KLR footpeg bolt problem
Discussion in 'Thumpers' started by Arkzooky, Dec 11, 2010.
  1. RLK
    RLK RLK KLR
    Nov 22, 2004
    7,740
    CSprings
    Mine's broken. The bolt broke but what also broke is the weld holding the nut in the box. The nut with the broken bolt inside are spinning around on the drill bit. That splatter is from when I tried to weld the bracket on. The back nut drilled easily enough but there's not much to tap for M10 1.5. The box has to come off.
    #21
