KLR250 thread
Discussion in 'Thumpers' started by Bad Company, May 10, 2008.
  1. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    5,154
    When my mini bikes failed the gas cane back 17% not gas. On a 30 degree day thats lean as well failed.
    A Seabee likes this.
  2. A Seabee
    A Seabee Adventurer
    Dec 25, 2011
    23
    SoCal
    well, you can take the ethanol out, but that's what they're using for Octane these days. I use racing gas in my bikes that have carbs and sit. It's a night and day difference
  3. enumclaw
    enumclaw I just....don't know
    Dec 3, 2008
    988
    Outer fringes of the Puget Sound Region
    Great points. I have non-ethanol available to me, which I have used most of the time. But more than that, I have drained the tank and used fresh gas at least a couple of times over the years.
    I am pretty certain the cam timing is good, primarily because it runs well and is not lacking for throttle response when started and warmed up. But I will have to double check it now.
    Thanks for the ideas.
  4. 8gv
    8gv Long timer
    Nov 22, 2009
    4,437
    CT exile now in NH
    Refresh my memory...
    Does the KLR250 have a vacuum operated fuel tap?
  5. greasyfatman
    Oct 18, 2014
    5,154
    No. But it has the filter straws in the tank and a tank vent that clog. I wonder if fuel is slow filling the bowl?
  6. enumclaw
    Dec 3, 2008
    988
    Flow is good, was just out trying to start it again. 25-30 kicks with barely a sputter. F me. It will sit for a while again while I'm away for a week.
  7. greasyfatman
    Oct 18, 2014
    5,154
    Compression check. Feel for spark. Try starting fluid. One will let us know whats up.
    triptych likes this.
  8. A Seabee
    A Seabee Adventurer
    Dec 25, 2011
    23
    SoCal
    Maybe it's an ignition problem
  9. enumclaw
    Dec 3, 2008
    988
    It'll be about a week before I can get back, and get back to it. I'll check basics and let you all know. Thanks.
  10. greasyfatman
    Oct 18, 2014
    5,154
    Whats the spring on you KACR look like? Could this be staying engaged?
    laylow3down likes this.
  11. triptych
    triptych KLR250
    May 1, 2017
    65
    down under
    @enumclaw sounds like just about everything has been mentioned already, but have you tried tweaking the pilot screw? it can be quite lean from the factory...
    my bike does not cold start first or second kick unless I ride it daily, but once i'd fixed the air leaks and bad valve clearances that it came with, backing out the pilot screw a little bit more really helped
    some versions have the pilot screw covered by a plug or cap that can be drilled out if you're careful, i'm sure that's documented elsewhere in this thread
  12. laylow3down
    laylow3down dirt bike mike
    Jul 24, 2013
    730
    all over the DMV
    @enumclaw how does it feel when you kick start it? is it easy? could be the KACR as Greasy mentioned... my bike would stall some times because of this and it would always take many kicks to get it going before I completely removed the KACR from the exhaust cam...
  13. laylow3down
    Jul 24, 2013
    730
    all over the DMV
    triptych and A Seabee like this.
  14. A Seabee
    A Seabee Adventurer
    Dec 25, 2011
    23
    SoCal
    what did you do?
  15. greasyfatman
    Oct 18, 2014
    5,154
    Check out his can man.
  16. A Seabee
    A Seabee Adventurer
    Dec 25, 2011
    23
    SoCal
    the muffler?
  17. greasyfatman
    Oct 18, 2014
    5,154
    Lol what ever you NAVY guys are into:lol3
    yes Can and muffler are synonymous.
  18. nails1
    nails1 Been here awhile
    Feb 21, 2008
    374
    New Mexico
    Is it heinously loud?
  19. enumclaw
    Dec 3, 2008
    988
    Thanks again guys. Haven't forgotten it again, just have had life get in the way. Hoping to check some things out this weekend.
  20. triptych
    triptych KLR250
    May 1, 2017
    65
    down under
    Did you rejet for that?
