KLiM KRIOS Helmet
Discussion in 'Equipment' started by Smackit, Aug 4, 2016.
  1. NCD
    NCD Dirty Hairy Supporter
    Nov 13, 2008
    854
    NE Ohio
    I received an order confirmation for a replacement helmet (won't see it until the end of the month) so I let curiosity get the best of me.
    The ENTIRE top and much of the sides are Koroyd. I'm very pleased to see this much in there. The EPS is around the lower perimeter where you need to attach things or have dedicated vent channels.
    The carbon layup on the shell is clean and consistent. The vents above the shield not only head to your forehead, but also channel up on top of the Koroyd. That's why this thing feels so airy.
    Klim was awesome with the warranty, so I will just share this one photo so owners in this thread and those considering the helmet here on ADV can see under the hood.
    Ride on!
    CJMCB, ZoomerP, Madman4049 and 7 others like this.
  2. dolomite
    dolomite Adventurer
    Oct 14, 2019
    87
    Albuquerque, NM
    I guess I've been hesitant since Revzilla says: In RevZilla's experience, Pinlock shields and inserts for Arai XD-4 Helmets are not as effective as Pinlock shields and inserts for other Arai helmets due to the compound curves of the shield.
    There's also a new anti-fog face shield so maybe I should try that. Sorry to derail the thread!
  3. jerbelgium
    jerbelgium Adventurer
    Oct 3, 2008
    53
    Nishua Enduro Helmet from Louis in Germany.
    Today I was at their shop to try the Nishua Enduro helmet and L fitted like the XD4 in L. perfect.
    I read a lot that this helmet is not available in the USA or Canada, and Louis is not shipping to you. In case you would be interested, or in case more of you are interested, feel welcome to contact me and I can arrange shipment for you.
    Even if you would be able to group with more people, I will arrange the shipping of your helmets
    feel welcome to DM me for my emailaddress and cell Phone number…………...
    motogluten and tsak8 like this.
  4. JMforPres
    JMforPres Long timer Supporter
    Apr 13, 2008
    1,564
    Charlotte, NC
  5. dolomite
    dolomite Adventurer
    Oct 14, 2019
    87
    Albuquerque, NM
    Bought one on ebay, I'm desperate for anything to make this helmet viable for another wet season. And Arai's $75 "fog-resistant" visor doesn't exactly get rave reviews.
  6. Bahox
    Bahox Adventurer
    Aug 3, 2016
    43
    I have been using Klim Krios Helmet in some middle east countries and some Asian countries.
    +++ Light weight, good protection
    --- very noisy, not enough ventilation
    This is my worse comfortable helmet i have ever used. This helmet does not deserve that much money.
    So I advice you that "DO NOT BUY KLIM KRIOS"
  7. dmitriy_adv
    dmitriy_adv Dmitriy M
    May 17, 2012
    268
    All over the USA
    I've been working through my backlog of projects during this COVID19 lockdown thing, and decided to see if I can address the rattle. Looking closer at it, the problem is definitely that the locking mechanisms on the side are not tight and can move/rattle when hit by wind. On one side the peak actually comes in contact with "nub" that goes into the visor detents, which seems to make most of the noise, but the visor moving back and forth in the mechanism isn't helping. I've contacted Klim about this, but have not gotten a response.
    I heard some people adding spacers/washers, so I took some pieces of an old tube and super glued them on the underside of the visor. Seems to make for a much tighter fit and eliminates the rattle. Hopefully this will be an easy fix to my problem, we'll see in a few weeks!
    Swashplate likes this.
  8. GF-kam
    GF-kam Long timer
    Aug 19, 2013
    1,989
    Great Falls, Virginia, USA
    Nice direction !
    So remind me what happened to helmet to trigger warranty?
  9. NCD
    Nov 13, 2008
    854
    NE Ohio
    @GF-kam it was an assembly mistake where the shell was glued to the foam out of whack. I didn't notice it for months.
    GF-kam likes this.
  10. Monty_Stubble
    Monty_Stubble n00b
    May 19, 2020
    2
    West Yorkshire
    OK - A simple question - I've just plowed through these and I'm still not sure. Do Klim face shields fit on a Nishua?
  11. NCD
    Nov 13, 2008
    854
    NE Ohio
    From what I understand - yes they are the same.
  12. MtnRider
    MtnRider Been here awhile Supporter
    Nov 23, 2008
    529
    Santa Rosa, CA
    Yes so does the visor
  13. Wildmtn
    Wildmtn Still Lost
    Aug 30, 2017
    341
    Northern Colorado
    I recently grabbed a Krios Pro and like the light weight. I usually wear a Hornet x2 in XL and the Krios fit me best in a L. I think the Krios does better in the wind than my Hornet. I will say that it doesn't seem to seal up as well as my Hornet as I could feel air even with the vents closed on a cold ride.
  14. GF-kam
    GF-kam Long timer
    Aug 19, 2013
    1,989
    Sounds like an endorsement for a more ventilated design, once we have temps in 90+ degrees.
  15. tsak8
    tsak8 Adventurer
    Sep 22, 2010
    32
    Athens,Greece
    Hi everyone,
    So has anyone "upgraded" from the Krios carbon to the newest Pro model?
    I have no complaints from it but considering the Pro for the transitions visor and the extra(?) safety.
    Do you think is worth it?
  16. Madman4049
    Madman4049 Been here awhile
    Jan 11, 2017
    572
    NW Louisiana
    Never had the original krios but I did upgrade from a Schuberth E1, the lightweight, venting, transitions shield and comfort of knowing I have koroyd wrapped around my skull in an off is definitely worth it. Not to mention the added visibility through the bigger visor.
    I will mirror Wildmtn though, it doesn't seal nearly as well as my Schuberth but then again not much does, Schuberth's renowned for going over the top with sealing, noise reduction, etc. If they were more lightweight I would have never left the Schuberth. The Krios feels like a dirt helmet with a visor, the Schuberth feels like a NASA helmet.
    Oeths, yoohah and tsak8 like this.
  17. slartidbartfast
    slartidbartfast Life is for good friends and great adventures Supporter
    Dec 23, 2003
    13,494
    Southern Louisiana or Southern England or ...
    I'm fascinated (and impressed) with the fact that Klim seems to be leading the charge in utilizing this new technology in their helmets. I would not have expected that from a company whose main products (until recently) have been clothing. You would have thought that it would take a bigger helmet manufacturer, with more dedicated resources, to do all the necessary design and testing.
    I have an original K1R which is fabulously light and beautifully made. I love the transition shield also. It is the lightest, most comfortable helmet I have ever owned, by a wide margin and I would wear it all the time except... The top vents were so noisy as to make the helmet all but unwearable until I ripped them off, plugged the holes and molded covers over them. Then I realized that there was STILL horrible wind noise because the faceshield has a 1/8" gap along the top. I have got a strip of sealing foam in this gap but it's a bodge that makes the shield harder to close and detracts from the overall appearance and image of the helmet IMO. Even with these defects (sort of) band-aided, it is still a very loud helmet.
    Frankly, these almost inexcusable, fundamental design and quality defects makes me extremely wary of spending big bucks on another Klim helmet. Their utterly false claims about it being a quiet helmet have really turned me off too. I have been transitioning much of my riding gear to Klim because the quality and comfort is fabulous, IMO. I used a couple of pairs of their cheaper pants for a while before throwing down for an $800+ jacket and I'm pretty happy with that. I would dearly love to try the Krios Pro but will be waiting for the price to drop or hoping someone from Klim reads this and offers me a trade-up or product testing deal :lol2
  18. Monty_Stubble
    Monty_Stubble n00b
    May 19, 2020
    2
    West Yorkshire
    Bought myself the Nishua helmet from Louis in Germany for £166. Identical to the Krios but no pretty colours. Only in black and grey. Then bought a Klim Transitions visor. They fit perfectly. The helmet doesn't seem noisy to me. Perfect solution on a sensible budget. Absolutely no complaints.
    tennyis, Oeths and roookie1 like this.
  19. tennyis
    tennyis Been here awhile
    May 10, 2010
    793
    So with my AT950 falling apart, i've decided to look towards a more dirt oriented helmet. I really liked the Krios pro but not the price! I noticed the regular is on clearance at Fortnine for $480 (canadian) vs $930 for the Pro. I decided to go for it but after reading some comments on here i'm starting to second guess! I could get another AT950 for $360, it did last me 40,000 miles or they have a deal on a Bell MX-9 Mips Adventure for $230. Should I be emailing them to change my order? I don't want to get stuck paying return shipping if it's as bad as everyone says. I'm not overly worried about noise as on my AT950 I ride with the shield up unless it's cold or raining. That helmet is actually quieter with the shield up lol.
  20. slartidbartfast
    Dec 23, 2003
    13,494
    I had a look at the Nishua helmets. Presumably Nishua is the contract manufacturer for Klim. However, their latest model appears to be the same as the old Klim Krios. It does not have the new honeycomb crushable protection as the Krios Pro.
