heart of America
    #69
  10. Bevelheadmhr
    Mar 16, 2013
    675
    Cheshire, UK
    R IMG_0154.JPG emoved the hubs from the homemade rear wheel, to clean up the finish, and replace the old cap heads which bolted them to the wheel centre. Hit a problem when the new cap head bolts wouldn't tighten up correctly into the recesses made for them in the base of the hubs. Turns out the old cap head bolts had been machined down slightly so they'd fit the hub. So had to repeat the machining on the new bolts too..
    #70
  11. Bevelheadmhr
    Mar 16, 2013
    675
    Cheshire, UK
    Finally got the engine/frame back home today, so started to test fit parts, to see how it all looks.. when I hit another unexpected problem, this time the lovely upholstered seat - with its fibreglass base which was made on the frame - doesn't fit on the frame anymore, not by a little, but by a lot. Took a few seconds before I realised what had happened.. it'll have to go back to the upholsterer to be completely redone. My fault, as I'd made an assumption, which wasn't the case.
    Can you guess why the seat wouldn't fit the frame??
    #71
  12. Kai Ju
    Kai Ju Long timer Supporter
    Jul 29, 2009
    5,180
    Long Beach, California
    Cover stretched too tight ?
    #72
  13. 3legs
    3legs Real men ride sidecars Supporter
    Oct 3, 2007
    3,725
    Adelaide,South Oz
    Check out the great Aussie motorcycle movie " Stone " Just about all the bikes were Z9's. They had the bikini fairings on them. Look great on a Z9.
    They are actually a great little fairing. Have one on my BMW K1100 outfit.
    #73
    mkprz, BergDonk and villageidiot like this.
  14. Bevelheadmhr
    Mar 16, 2013
    675
    Cheshire, UK
    No, its more stupid than that!
    #74
  15. Bevelheadmhr
    Mar 16, 2013
    675
    Cheshire, UK
    Great film, saw it on VHS many years ago, I think it came out before Mad Max1 ?
    #75
    3legs likes this.
  16. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    17,350
    Orange County, CA
    wrong seat
    #76
    Kai Ju likes this.
  17. Bevelheadmhr
    Mar 16, 2013
    675
    Cheshire, UK
    No its the right seat
    #77
  18. villageidiot
    Apr 29, 2010
    17,350
    Orange County, CA
    suspense is killing me!
    #78
  19. Kai Ju
    Jul 29, 2009
    5,180
    wrong cover
    #79
  20. Tanshanomi
    Jul 22, 2009
    3,904
    Heart of America
    Upholstery on backwards?
    #80
