KLR650 Only Thread......
Discussion in 'Thumpers' started by willys, Nov 19, 2011.
  1. skibo
    skibo Adventurer
    May 10, 2016
    19
    On the road
    I did the test, and got about 54 vAC continuous--didn't get the up and down I expected. I also played around with the ignition coil some more, double checking it. It's all within Clymer specs--input (during cranking across both leads) came to 33 vDC (not the 18 originally stated--meter was on wrong mode). I also tried to test output of the ignition coil, since I got some input. I could not find any output (AC or DC). Plug cap and plug wires were tested, and were good. I'm assuming I should be able to measure the output, but I don't know whether it should be AC or DC. My multimeter is a pain to use when I don't know the range of expected values (e.g. if high, then it doesn't give me any indication, so I have to test multiple ranges).
    I also retested the stator as outlined on () Since the bike won't start, I'm not sure whether to expect the AC output (just turning it over). But the circuit continuity was consistent (i.e. no shorts).
    Thanks again. Suggestions anyone?
  2. GreatWhiteNorth
    GreatWhiteNorth Long timer
    Dec 2, 2009
    4,790
    Winterpeg - site of flatness beyond belief
    Kill switch. I've had two Gen 1 kill switch assemblies that were intermittent. Couldn't see anything physically wrong with the harness wires or connectors, but replacing with a new switch assembly fixed an intermittent ignition issue.
  3. skibo
    skibo Adventurer
    May 10, 2016
    19
    On the road
    Interesting you mention that. My switch broke a couple of years ago in a crash. After worrying about the electricians' tape keeping it on the "on" position, I ended up filling it with epoxy. I'm the perfect KLR owner!
  4. beemerjim
    beemerjim Been here awhile
    Jun 26, 2008
    712
    w mass
    Ya !! Filled it with Epoxy. I love it!
    jim
  5. John Fry
    John Fry Adventurer
    Jan 4, 2009
    38
    Need some recommendations and, sources for parts.
    2008 klr685 mostly on slab.
    Time for new chain and, both sprockets.
    I'd like to drop rpm at top speed. I've heard changing front sprocket size can shorten life span. Can it be done at the rear sprocket?
    Can I get a suggestion for a good size and quality combination of sprockets and, chain.
    Also need new rear shock.
    Possibly a muffler. I'd like to stay quiet.
    Prefer a Canadian store/website if possible.
    Thanks for your input.
  6. GreatWhiteNorth
    Dec 2, 2009
    4,790
    BikeBandit shows a new kill switch assembly as costing $60.
  7. Tweakedlogic
    Tweakedlogic Adventurer
    Jan 15, 2009
    35
    Memphis TN
    1376 pages of posts???
    To me it makes more since to have bike specific sub-forums. Easier to search, research, and find what you looking for without asking the same questions that have been asked already.
    I just got an 03 KLR, but i cant find the answers i need in this thread.
    Peace out
  8. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,047
    I get most of my KLR info on FB.
    There are several great pages that you get answers in just minutes most of the time.
  9. skibo
    skibo Adventurer
    May 10, 2016
    19
    On the road
    Thanks, I'll look into it.
  10. HardWorkingDog
    HardWorkingDog Harvey Mushman
    Aug 20, 2009
    2,996
    Walnut Crick, Cal.
    What are we missing here? Your first post to advrider in over 3 years, and it's to complain that this place is too hard?
    There's a search button on every page that works quite well. Or...just ask? Maybe BigFatAl is doing us all a favor--try Facebook.
    k-ris and GreatWhiteNorth like this.
  11. sideroadbob
    sideroadbob Been here awhile
    May 21, 2016
    114
    Kars, Ontario
    What is this Facebook thing you speak of?
    Sent from my LG-H831 using Tapatalk
    Snowbird likes this.
  12. Grinnin
    Grinnin Forever N00b
    Dec 10, 2005
    4,994
    Maine
    Ask away. Most of us are willing to rehash the questions and answers.
  13. Grinnin
    Dec 10, 2005
    4,994
    Maine
    I don't believe that a 16t front sprocket would significantly shorten lifespan. (15t is stock.) Having the bike setup for comfortably performing the kind of riding I do is more important than getting an additional 1,000 miles before rebuild.
    As my riding changes from time to time I've used the stock 15t, I've used 14t for trails, and I've used 16t for roads. With the 16t, the KLR is like a 4-speed around the rural roads here with an overdrive for faster roads. (Even if it's not numerically an overdrive.)
  14. Pollack
    Pollack Adventurer
    May 31, 2014
    875
    I have been using a 17T for the last 10K miles, on pace for a new chain in another 10K.
    Best regards,
  15. GreatWhiteNorth
    Dec 2, 2009
    4,790
    A larger front sprocket will actually wear slightly (emphasis on slightly) slower, as it's spreading the force over more teeth. I tried a 17T, took it off as I found it made 1st gear too tall. I found myself stalling a little too often getting going from a stop, and IMO it makes gearing too tall for offroad/dirt trails. Sure helps drop the rpm for highway cruising tho.
  16. GreatWhiteNorth
    Dec 2, 2009
    4,790
    Thought I'd share this... Today I installed an LED tail light (the LEDs on a circuit board set-up), and an LED strip type trailer light (mounted to thin L angle aluminium) on to this Gen 1 I'm fixing up (the salvage yard special :^) The HID lights in that Britannia Composites fairing are very bright and white. The license plate light is LED too. What a major upgrade over stock lighting. I'll be adding two aux lights up front as well (see and be seen).
  17. Tweakedlogic
    Jan 15, 2009
    35
    Memphis TN
    Just saying, I've been using different forums for a long time. Never seen one lump everything together like this in one thread. It's always been sub forums. Which has the benefit search by title in case I need to find threads related only to wiring, custom port work, parts for sale, or just pic threads, etc. It also makes it easier to browse when I don't know what I'm looking for.
    And yes, it's been a long time since I've been on. 3 years ago the wife got knocked up and I didn't have an adv bike. Now I have one, the kid is a bit more independent, so I've been dreaming, planning, and researching. I wasn't trying to come off as a dick. Just un-requested $.02
  18. GreatWhiteNorth
    Dec 2, 2009
    4,790
    You've got a valid point, and it's been brought up before. I'm guessing those "other" forums are KLR specific? When the site admin changed over the forum engine to this one (XenForo/Waindigo or whatever it is), the search feature become much better. It's not perfect, but it's better than it was.
  19. Tweakedlogic
    Jan 15, 2009
    35
    Memphis TN
    Varied... vintage motorcycle, 4x4 trucks, my RX7, bees, wood working, cafe racers, bicycles, contractor forums, beer/wine making. I'm into different stuff.
    Most follow the format i described. This way is a little weird to me.
  20. GreatWhiteNorth
    Dec 2, 2009
    4,790
    Before the forum engine was changed, you could only search within a sub forum (like thumpers)... now at least you can restrict the search to "this thread only", a huge improvement. Lots of good info in this thread... just gotta dig for it.
    thechief86 likes this.
