KLR, puked her guts in Fairbanks
Discussion in 'Thumpers' started by Carl Stark, Jul 7, 2011.
  1. Carl Stark
    Carl Stark Adventurer
    Apr 11, 2006
    70
    Sheridan WY
    2005 KLR 650 19,000miles. We were 30 miles from Fairbanks on Park Hwy when it overheated and died. We let it cool down for app 30 mins (had water in it) and it restarted but would not idle. Headed back to Fairbanks it was puffing smoke on acceleration and blowing oil into air box and dripping off of bottom of engine. It used app 1/2 quart of oil in 50 miles.
    We are back at the Dorm and are hoping to ride it to Eagle River tomorrow by pouring oil in as needed. Anyone have any experience with similar situation, or have advice on if this is a good decision? How is cell service between Fairbanks and Anchorage in case need to call a tow truck?
    Also, need opinions on a 685 kit and which one to get?
    Carl and Jonnie Stark
    307-752-5459
  2. Foot dragger
    Foot dragger singletracker
    Dec 27, 2006
    20,427
    chico,just below rag dump(nor-cal)
    Yikes! I wouldnt bet on it going very far if its doing all that,something is broke and might break worse soon. Might be rent a trailer time.
  3. NJ-Brett
    NJ-Brett Brett
    Sep 8, 2010
    9,279
    Southern New Jersey
    I would think that is a bad move.
    If things come apart (more?) when the engine is spinning, the entire engine could be trashed, not just a piston/bore needed.
    Life and death, or if you don't mind having to throw the dead bike in a ditch, otherwise I would not push it.
  4. tim007
    tim007 Banned
    Jan 12, 2010
    470
    portland///vancouver
    has anyone called the cell?
  5. Ensey
    Ensey KLR Combat Touring
    Oct 4, 2004
    739
    Duncan, Ok
    You need to also post this in the Alaska forum so you can get some local help.
  6. vatrader01
    vatrader01 vatrader01
    Jan 11, 2007
    1,164
    Gateway to Skyline Drive, Virginia
    Most of the description sounds a lot like a blown head gasket. Check your PM's.
  7. vintagespeed
    vintagespeed fNg
    May 9, 2011
    3,444
    Rancho Cucamonger, CA
    sounds like it's done man, dont ride that thing it's just going to lock up on you.
  8. subybaja
    subybaja Long timer
    Jul 18, 2007
    2,896
    Anchorage (Spenard)
    Three things come to mind:
    Adventure Cycleworks, LLC
    362 Snowy Owl Lane
    Fairbanks, AK 99712
    http://www.advcycleworks.com
    Thread: New service shop in Fairbanks, Alaska
    FriarMike runs
    The Abbey
    Knik Goose Bay Road
    Wasilla, AK 99654 <nobr>(907) 376-6919</nobr> &#8206;
    Great work, usually booked solid.
    WymanWinn on klr650.net keeps several Schnitz Racing 685cc pistons and cylinders on the shelf, bored, gapped, ready to install. He's a great guy, and I'll bet he'll ship overnight.
    Yikes! Uhaul's online quote from FAI to ANC is $410! Box truck only available...
    PS- pouring oil on the road is your bikes' subtle message to STOP RIDING IT! (on the other hand, if you've got a broken ring/piston land, it's already FUBAR. If the piston/cylinder has to be replaced, what've you got to lose?)
    #8
  9. tim007
    tim007 Banned
    Jan 12, 2010
    470
    talked to wyman and its $450 shipped and its now a 688cc kit but you need to send him a good cylinder its $700 if you want his items first and then send him your cylinder later .
    daddys going to get an upgrade soon .. ok thread jack over
    #9
  10. HighwayChile
    HighwayChile greetings from Wa state
    Aug 19, 2003
    4,962
    Bow, WA USA
    Don't rent a truck , talk To a local, pay em cash, gas or booze, for the lift, make a friend , you'll both be better
    #10
  11. BikePilot
    BikePilot Long timer
    Jul 5, 2005
    11,675
    Golden CO
    It could be a bad head gasket or something other than piston/rings/cyliner (though those are a known weak spot on the klr) - the piston theory doesn't explain why it overheated first. Clogged radiator? Waterpump impeller shot? Headgasket (back to that...).
    #11
  12. JamesG
    JamesG Rabid Poster
    Dec 31, 2006
    10,946
    Columbus, GA
    At least it wasn't the Doohickey of Doom.
    #12
  13. Max Overbore
    Max Overbore Crusty, Hi-milage noob
    Oct 10, 2007
    19
