KLR650 Only Thread......
Discussion in 'Thumpers' started by willys, Nov 19, 2011.
  1. Bobk0
    Bobk0 Mentos..The Trailmaker
    Jan 31, 2014
    1,164
    On Some Impossible Trail
    Started to cut out lettering of KLR decals with an exacto. It should srencil pretty well. Not sure what color combo to use yet. 20190930_175540.jpg
  2. TheHeretic
    TheHeretic Been here awhile
    Jun 7, 2005
    524
    RI
    Maybe a dumb question but I currently have Cycle rack panniers on my KLR and HF pelican knock-off cases. I'm wondering what type of soft bags could be mounted to the racks that I could collapse some when not in use so the bike profile would be slimmer and maybe reduce the weight a bit compared to the hard cases. I've been looking around but nothing specifically tells me that the soft bags can be cinched down when not in use.
  3. Dread
    Dread Putt-Putt Adventurer
    Sep 17, 2006
    707
    Boise, ID
    Really any soft bag with compression straps that doesn't have an internal stiffener. I use HF pelican knock offs too, but also just got some Giant Loop motottrek panniers. They cinch down, though not completely flat.
    TheHeretic and Dan Diego like this.
  4. XDragRacer
    XDragRacer Long timer Supporter
    Mar 25, 2009
    5,272
    A modest proposal: Consider CycleRacks textile bags:
    Durable, crash-worthy (don't ask me how I know this!) "soft" panniers and top case. Fit and interchange seamlessly between KLR650 and KLR250.
    Check out, "Products," about the third page, of the Cycleracks website.
    (Polar bear not included.)
    Nerf bags: Happy Trails; handlebar and tank bags, Kawasaki.
    TheHeretic likes this.
  5. TheHeretic
    Jun 7, 2005
    524
    RI
    Thanks Guys!
  6. Pollack
    Pollack Adventurer
    May 31, 2014
    1,244
    Here is an issue I have not read about. This summer my front right indicator broke, or the rubber that holds it in place. About a month later the other side broke. Two months later the left rear indicator broke so I order a new one as well as the right rear one. The right rear one was half torn so to speak. In the span of approximately four months all four failed. Mine is a 13' so the lasted about six years. I'm not sure if this is the norm; however, I have used a cover since the day I bought the bike new. The mild wear and tear of putting on and off may have accelerated the wear. :dunno
    Best regards,
  7. Baja_Bound
    Baja_Bound Been here awhile
    Dec 23, 2011
    156
    Texas
    Pollack likes this.
  8. mikehailwood
    mikehailwood Been here awhile
    Dec 24, 2005
    333
    St. Louis, MO / Estes Park, CO
    Didn't 2008's or 2009's have this problem covered by warranty?
  9. Late for the Party
    Late for the Party Been here awhile Supporter
    Sep 21, 2010
    146
    My son's '09 had the same issue.
    At about 10k on mileage, his left front signal broke at the rubber base, followed about 4 months and 2k later by his right front signal the same way. Other than back country trips, it lives in a garage and is well cared for.
  10. Windborne11
    Windborne11 Been here awhile
    Aug 23, 2018
    477
    East of the West Coast
    There was a recall on signals on the 08's I believe.
  11. Gallowbraid
    Gallowbraid Been here awhile
    Nov 11, 2010
    909
    Woodstock, GA
    08 and 09's saw a change in the source of rubber bits on the KLRs. The stalks for blinkers would fail as would some of the rubber shielding for the main wiring harness. The stalks are annoying, the wire harness protection failing would cause shorts as wire insulation rubbed through and would leave people stranded. I believe Kawasaki covered the wire harness under the recall universally, but replacement of the blinker stalks was hit or miss. There's a fella out there 3D printing replacements: https://3dcycleparts.com/2008-KLR-6...inker-Fix-NEW-Easy-Install-Version-p108657506
  12. Alex_Burton
    Alex_Burton Adventurer
    Mar 18, 2019
    89
    The Great Amerikanski Desert
    MASSIVE BUMMER! I've got a stuck engine on my 2004 KLR650. My friendly local motorcycle shop is putting together an estimate as to what it'll cost to fix it, but I'm told it might be less $$$ to buy a good used engine from a salvaged KLR650 instead of repairing what I've got. So I've got two questions I hope y'all can help me with;
    1.) Does anyone here have either a complete engine or a complete lower end they'd be willing to part with OR can anyone recommend a honest/reliable source for the same?
    2.) Will a Gen2 engine work for a Gen 1 KLR650?
    Your help is much appreciated!
  13. willfreely
    willfreely Elderly Belligerent
    Jan 15, 2013
    1,578
    Eastern Middle Tenn
    Your cost to fix, though, could include a 685 upgrade.
    Hannda likes this.
  14. Hannda
    Hannda Short, fat, bearded, old & slow
    Apr 27, 2005
    48,342
    Not yet far enough away from town
    And wouldn't burn oil like a Gen2 engine.
    ZachM1 likes this.
  15. willfreely
    Jan 15, 2013
    1,578
    Eastern Middle Tenn
    I resemble that remark.
    Hannda likes this.
  16. phideaux
    phideaux Long timer Super Supporter
    Feb 4, 2008
    4,081
    NW Georgia
    Make that 'should'!
  17. XDragRacer
    Mar 25, 2009
    5,272
    Yes, and no. Can be done, but . . . here, some obstacles to the conversion:
    Ignition systems remain significantly different between the generations. For example, ignition coils differ, plus . . . engine kill mechanism on Generation 1s shorts-to-ground stator AC source to ignition system, both on kill switch and on ignition switch; engine kill mechanism on Generation 2s interrupts 12 VDC source to ignition. No fan relay on Generation 2s; full fan current routed through thermal radiator switch.
    To this I add, "etc." Other differences may require addressing for a Generation 2 engine implant into a Generation 1 KLR650.
  18. smokediver3
    smokediver3 Adventurer
    Feb 16, 2012
    74
    West "by God" Virginia
    I "lovingly" referred to my 02 as the 2wheeled tractor, and now that parts from it have migrated onto the 92 that I picked up it has become Tractor 2.0, or as my son and one riding buddy dubbed it, Franken-bike.
  19. Windborne11
    Aug 23, 2018
    477
    Anybody fit a 1989 countershaft sprocket onto a 1997+ KLR? Is the spline the same? 1987- 1996 used 2- 6mm bolts and a plate to attach the sprocket, where 1997+ use the big nut. Reason is I can get a 17T sprocket for 1989 model, but not later bikes. I want to try one.
  20. sanders446
    sanders446 Been here awhile
    May 17, 2017
    298
    MA
    Eagle mike sells 17 tooth cs sprockets for the 1996+ big nut bikes and the spacer. Says it may require modification to the plastic cover though.
    https://www.eaglemike.com/Countershaft-sprocket-CSS.htm
    ZachM1 likes this.
