KDX200
Discussion in '2 smokers' started by tag3, Jan 26, 2018.
  1. tag3
    tag3 Doofus
    Jan 17, 2014
    16,573
    Inland from the coast of Santa Cruz and Trona.
    And does this look purdy?
    I'll get the cases up here soon too.
  2. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    3,968
    How did that carb turn out?
    I am so bad at cleaning that stuff up. What did you use on the cases? 2324BA3B-8B01-4EE9-A3CD-FDB1076BD07D.jpeg
  3. tag3
    tag3 Doofus
    Jan 17, 2014
    16,573
    Carb was FULL of piss. In other words, glad I had another around.
    I put the cases in the glass bead blast cab. Should maybe have it all back together this weekend...........maybe.
  4. tag3
    tag3 Doofus
    Jan 17, 2014
    16,573
    A little rebuild porn.
    Then. 1226191828.jpg And now.
    Cylinder and head are just sitting there.
    Few more parts to clean up and then the building.
  5. tag3
    tag3 Doofus
    Jan 17, 2014
    16,573
  6. PistonPants
    PistonPants Crankcase Scavenger
    Jun 11, 2008
    804
    Cantwell, AK
    Oooooooh Shiny!
  7. Tripped1
    Tripped1 Smoove, Smoove like velvet.
    Aug 6, 2009
    33,874
    Nippon
    I just picked this guy up.
    $700 and a Klim overlander that I bought off of the PO for $300 :rofl Running condition, but I have to go back frigging 25 years till the last time that I putzed with a Kawi 2 smoker, this should be fun.
    The real question is how long can I last before tearing it apart and messing with things....and these old dynosaurmobiles there is always something that can be messed with.
    greasyfatman likes this.
  8. tag3
    tag3 Doofus
    Jan 17, 2014
    16,573
    I see blinkers. Nice!
  9. Tripped1
    Aug 6, 2009
    33,874
    Nippon
    Yeah, actually plated and legal.
    Issue is that its JDM so smaller tank and carb from my understanding. Gets delivered Thursday.
  10. tHEtREV
    tHEtREV Encouragement award recipient. tEAM iDIOT.
    Apr 14, 2007
    12,659
    Middle Park, Brisbane, Australia
    Steel tank, smaller carb (I think) and oil injection like the Australian KDX200F?
  11. Tripped1
    Aug 6, 2009
    33,874
    Nippon
    Correct on all three.
  12. greasyfatman
    Oct 18, 2014
    3,968
    Sweet man that is straight.
  13. Tripped1
    Aug 6, 2009
    33,874
    Nippon
    So got the bike....it is sort of baggy until it warms up then it is nasty.
    Man I forgot what a 21" wheel feels like its SO SLOW.....I also forgot what a bike with no battery is.
  14. Tripped1
    Aug 6, 2009
    33,874
    Nippon
    So for the hive
    Anyone got thoughts on the reliability of the (fuel) oil pump?
    I came across the carb boot and US spec carb but I will have to modify the boot to use the oil injector....which I have to say I don't really want to remove. Also anyone got sources for the shop manual, and springs? I am a solid 60 pounds to heavy for whatever is on the bike now, its grounding like a mother.
    Man though, took it out (with my Ducati's plate on it :lol3) and once i got it in some snotted up single track, the little thing is FUN AS FUCK, super easy to ride and a only as much nasty as you want it to have. I forgot what riding on a loose surface with +500lbs of beast to wrestle with.
    So, so good, and I haven't ridden anything more gnarly than a fire road in decades.
  15. tag3
    tag3 Doofus
    Jan 17, 2014
    16,573
    Welcome to the fun side of life.
  16. SloCalSpode
    SloCalSpode Been here awhile
    Jun 13, 2007
    136
    Got a question for the KDX200SR owners.
    Is the gearing ratio different than say a US version of the off-road KDX?
    Reason I ask, is I SuperMotarded my 1990 and would like a more road going
    speed potential. And would it be possible to locate said gears in the US?
    I am running 14/42 gearing already and the bike is really on the pipe so to speak
    at anything above 40MPH in top gear. Would be nice to cruise at 50-55 and not
    be right where the bike goes into "wild mode"
    BTW, this bike has the LA Sleeve Co. 240cc kit. No primary power valve, but does
    have the sub valves. It sure does pull strong in the lower half of the RPM range.
    Thanks and cheers, Jeff
  17. Tripped1
    Aug 6, 2009
    33,874
    Nippon
    Your overall drive is going to be significantly different with the 17" rear on it...
    Ideally you take the difference in OD between stock and your street tire and then adjust the final drive by the difference......with stock (I think) its not going very fast when I hit 6th, maybe 50-55mph......and I am usually wrapping it out, I am used to big CC twins.
  18. tag3
    tag3 Doofus
    Jan 17, 2014
    16,573
    After working 7 days a week since March I have had a day to put things together a bit more. Well, after a 9hr day at work I got this far.
    More to come......
